go_a_way1
Old 05-20-2014, 10:30 PM   #463
CSG Mike
CSG Mike's Avatar
Originally Posted by oc-drummer View Post
lol that is certainly a distinction I didn't want.
Anyway, is there a possibility of engine damage as a result of the SC dying due to insufficient lubrication? I was coasting to a stop at a red light around 15-20mph when my dash lights came on and the car died. I also did not rev the car above 3k during my brief drive because I was in an urban area and it was raining steadily. No I did not hit any big puddles either.
I worry that the people who are responsible for this mess might blame any additional problems that may arise on the manufacturer or myself.
Check to make sure the charge pipes are connected after the MAF. If your shop messed up the SC line install, I'm not sure I'd trust the rest of the work either; a lot of the owners here DIY the install at home, and the inlet/outlet for Rotrex fluid is clearly marked on the protective covers.
A dying engine will make all kinds of crazy noises, but a disconnected charge pipe after the MAF will make the car just not idle at all, and just stall.
oc-drummer (05-20-2014)
Old 05-21-2014, 01:25 AM   #464
Poodles
Drives: 2015 Series.Blue
Originally Posted by bacon_cheese_beer View Post
the fact that the sc locked due to no oil, there is a very high probability that residue from the torn sc blades may have gotten sucked in your engine. i check your dipstick for metal shards and if the sc is still installed i would check the tubing also. i would change my oil also just incase.
More likely to be trapped in the intercooler.
The Following 3 Users Say Thank You to Poodles For This Useful Post:
CSG Mike (05-21-2014), CxG (04-03-2018), sw20kosh (05-21-2014)
Old 05-21-2014, 03:15 AM   #465
sw20kosh
Drives: 2013 Black FR-S
This.
Engine shutting off when coming to a stop light is probably a vac leak or a fueling issue (tune related). Does the car start right back up? No other symptoms?
Old 05-21-2014, 03:23 AM   #466
sw20kosh
I ugraded my clutch and flywheel knowing I'd be going over 300whp.
Not 100% sure what the stock can handle, but I didn't want to take any chances
I had heard it slips at 230-240 ft lbs. mine started slipping at 220-230 ft lbs. it has nothing to do with whp.
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
CSG Mike (05-21-2014), MAPerformance (05-21-2014), sklimo (05-21-2014)
Old 05-21-2014, 11:55 AM   #467
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Originally Posted by romin View Post
Given the Radium catch can mounts in the same location as the Rotrex Oil Reservoir which one did you relocate and how?
Cheeseballs is offline   Reply With Quote
The Following 4 Users Say Thank You to Cheeseballs For This Useful Post:
CSG Mike (05-21-2014), CxG (04-03-2018), romin (05-21-2014), sklimo (05-21-2014)
Old 05-21-2014, 01:39 PM   #468
nelsmar
I figured I would share a local's kit that I helped tune this week since he isn't on the forum. I wasn't expecting such a large gain from E85! I plotted a stock car in comparison to show how low this dyno reads. Stock car made 130whp/113wtq. Nearly a 135% power gain over stock! There were gains all the way down even at 1,500RPM.
The car has agency power headers, overpipe, i believe catless front pipe, stock midpipe back to the rear of midipe and then twin exit muffler delete.
My flickr - Canibeat
Local magazine scout
The Following 8 Users Say Thank You to nelsmar For This Useful Post:
*LongFella (05-21-2014), Calum (05-21-2014), CSG David (05-21-2014), CSG Mike (05-21-2014), jflogerzi (05-21-2014), JonAvalon (05-21-2014), sklimo (05-23-2014), sw20kosh (05-21-2014)
Old 05-21-2014, 05:20 PM   #469
CSG Mike
CSG Mike's Avatar
People have difficulting believing me when I say that you have a power gain from idle on up.
Do you happen to have a dyno comparing the REALLY low RPM ranges? I know it's not typical due to lugging, but it's nice to have
Old 05-21-2014, 05:30 PM   #470
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Is anyone that's running E85/FlexFuel with this kit running out of injector capacity or fuel flow with the OEM fueling gear and E85? Is it ok to run without a higher flow pump in the tank and bigger injectors assuming the original 9psi pulley is used?
I thought that a new pump/injectors were needed or strongly recommended to run E85 with the C30-94. @moto-mike can you clarify?
Old 05-21-2014, 06:06 PM   #471
nelsmar
Next time I am at my friends shop I can grab a plot. The dyno window started at 1,500RPM.
The Following User Says Thank You to nelsmar For This Useful Post:
Old 05-21-2014, 09:08 PM   #472
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We've gone up to 12-14 psi on e85 on stock fueling. Pump is good to have, injectors good to have as well. With the DI/PI combo you can hit 300 wheel HP on e85, but there's nothing wrong with the extra headroom the 700cc injectors and high flow fuel pump provide.
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
ATL BRZ (05-21-2014), PikachuBRZ (01-20-2023)
Old 05-21-2014, 09:31 PM   #473
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
So for us amateurs (me), running stock fuel pump and injectors is fine? If we want north of 300 hp, upgrade the pump and injectors?
I'm really liking the numbers posted. Full exhaust set-up, E85, stock fuel pump and injectors... Great numbers!
So glad I went with this kit!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 05-21-2014, 09:35 PM   #474
Cheeseballs
Drives: Really slow
Originally Posted by normancw View Post
@Cheeseballs
That looks great! Where did you get the mounting bracket - is it custom made?
It's just the driver side bracket that comes with the dual catch can kit. It's been cut down to accommodate the reservoir. You would just need to fab the small piece that connects the bracket to the chassis.
The Following User Says Thank You to Cheeseballs For This Useful Post:
Old 05-23-2014, 12:03 AM   #475
jflogerzi
jflogerzi's Avatar
Mustang Dyno or dyno jet?
Old 05-23-2014, 02:11 AM   #476
CSG Mike
CSG Mike's Avatar
Maha. Reads lower than both
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
