Old 05-19-2014, 12:33 AM   #1
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Oft e85 issues
On cold starts i get popping nosies coming from engine and rpm jumps around, and boggs. Didnt have this issue until switched to e85 with oft tune.
Mods:
Light crank pulley
Injen intake
Headers
Over pipe
Cat delete
Cat back exhaust
Third tank of e85 started happening since 2nd tank. Wondering if i should be worried.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 05-19-2014, 12:51 AM   #2
Lytheum
Drives: 2013 BRZ Premium 6MT
i get some popping on cold starts. seems to happen more when its cooler out. i usually just tap the gas pedal after i hear the first pop and they stop.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
The Following User Says Thank You to Lytheum For This Useful Post:
sosick (05-19-2014)
Old 05-19-2014, 01:55 AM   #3
Tromatic
"sick ass ultramarine frs"
Seems it's sick.
The Following 4 Users Say Thank You to Tromatic For This Useful Post:
86-tundra (05-22-2014), Annahra (05-19-2014), sosick (05-19-2014), was385 (05-19-2014)
Old 05-19-2014, 02:09 AM   #4
steve99
Drives: FT86
If it only happens during initial startup in first 15 sec or so its probably ok on a cold morning like 30f .
If its a warm day and its happening after startup then thats not sounding too good look up di seal failure
If your original rom calid was 700 900 or a00 series then the transient knock retart which helps with di seal problems was not implempted it started on a01 and above series roms ie a01c.
Oft tines incorporate it.
Old 05-19-2014, 02:27 AM   #5
sosick
fastest frs in sbg
sosick's Avatar
Yea usually around 30f start ups
2014 firestorm frs
Old 05-19-2014, 02:27 AM   #6
sosick
fastest frs in sbg
sosick's Avatar
Just initial start up. It dont sound good at all.
2014 firestorm frs
Old 05-19-2014, 03:33 AM   #7
steve99
Drives: FT86
If its only on cold morning startup on e85 its fine
Old 05-19-2014, 11:05 AM   #8
sosick
fastest frs in sbg
sosick's Avatar
Good
2014 firestorm frs
Old 05-21-2014, 07:12 AM   #9
bfrank1972
Drives: 2013 FR-S Argento
It's fine , misfire when engine is cold causes small burps and backfires in intake manifold, that's the popping sound. Add a gallon of gas to your tank might help.
The Following User Says Thank You to bfrank1972 For This Useful Post:
Luckrider (05-21-2014)
Old 05-21-2014, 08:57 AM   #10
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
This is what the issue is. It is normal and happens in stupid cold weather with e10.
Luckrider is offline   Reply With Quote
Old 05-21-2014, 10:01 AM   #11
sprintamx
I'm on my second tank of E85. Each time I start the car for the first time in the morning, the motor starts reluctantly and then cuts out. It starts on the second try, stays running, and there do not seem to be any performance issues. It's not cold in the mornings or overnight, and the car has been garaged.
Typical, or concerning? I'm running the latest Stage 2 E85 EL bin.
sprintamx is offline   Reply With Quote
Old 05-21-2014, 01:38 PM   #12
wparsons
wparsons's Avatar
I actually get some mild misfiring and popping on e0 when it's REALLY cold out (like -20*C), both the stock ROM and OFT stage 1.
flickr
Old 05-21-2014, 04:31 PM   #13
SilverFoxBRZ
BRZ Jockey
Drives: 2013 BRZ LTD 6MT Sterling Silver
I recently started checking and logging Ethanol percentages too see if there is a correlation between performance and mixture. I recommend everyone on E85 does this. The federal allowable range is 51-83% and I can't believe that even a conservative tune will run as well towards the lower end of Ethanol concentration when compared to 70%+.
SilverFoxBRZ is offline   Reply With Quote
Old 05-21-2014, 06:14 PM   #14
steve99
Drives: FT86
Shiv explains it here pretty well. In short ecu will adjust fuel trims to compensate for E% within those ranges E60-E90. Even E50 will have enough octane rating to prevent knock with timing used on a NA FA20 motor.
http://www.ft86club.com/forums/showthread.php?p=1389932
Oil issues with my avo brz...help!!!!! brz2013 Forced Induction 22 10-19-2016 11:03 AM
Anybody Have Zero Issues? Don Ivey Scion FR-S / Toyota 86 GT86 General Forum 129 03-25-2013 01:14 PM
91 Octane issues? tokiokun717 Northern California 17 02-01-2013 02:21 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 08:15 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 03:41 PM
