Old 05-17-2014, 02:13 AM   #2367
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Originally Posted by drewbot View Post
Perhaps it's a camber and fitment question, but currently I have 17x8 +48's on stock Michelin 215 Primarcy's up front.
I want to go up to 235/40, but am concerned about rubbing with -1 or -1.5 camber on stock suspension. It appears that this is OK, but bumping my question anyhow.
If I understand correctly, you could fit 265 and not rub on stock suspension, perhaps someone can chime in
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 05-17-2014, 12:52 PM   #2368
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
If we use the fitment of 17x9 +35 with 235/40/17 which is said to fit with no rubbing, then it looks like 235/40/17 on 17x8 + 48 is almost as close to the strut.
From willtheyfit:
Compared to your existing wheel, this new wheel will have an inner rim which is 0.3mm closer to the suspension strut. The outer rim will poke out 25.7mm less than before.
drewbot is offline   Reply With Quote
Old 05-19-2014, 06:05 PM   #2369
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Sigh.. I think I know the answer to this, but I'm holding onto a kernel of hope that I'm wrong..
I have run a set of 265/35-18 on 18x9.5+38 wheels on my BRZ already. Camber is -2.4F, -2.2R. The fronts only rubbed at full lock, and the rears only rubbed at that little plastic fastener between the bumper and fender.
Unfortunately, I can't continue to use those wheels because they don't clear my new brakes.
So now, here's the big question:
How much of a headache would I be in for if I go to a 18x10+30 wheel?
...and I really don't want to add any more negative camber.
FRS Project looks promising, but I'm just not sure.
Old 05-20-2014, 10:23 PM   #2370
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Originally Posted by Marchy View Post
quick question, I'm currently riding on 17x9 et42 with 245/40 squared PSS. I'm looking to drop my car on some RCE yellows (should be a 0.8" to 1") drop. Am i going to run into any issues rubbing.
Saw someone selling the same wheels saying he needed 3mm spacers to clear his struts when he was lowered on eibach pro-kit which is about 1.2" drop.
thanks,
Lowering your car does not affect the front camber.
In any event, it appears that setup may rub depending on your camber situation
Old 05-21-2014, 03:59 AM   #2371
meeks
slide to unlock
meeks's Avatar
Drives: 2013 FR-S Raven Black
Pic request please:
17x9 +42 to +30 on 235/40 dropped on prokit, please
meeks is offline   Reply With Quote
Old 05-21-2014, 03:20 PM   #2372
s13Henry
s13Henry's Avatar
Drives: Black BRZ/Black S13 Silvia
Got 18x9 18x10 +4. My thoughts on tire size are 215/35 225/40. Will it fit?
s13Henry is offline   Reply With Quote
Old 05-21-2014, 10:09 PM   #2373
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by gl2filmerguy View Post
I'm looking to get 18" Work Meister S1's. I am going to be lowering my car at LEAST 1-1/2". I would like to get it "Flush" more than having it poke out and look odd. Can someone please help me with what offsets I should get for front and rear? THANK YOU!!
Been away from this thread for a while (busy) but will try to help.
What widths and offsets are available for the S1's?
Slick is offline   Reply With Quote
Old 05-21-2014, 10:12 PM   #2374
Slick
Slick's Avatar
Originally Posted by Gt86_nick View Post
So after looking around I had a change of heart from the bbs' don't really want to put that much into a lease. I'm currently looking at a pair of work xd9s 18x8. I had read here that +34 would make me flush but I was playing around on the auto fitment calculator here and the +35 option looks to be a little tucked still it looks like the +28 option would make it flush. Also I plan on lowering on h&r super sports -1.2f and -1.6r drop
It all depends on your camber settings. With your drop and no camber bolts, you should end up at around -1.5 already. I'd go with something close to +35. The +28 will poke, at least on the fronts.
Old 05-21-2014, 10:17 PM   #2375
Slick
Slick's Avatar
Originally Posted by cncnjn View Post
I was looking at wheels, my car is lowered about 1in 1/2 all around, the wheels im looking at are 18x9.5 with either +30 or +38 offset, which one would give me a better flush fitment? Should i go +30 in front +38 in back? Vice versa? Let me know, thanks.
Vice versa so +38F, +30R would work, but I'd just go with +38 all around.
If lowered on springs, then clearance up front will be close to the perch, coilovers no issue. Proper camber is key.
Old 05-21-2014, 10:28 PM   #2376
Slick
Slick's Avatar
Its a 13mm difference in offset (inward) from stock wheel/tire and with the extra camber a bit closer. I think you should be just fine.
If you have the stock tires on these wheels already, then just measure the inside gap to the spring perch. The 235/40 will be almost an inch wider than the 215's, so 1/2" on each side wider than stock. Everything else remains the same since you are keeping the same wheel and camber right?
The Following User Says Thank You to Slick For This Useful Post:
drewbot (05-21-2014)
Old 05-21-2014, 10:35 PM   #2377
Slick
Slick's Avatar
Your question is better directed at those in this thread:
http://www.ft86club.com/forums/showt...25171&page=103
But it looks to me like you're adding about 14mm more poke.
Old 05-21-2014, 10:40 PM   #2378
Slick
Slick's Avatar
thanks,
Hi Marchy!
I'd check how much clearance to the spring perch you have with your current setup first. You're getting lower, which will add camber but some guys are already running 17x9 +45 for the track with the same size tire. I'd say if you have 8-10mm clearance now, you're probably okay.
You can always take some negative camber back out if needed, just make sure to do it with eccentric camber bolts, not crash bolts.
Marchy (05-22-2014)
Old 05-21-2014, 10:44 PM   #2379
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Yeah good point. I can fit a finger and a bit between the wheel and the strut, but can't fit two fingers (that's what she said)
Old 05-21-2014, 10:56 PM   #2380
wallace03
wallace03's Avatar
Drives: WRB BRZ
Will this combo work for me without any issue:
-Gramlights 57xtreme 18x9.5 +40 offset
-245/35 Tires
-ST coilovers
From what i've seen it should work, just want to double check. Also, any recommendations for affordable performance tires?
wallace03 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
