Old 05-23-2014, 11:27 PM   #1191
SPCorBUST
SPCorBUST's Avatar
@KraftWerks has the shipment of C38 couplers arrived yet?
SPCorBUST is offline   Reply With Quote
Old 05-24-2014, 09:51 PM   #1192
zERoTu
Drives: 1st RBv2 10 Series FRS
U can add me to the list. Ordered may 21, 2014
zERoTu is offline   Reply With Quote
Old 05-24-2014, 10:40 PM   #1193
TmP
TmP's Avatar
Drives: A bunch of 'em...
Who got his blower? This guy.
TmP is offline   Reply With Quote
The Following User Says Thank You to TmP For This Useful Post:
Freeman (05-25-2014)
Old 05-25-2014, 01:08 AM   #1194
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
So, here I am so far with @moto-mike e-tune for my @KraftWerks kit. This is on 93 crap gas. Just finished installing his Flex-kit and will log and see what I can make.
zoth is offline   Reply With Quote
The Following 2 Users Say Thank You to zoth For This Useful Post:
Calum (05-25-2014), glamcem (05-26-2014)
Old 05-25-2014, 01:19 AM   #1195
SPCorBUST
SPCorBUST's Avatar
Just received his kit as well, but I got it without the tune. Delicious is going to be doing that. Without having installed it yet, it seems like a very well put together kit.
The Following User Says Thank You to SPCorBUST For This Useful Post:
86SPEED (05-25-2014)
Old 05-25-2014, 01:50 AM   #1196
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
So you got it w/out EcuTek, and then you purchase the EcuTek through Bill at DT? Is it cheaper that way?
chiefshayan is offline   Reply With Quote
Old 05-25-2014, 01:59 AM   #1197
SPCorBUST
SPCorBUST's Avatar
Well it's cheaper without the tune, yes, but you can't run it without one. Since I'm getting a full custom tune anyway, it doesn't make sense to purchase it with a tune, as Bill already said he can take care of that and Mike confirmed.
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
Old 05-25-2014, 02:05 AM   #1198
chiefshayan
So you're towing the car to San Diego?
Old 05-25-2014, 02:27 AM   #1199
SPCorBUST
SPCorBUST's Avatar
Yes, I have AAA, so it will be free for 100 miles, but they're only about 65 from my home or work.
Old 05-26-2014, 09:23 AM   #1200
TmP
TmP's Avatar
First track day yesterday.
Holy oil temps batman!
275 F on a stock car while squeezing it out on track - :O
220 F on the highway - double :O
Here's what I want to know:
For those of you that run the C30 without an oil cooler, what where your oil / coolant temps before and after the install and how do you use your car?
THANKS!
Old 05-26-2014, 09:48 AM   #1201
zERoTu
Does anyone know if the Perrin engine oil cooler fits along side with this kit? Looks like a tight fit.
Old 05-26-2014, 11:13 AM   #1202
NCItaly
Drives: 2013 BRZ Limited
If you remove the grill you can fit one in front (obviously) but it seems the best place is behind the passenger side fog light, and removing that light for air flow
NCItaly is offline   Reply With Quote
Old 05-26-2014, 11:29 AM   #1203
NCItaly
also, for you guys that haven't installed yet, check out these threads:
http://www.ft86club.com/forums/showthread.php?t=62709
http://www.ft86club.com/forums/showthread.php?t=62562
http://www.ft86club.com/forums/showthread.php?t=46456
if you haven't already, I highly recommend you clamp these hoses. It's almost guaranteed they will pop off at about 9.5-10psi. (just dealt with this myself and it would have been easier to do before the kit install)
The Following User Says Thank You to NCItaly For This Useful Post:
Taino-BRZ (05-26-2014)
Old 05-26-2014, 11:43 AM   #1204
zERoTu
thanks but do u know if the oil filter, and the sandwich plate will clear the charger bracket and plate? i can mount the cooler np, just wondering if it clears the charger bracket.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
