Old 05-27-2014, 10:54 AM   #5727
shif7i7down
Erected Member
Drives: frs
Originally Posted by fenton View Post
Does the code come up when wot or when just starting the car.
Comes on when wot.
Btw, i dont need a 4bar map sensor do i?
shif7i7down is offline   Reply With Quote
Old 05-27-2014, 10:57 AM   #5728
s2d4
s2d4's Avatar
Originally Posted by robwbright View Post
Which makes my CELs yesterday even weirder. They aren't there while driving the car to dads, the car is turned off for 5 minutes, the three CELs show up on restart, I drive 1/2 a mile, turn off the car, clear the CELs, restart the car, and all three of the CELs are gone. They didn't come back the two other times I started/drove the car later in the evening.
Do you have the OFT plugged in?
Old 05-27-2014, 11:01 AM   #5729
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Not on that occasion... I had the bluetooth OBD thing plugged in with Torque Pro running.
That did occur to me as a possible cause for the Network/Electrical CEL.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 05-27-2014, 11:14 AM   #5730
fenton
Originally Posted by shif7i7down View Post
Comes on when wot.
You do not need 4 BAR. The 1.5 the car comes with works fine for our application (5 psi and below).
I am very intrigued as to why you are getting that error when WOT as it would seem that CEL trigger is not excluded from the ROM or something like that.
fenton is offline   Reply With Quote
Old 05-27-2014, 11:43 AM   #5731
shif7i7down
Erected Member
Drives: frs
Idk, maybe @shiv@vishnu can answer that one
Old 05-27-2014, 12:47 PM   #5732
s2d4
s2d4's Avatar
Yeap.
Old 05-27-2014, 01:55 PM   #5733
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Got my 1.5 kit on Sat - need to make time this week to install it!
Finished OFH install, RCE yellows, and spyder headlights + wheel change.
Still not sure where I'm going to mount the display.
Khyron686 is offline   Reply With Quote
Old 05-27-2014, 02:16 PM   #5734
jpit
Drives: Subaru BRZ
Rob,
I'm pretty the U0073 code is a problem with your OBD reader and the torque app. Every once in awhile I get this code even when it is communicating properly and others on this forum have experienced it also. This isn't a code I would worry about.
jpit is offline   Reply With Quote
Old 05-27-2014, 02:30 PM   #5735
Winjr
Drives: 2013 Subaru BRZ Premium
I thought the car's ECU needs to "cycle" through its complete analysis, which varies by car and is usually 20-30 miles worth of driving. Which means that the CEL won't light again immediately after start up, depending upon the problem, but will once the ECU completes its cycle. No?
Winjr is offline   Reply With Quote
Old 05-27-2014, 04:40 PM   #5736
shif7i7down
Erected Member
Drives: frs
I want to rule out Any possible mistake that i may have done to get the P0108 cel.
That rubber tube that connects to the aluminum peice"brass fitting" connects to the little black nub that is sticking out of the controller right?
If all else fails should i buy a new map sensor?
I'll also do some loggs later today
Old 05-27-2014, 04:50 PM   #5737
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
I've been thinking about this and I think you may have loosened a tube under boost. Check this out just in case.
http://www.ft86club.com/forums/showt...26#post1655426
Installed Mods:
Old 05-27-2014, 05:06 PM   #5738
robwbright
No CELs today... running fine and fast.
2006 Saab 9-3 2.0t
Old 05-27-2014, 05:06 PM   #5739
raven1231
you're correct sir
Old 05-27-2014, 05:37 PM   #5740
shif7i7down
Erected Member
Drives: frs
dang, i gotta take that intake plastic manifold thingy off?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
