AVOturboworld
Old 05-05-2014, 04:56 PM   #2941
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by protpibe View Post
King Tut is right. I didn't realize your boost data is coming from your logs and not a boost gauge.
Yeah, I need a boost gauge, I am maxing out at 6.2 when on WOT..seems right, but I would rather know for sure - than rely on Torque (app)
Old 05-07-2014, 04:02 PM   #2942
AVOturboworld
Ross from our AVO Japan office recently went to Indonesia to do 10 AVO turbocharger kits ranging from stage 1 to stage 3 at Racetech, our official distributor.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Astroboy (05-08-2014), SkAsphalt (05-08-2014)
Old 05-07-2014, 10:18 PM   #2943
Bigmaxy
Drives: Pegasus GTS86
Ross is one fashionable dude. :-) lol.
Bigmaxy is offline   Reply With Quote
Old 05-19-2014, 04:08 PM   #2944
AVOturboworld
Follow up on that - they made a video as well of Ross there:
[ame="https://www.youtube.com/watch?v=NS0Uy3Danak"]AVo Turbo World Japan Installation tokomunitas 86 Jakarta - YouTube[/ame]
Old 05-21-2014, 12:59 AM   #2945
Revzyuu
Drives: GBP '15 STI
Loving the kit I bought just a week ago. My only issue is that my Intake pipe to the turbo will not stay after a good amount of pulls. Everytime I stop I find myself looking under the hood to make sure it hasnt moved much or any at all. Is there a way to correct this? I've tried getting it as flush as possible and still have issues with it slowly slipping off.
Revzyuu is offline   Reply With Quote
Old 05-21-2014, 01:04 AM   #2946
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
As long as you get the pipe on as far as it will go and you get the clamp on straight, it should be fine. I ended up using a t-clamp and I haven't noticed any movement since. There is no positive pressure on that hose so there isn't much danger of it popping off unless the intake pipe coming off the air box is leveraging it
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 05-21-2014, 01:08 AM   #2947
Astroboy
Astroboy's Avatar
Drives: None
Has anybody hit over 400hp yet w/ this awesome kit yet?
Astroboy is offline   Reply With Quote
Old 05-21-2014, 01:08 AM   #2948
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@DesertFrs
Sent from my IBrick
Old 05-21-2014, 01:14 AM   #2949
Revzyuu
Drives: GBP '15 STI
Interesting...I'll find and buy one and give it a shot. Getting ready for a road trip and seeing that over the past few days didnt give me a good vibe. Thanks for the help
Old 05-22-2014, 10:49 PM   #2950
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
I hit past the 410whp and 356wtq mark last month on my 5th tune by @DeliciousTuning and that's with a stock air box at 16psi. Doing small modifications to the car right now to take it back for another tune. Still waiting to have my numbers confirmed on a Dyno-Jet or Dyna-Pack, as my tune was done on a Maha-Dyno.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following 3 Users Say Thank You to DesertFrs For This Useful Post:
Draco_PR23 (05-22-2014), SkAsphalt (05-23-2014), Sportsguy83 (05-22-2014)
Old 05-22-2014, 11:55 PM   #2951
qtwre
Drives: White FR-S
Just installed the avo breather tank this evening. Removing and replacing the PCV valve was a major pain. My deep sockets were too long and would get stuck under the intake manifold.
I hope I routed the hoses properly. The instructions are OK but could be more specific.
qtwre is offline   Reply With Quote
Old 05-26-2014, 03:37 PM   #2952
protpibe
protpibe's Avatar
So add me to the list of leaking header gaskets. It was initially installed with Grimmspeed gaskets but done before the support bracket shimming post was made. Everything was torqued and re-torqued after heat cycling a few times. I'm thinking maybe the header warped in that time without the spacer on the bracket? I've recently switched to OEM gaskets but the leak came back, I'm guessing due to warpage from the initial install. I'm currently awaiting word from Paul on the fix, but I'm thinking I may just get the header flanges planed to see if that will fix it. The small noise it makes honestly drives me nuts. Maybe I have OCD or something but I can't drive with my windows open with it leaking even a little bit
I'll post up results on how I get it fixed
Old 05-26-2014, 03:59 PM   #2953
onzippy
Drives: 2014 FRS
Hey Protpipe,
What kind of mileage on the turbo? I'm about 2,000 miles using the gaskets from AVO but I'm not sure the difference between them and the Grimmspeed. The Avo gasket looks more substantial than the OEM but didn't need the spacer on the turbo bracket. Maybe try getting those from Paul now that they're supplied with the kits.
Gawd.. what a PITA is was installing the manifold, alone, without a lift. I hope mine don't leak.
BTW How do you tell where the leak comes from? I mean, do you get under there and listen by the manifold, then listen by the turbo then listen by the overpipe etc...?
Good luck with the repair.
onzippy is offline   Reply With Quote
Old 05-26-2014, 04:03 PM   #2954
protpibe
protpibe's Avatar
Originally Posted by onzippy View Post
Hey Protpipe,
Yeah I'm thinking avo gaskets may be part of the fix, but also if the header is already warped, I'm thinking I will need a new header. Not sure what effect the AVO header studs would have, but they now offer those on their website too.
The leak is pretty clear once you stick your head under the car
That was about 3 weeks ago I think, about a week after I had the OEM gaskets installed. I'm sure it's much worse now.
edit: Oh, and I have about 4,000km on the kit now.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
