Old 05-23-2014, 04:58 AM   #29
Lemar58
Drives: Scion FR-S
Originally Posted by ScionFrsFan View Post
Side question: Ahhh first day on the juice and for the hell of it, I tried some 0-60 runs.
Yes I have a automatic, but 0-60 was 6.9-7 sec? Yes that is faster, but it seems with a reported 25-30 extra hp. It should be faster than that?
Did you give your Ecu enough time to learn the flash. Usually takes about 80 miles before I start driving hard...
Lemar58 is offline   Reply With Quote
Old 05-23-2014, 05:18 AM   #30
s2d4
s2d4's Avatar
Truth is no one knows 100 % with this car as E85 tune have only been out maybe a year or so, some guys run e85 full time and have clocked up maybe 20 or 30k miles on e85 with no obvious effects. However who knows the long term issues after five years or more, its looking ok but no guarantees.
Any mod you make that increases power theoreticly increases loads and stresses and pushes engine and other components further from their designed and tested limits, its a risk you have to accept if you modify anything
Although it does run a lot cooler and with DI, not entirely sure that it would actually under more stress for NA applications.
We've all seen loads of knock in hot weather on gas, especially on stock tune, surely this has to be a lot worse than running cooler instead?
Old 05-23-2014, 06:02 AM   #31
steve99
Drives: FT86
agree, was more going down the line of general mechanical stresses with mods more power more load ect or hey i put in a super heavy clutch no more slip but it causes gearbox failure due increased shock load a few weeks later
although knock is probably the worst kind of loadfor an engine
s2d4 (05-23-2014)
Old 05-23-2014, 10:39 AM   #32
ScionFrsFan
No, I didn't give it 80 miles before going wot. Is 7 sec normal for a auto with e85?
In addition, now what? Besides aftermarket headers and FI, there honesty doesn't seem to be any way to really gain anymore real power.
Intakes seem like a waste and the little you might gain from an exhaust doesn't seem worth all the noise lol.
Thank!
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 05-23-2014, 10:50 AM   #33
MAPerformance
Drives: Asphalt FRS
The real question is how are you measuring your 0-60 runs?
MAPerformance is offline   Reply With Quote
Old 05-23-2014, 10:53 AM   #34
ScionFrsFan
Just using the torque app; way out on some deserted county roads. I did the same with the unichip using the most aggressive tune + some torco, my times were a tad faster than 7. I believe stock is 8 sec. I understand the car wasn't designed to be "fast", but I was hoping for mid 6's with e85.
ScionFrsFan
Old 05-23-2014, 11:28 AM   #35
DAEMANO
Time Traveller
0-60 is a poor indicator of performance because it relies so heavily on a great launch, tarmac and tire temps, atmospheric conditions, etc. Also, you have an automatic which have pretty consistently reflected nearly a full second slower to 60 than the 6MT.
Better performance metrics are 5-30, 30-60, 50-90 or even 90-120, anything from a roll in real world driving conditions. On a track do you ever acellerate to 60 from a full stop? AutoX maybe.
Don't get too worked up about 0-60. Third gear is where all the fun is anyhow, and especially on e85.
The Following User Says Thank You to DAEMANO For This Useful Post:
ScionFrsFan (05-23-2014)
Old 05-23-2014, 11:40 AM   #36
MoogDiesel
Just some guy...
MoogDiesel's Avatar
Drives: BRZ, FozXT
2nd tank.....I CAN'T GO BACK!! DON'T MAKE ME GO BACK!!!.....stock+Tomei 80 CBE. OFH on the way.
2013 BRZ Limited - Current #mizu
2014 Forester XT Touring - Current #kaji
2009 STI - Stage 2 - Sold #subanetta
2005 Audi A4 Quattro - Sold
2003 SRT4 - Sold
MoogDiesel is offline   Reply With Quote
The Following User Says Thank You to MoogDiesel For This Useful Post:
Shiv@Openflash (05-24-2014)
Old 05-23-2014, 11:48 AM   #37
ScionFrsFan
haha. Does it get any better on second tank?
ScionFrsFan
Old 05-23-2014, 12:39 PM   #38
MoogDiesel
Just some guy...
MoogDiesel's Avatar
Drives: BRZ, FozXT
Depending on how much 91/93 was left in the tank on initial fillup then yes it can.
2003 SRT4 - Sold
Old 05-23-2014, 01:29 PM   #39
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
Been running e85 for a while now. Never had a problem. Cold start is fine. I live in Florida though. Dynod 193whp completely stock except for e85 and Borla axel back.
TruRace is offline   Reply With Quote
The Following User Says Thank You to TruRace For This Useful Post:
DC2R (08-09-2014)
Old 05-23-2014, 10:32 PM   #40
86viper
Drives: 2013 Toyota 86 GTS
Also running the E85 here in Aussie land. Zero problems after more than 12000km on it. I do use the lucas ethanol treatment just to be sure though, as do a fair few of the e85 users here.
86viper is offline   Reply With Quote
The Following 2 Users Say Thank You to 86viper For This Useful Post:
ScionFrsFan (05-24-2014), steve99 (05-23-2014)
Old 05-24-2014, 11:29 AM   #41
ScionFrsFan
So far so good! Seems to be getting stronger, but I'm guessing that is because I'm losing the weight from the gas I'm burning up lol. Waiting till close to empty to try and make this next tank closer to 100% of e85....From my understanding as long as your above E50 or so, once the ecu adjust there shouldn't be a difference over e85?
PS: NO hard starts!!! Sadly even though its may 26; the Chicago-land area last night was in the high 40's and the car started up just fine. Curious if it could handle the winter though....
THANK YOU!!!!!
ScionFrsFan
The Following User Says Thank You to ScionFrsFan For This Useful Post:
Old 05-24-2014, 11:34 AM   #42
ScionFrsFan
I FEEL THE SAME WAY NOW! I can't imagine what the car would feel like back on the stage 1 tune, or even worst using the stock tune lol. Stock always felt okay, at times it felt "quick", but now e85 has ruined me forever!
ScionFrsFan
Open Flash Tablet Help :( ScionFrsFan Software Tuning 29 05-20-2014 12:26 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 05:03 PM
WTB: Open Flash Tablet Hotlava86 Engine, Exhaust, Bolt-Ons 1 03-19-2014 01:25 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
WTB: Open Flash Tablet CreinCrein Engine, Exhaust, Bolt-Ons 1 01-29-2014 12:55 PM
