Tracking / Autocross / HPDE / Drifting What these cars were built for! |
#15 |
My VTEC fluid is full
Drives: EFF JAY
Did you take temp readings? I have remote canisters (on a different car) and it is also by the engine, although not as close as yours.
#16 |
Drives: Some rust bucket
Here's a pic of the R2's similar mounting location.
#17 |
After driving pretty hard the drivers side one isn't even warm in any way. The passenger side canister gets a little warmer but not much. I guess I can get out the pyrometer tomorrow and check them before and after driving. The engine itself doesn't really give off enough heat n that area to make a difference but the passenger side sits above the exhaust.
#18 | |
I'm not worried about it but if someone was you could certainly use some reflective tape or heat blanket material around them. |
The Following User Says Thank You to xwd For This Useful Post: | iLuveKetchup (03-14-2013) |
#19 |
Drives: 2013 FRS/2011 TDI
This setup looks amazing...
#20 |
Drives: 13 CSB BRZ Ltd
Any updates?
#21 |
Drives: '13 Argento 6MT FR-S
@dwx: Any longer-term updates to what you've said above? These are beautiful.
#22 |
Look just as good and work just as well as when I installed them 9 months ago. I've re-mounted the canisters onto the Grimmspeed front strut bar, that's about it.
I am getting ready to take them off the car to get them re-valved for higher spring rates and a couple other changes since I'm moving to STX next year. |
The Following User Says Thank You to xwd For This Useful Post: | Anthonytpt (11-14-2013) |
#23 |
@dwx: Did you end up re-valving for higher spring rates? If so, how's that working in STX for you?
#24 |
Junior
Drives: a car
hey @dwx do you have shock dyno's of these?
#25 |
I have them printed somewhere I will see if I can find them.
#26 |
Drives: whiteout
what kind of sway bar or front endlink are you using? my mcs with whiteline front end link and stock sway bar binds like crazy. I need to find someone that produces shorter endlinks. a lot of popping sounds from the front turning
#27 |
I am using the WL front bar with WL end links. I've used the Strano bar as well, never had any issues. I have never tried the stock bar with different end links.
#28 |
Junior
Drives: a car
Update on those shock dyno's
Basic tech info: spring rates, rear suspension, motion ratios, and you. | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 07-08-2022 02:56 PM |
Motion Control Suspension Singles---SCCA Stock legal are done! | Sam Strano | Tracking / Autocross / HPDE / Drifting | 25 | 01-16-2013 02:42 PM |
Deft Motion | Suspension Specials | Deft Motion | Brakes, Suspension, Chassis | 4 | 07-12-2012 02:48 PM |
