Old 05-23-2014, 10:41 PM   #1
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
transmission grind in 5th gear
Hi guys I am having an issue with 5th gear grinding. My car has several transmission modifications. Fluid change, short shifter, bushing, aftermarket clutch. Does anyone have any further information on this issue? and yes, I'm aware of the other thread regarding 5th gear.
Thank You in advance!
Rocket.BRZ is offline   Reply With Quote
Old 05-28-2014, 07:47 AM   #2
Rocket.BRZ
Switching out the fluid to potosin mtf today. Hopefully this fixes the issue.
Old 05-29-2014, 05:45 PM   #3
Rocket.BRZ
Just swapped my fluid over with pentosin and half a bottle of lucas transmission fix. No more grinding in 5th gear and its pretty smooth compared to before. I will update this post when I get some miles on it.
OK the grind is back. I wonder if the Lucas transmission fix has something to do with that
Does anybody have some suggestions? Maybe switch to Redline?
Old 06-02-2014, 11:59 PM   #4
treystarks
treystarks's Avatar
Drives: 2013 Firestorm FR-S
Are you still in warranty?
Sent from my SAMSUNG-SM-N900A using Tapatalk
treystarks is offline   Reply With Quote
Old 06-03-2014, 05:18 AM   #5
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I'm going to go out on the limb and say everyone has this problem. I assume you are talking about when downshifting or upshifting into fifth at relatively high speeds (65-70). Some people have gotten a whole new transmission but in the end I am sure the problem won't go away. Just shift slower into fifth gear, that's the way I learned from it. I swapped from Pentosin Transmission fluid and Motul differential and honestly I don't remember if it helped but it definitely doesn't go away.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following User Says Thank You to l0aded For This Useful Post:
Rocket.BRZ (06-03-2014)
Old 06-03-2014, 07:35 AM   #6
Rocket.BRZ
Yea I have seen improvement with the pentosin and I have learned to be very gently sliding into 5th gear. The rest I like be a bit rough but she must be a special gear
Old 06-16-2014, 07:39 PM   #7
_j_anthony
Daily Driven Expert
_j_anthony's Avatar
Drives: FR-S Monogram(BLACK)
not 5th but 2nd gear
I had grinding with my second gear while my foot was on the clutch, happened twice in the first 400 miles. I'm at 1,260 and haven't had an issue recently.
_j_anthony is offline   Reply With Quote
Old 06-30-2014, 10:38 PM   #8
Rocket.BRZ
Originally Posted by Sleeperz View Post
FREE STUFF!
Purchased a new car? Want to make it faster, stronger and better? Contact us for free performance parts for your new vehicle. We will take care of the engineering of the parts to make your car fast! We like to stay ahead of the curve when it comes to new performance opportunities for new late model vehicles. If we choose your car as the 'test mule' for our new performance products, all parts will be designed and installed with a full warranty for FREE! We have the equipment, engineering skill, and connections to make any part for any vehicle and any application. Anything from turbo to exhaust to transmission to engine modification. With our equipment and talented people, you can have some of the nicest parts in the industry for $0. The reason for this is we would like to offer more performance oriented parts for new late model vehicles built by us. If we build the prototypes for you at no charge, it will benefit all of us! Don't pass up on this rare opportunity!
http://www.jackstransmissions.com/
still looking for a test car?
transmission, transmission grinding
6th Gear Grind & Replaced Transmission Bonburner Issues | Warranty | Recalls / TSB 45 07-30-2016 11:08 PM
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 09:39 PM
transmission grind jbailey8748 Engine, Exhaust, Transmission 26 05-18-2014 09:32 PM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 11:50 AM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
