Old 05-23-2014, 09:40 AM   #477
jflogerzi
jflogerzi's Avatar
Maha. Reads lower than both
What would those numbers translate to on Bill's Mustang dyno
Old 05-23-2014, 09:50 AM   #478
nelsmar
It should be lower than bills mustang... I have never seen a dyno read this low. Stock cars run 125-135 typically around 130.
My flickr - Canibeat
Local magazine scout
Old 05-23-2014, 03:07 PM   #479
CSG Mike
CSG Mike's Avatar
Well, he stated a baseline of 130whp/113wtq.
That would mean the dyno reads at a rate of 35% loss.
At the shown 281/223, that would translate to 432/343 at the crank, based on 130whp being 200hp crank.
On a dynojet, that would be ~367whp (15% loss), or 354whp on a mustang (~18% loss). Approximately of course.
*LongFella (05-23-2014), CxG (04-03-2018)
Old 05-23-2014, 03:17 PM   #480
doberman8u
Drives: 2013 FR-S, 2004 Z06
Originally Posted by nelsmar View Post
I figured I would share a local's kit that I helped tune this week since he isn't on the forum. I wasn't expecting such a large gain from E85! I plotted a stock car in comparison to show how low this dyno reads. Stock car made 130whp/113wtq. Nearly a 135% power gain over stock! There were gains all the way down even at 1,500RPM.
The car has agency power headers, overpipe, i believe catless front pipe, stock midpipe back to the rear of midipe and then twin exit muffler delete.
Is this with stock injectors and pump?
doberman8u is offline   Reply With Quote
Old 05-24-2014, 01:37 PM   #481
nelsmar
Dw700 iniectors dw65c pump. I would have to check the logs to see how close this was to working in oem injectors. I did do a few pulls up to around 7200rpm on completely stock fuel system on e85 before but I don't remember if it was pushing the di time too far or not I would say it's probably on the edge of what i would push in the ever you get e90 and some very cold weather.
Then again if you were to drop the redline just a hair it might be a lot more within oem fuel capacity.
Old 05-24-2014, 10:59 PM   #482
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Stock car reads around low to mid 130's on our mustang if I remember correctly. It's been a long time since we actually had a stock car on there. My car is back to stock for a short time for some NA parts testing so I'll get a base run if you guys care to see what a stock car makes on our mustang :P The Dyno Dynamics down at HG Motorsports we were using for awhile also reads mid 130's for a stock FR-S, BRZ. It's not uncommon for a Dyno Dynamics, Mustang, Maha, just a matter of whether you're running it in true heartbreaker mode or any sort of sim mode. We always prefer the lowest, truest reading and it looks like you do too @nelsmar
Sincerely,
Zach
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
CxG (04-03-2018), nelsmar (05-25-2014)
Old 05-27-2014, 01:16 AM   #483
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Would getting an aftermarket exhaust be a bad idea for the CARB tune kit? I'd like to add a distinctive exhaust note to my car along with other small benefits (weight savings, looks, etc)
Cheeseballs is offline   Reply With Quote
The Following User Says Thank You to Cheeseballs For This Useful Post:
4032pauln (05-27-2014)
Old 05-27-2014, 03:47 AM   #484
1086
1086's Avatar
Drives: UM86 - 6MT
Would you guys say that the Jackson kit is superior to the other CARB legal FI options? I am in California, and I am heavily leaning toward the JR kit. Also, on the carb legal tune it is said there is a ~70 whp increase over stock.
What is the whp increase on a non-carb legal tune/map?
What is the whp increase running E85?
If I buy the kit straight up as it stands + an oil cooler, will I bet set? even if I want to periodically run E85 from time-to-time?
Will whp numbers change with the oil cooler as well?
1086 is offline   Reply With Quote
Old 05-27-2014, 04:17 AM   #485
Raven604
Hey you. Only 1 question at a time. Yes, probably the best carb FI option at this time.
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
The Following User Says Thank You to Raven604 For This Useful Post:
1086 (05-27-2014)
Old 05-27-2014, 04:47 AM   #486
CSG Mike
CSG Mike's Avatar
Catback? You'll be just fine.
*LongFella (05-27-2014), Cheeseballs (05-27-2014)
Old 05-27-2014, 04:49 AM   #487
CSG Mike
CSG Mike's Avatar
Yes. We put our money where our mouth is.
Yes, 70-75whp in full CARB trim is accurate, with zero other mods.
On 91 octane? Rumor has it with supporting mods and a stock engine, you can extract plenty more
With E85 and supporting mods, even higher.
Get flex fuel
You'll sustain the power with an oil cooler; I highly recommend it.
While we're at it, I wouldn't be surprised to see 400whp+ with a built engine and the Jackson Racing kit.
The Following 7 Users Say Thank You to CSG Mike For This Useful Post:
*LongFella (05-27-2014), 1086 (05-27-2014), Cheeseballs (05-27-2014), CxG (04-03-2018), sdlynx (05-27-2014), sklimo (05-27-2014), spitz (05-27-2014)
Old 05-27-2014, 12:59 PM   #488
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Installed my kit this weekend.
Ah-freaking-mazing. It's everything advertised and more. It is, in my opinion, now the perfect DD / Track weapon.
Only small issue I had with the install, as previously stated by other owners, was bumper fitment. The pipes needed some man power to get into place, but this wasn't a big deal at all. Also, if Jackson Racing wanted to make this install completely brainless, they could create a installation guide with BOTH the oil cooler kit and SC kit steps combined. I had to flip back and forth between both kits, but just a suggestion more than a complaint. Install went very smooth.
spitz is offline   Reply With Quote
The Following 4 Users Say Thank You to spitz For This Useful Post:
*LongFella (05-27-2014), 1086 (05-27-2014), CSG Mike (05-27-2014), CxG (04-03-2018)
Old 05-27-2014, 02:19 PM   #489
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
With this kit, should I get the installer to install clamps on the vacuum lines as mentioned on some of the other threads?
Casey10s is offline   Reply With Quote
Old 05-27-2014, 02:21 PM   #490
CSG Mike
CSG Mike's Avatar
Not a single owner has reported having that problem yet, but it certainly won't hurt.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
