I love peanut butter
Drives: 2013 SWP BRZ Limited
Will OEM camber bolt install affect alignment
Can I install these without affecting my alignment?
I installed Eibach Pro-Kit sorings recently and had my car aligned. I was wondering if I can put these bolts in to get more negative camber without messing up the toe. I'm thinking no, but thought I'd ask since I don't know if toe would be affected by this. I know, I know, I should have put these in before my alignment.
#2 | |
AutoX Nut
Drives: 2020 Toyota Supra
#3 |
Drives: '13 BRZ Ltd
In my experience the camber bolt changed the toe alignment very little, if at all. IMO definitely not enough to require another alignment. YMMV. Obviously, if you put them in and it drives oddly then you'll need to get it aligned.
#4 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Yes it will affect it.
#5 | |
[/thread] |
#6 |
PROUD OF BOXER
Drives: Raven FR-S
i had the alignment checked before and after. no change.
edit: for reference, i have rs-r superdowns
#7 |
The toe change with OEM camber bolts is pretty minimal. It will toe in slightly, but not enough to ruin tires. I think it was about 1/16" toe-in for each degree of camber added per side.
So, get the camber bolts, max negative camber and get 1/8" toe in. |
#8 | |
Here's my alignment results |
#9 |
Turbo 86
Drives: GT86
it woult last too long with oem bolts
10 - 1 = 0
real math |
#10 |
Drives: 2012 Toyota 86
I have camber bolts installed in both holes, and rsr super downs. Drives strait, and no abnormal wear after a couple thousand kilometers.
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Alignment needed after front camber bolt install? | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-31-2013 12:13 AM |
| Whiteline Camber bolt install | TimR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 06-06-2013 08:33 AM |
