#1191 |
@KraftWerks has the shipment of C38 couplers arrived yet?
#1192 |
Drives: 1st RBv2 10 Series FRS
U can add me to the list. Ordered may 21, 2014
#1194 |
Drives: 2013 BRZ Premium Dark Gray Metallic
So, here I am so far with @moto-mike e-tune for my @KraftWerks kit. This is on 93 crap gas. Just finished installing his Flex-kit and will log and see what I can make.
#1195 |
Just received his kit as well, but I got it without the tune. Delicious is going to be doing that. Without having installed it yet, it seems like a very well put together kit.
| The Following User Says Thank You to SPCorBUST For This Useful Post: | 86SPEED (05-25-2014) |
#1196 |
Drives: 2013 AT Firestorm FRS
So you got it w/out EcuTek, and then you purchase the EcuTek through Bill at DT? Is it cheaper that way?
#1197 |
Well it's cheaper without the tune, yes, but you can't run it without one. Since I'm getting a full custom tune anyway, it doesn't make sense to purchase it with a tune, as Bill already said he can take care of that and Mike confirmed.
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#1198 | |
#1199 |
Yes, I have AAA, so it will be free for 100 miles, but they're only about 65 from my home or work.
#1200 |
Drives: A bunch of 'em...
First track day yesterday.
Holy oil temps batman! 275 F on a stock car while squeezing it out on track - :O 220 F on the highway - double :O Here's what I want to know: For those of you that run the C30 without an oil cooler, what where your oil / coolant temps before and after the install and how do you use your car? THANKS! |
#1201 |
Does anyone know if the Perrin engine oil cooler fits along side with this kit? Looks like a tight fit.
#1202 |
Drives: 2013 BRZ Limited
If you remove the grill you can fit one in front (obviously) but it seems the best place is behind the passenger side fog light, and removing that light for air flow
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
#1203 |
also, for you guys that haven't installed yet, check out these threads:
http://www.ft86club.com/forums/showthread.php?t=62709 http://www.ft86club.com/forums/showthread.php?t=62562 http://www.ft86club.com/forums/showthread.php?t=46456 if you haven't already, I highly recommend you clamp these hoses. It's almost guaranteed they will pop off at about 9.5-10psi. (just dealt with this myself and it would have been easier to do before the kit install) |
| The Following User Says Thank You to NCItaly For This Useful Post: | Taino-BRZ (05-26-2014) |
#1204 |
thanks but do u know if the oil filter, and the sandwich plate will clear the charger bracket and plate? i can mount the cooler np, just wondering if it clears the charger bracket.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
