Old 05-20-2014, 02:31 AM   #1079
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Does any one else have dyno sheets to post up? I would really like to add hard numbers to the first post.
Here is a dyno sheet of the tune refining @Drift-Office did on my car last weekend with an overlaid with the December tune. In December the temps were around 40* and this past weekend it was around 70*. Bob and Bill drug another couple HP out of it with the higher temps and did it with even less boost! My car feels absolutely amazing! Hope everyone else is seeing similar results. If you live anywhere within driving distance of Seattle I suggest you make the trip to Drift Office for a tune.
digital_assassin is offline   Reply With Quote
The Following 3 Users Say Thank You to digital_assassin For This Useful Post:
Calum (05-20-2014), Freeman (05-20-2014), glamcem (05-20-2014)
Old 05-20-2014, 03:08 AM   #1080
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by post_break View Post
How did you get the intake manifold off? Is there a guide because it looks complicated as hell. I saw you could somewhat get to them by moving the AC but that's not easy with the SC installed.
Originally Posted by zoth View Post
I'm wondering myself. I just want to do it soon...So that I won't have any issue's down the road. DIY for removing manifold with KraftWerks SC installed would be great. Anyone ?
I didn't have to remove the intake manifold, I removed the Accessory belt and the AC compressor out of the way then you can clearly see the braided hoses
luckily I took a picture of it follow the braided hoses underneath the intake manifold and add 2 x 9/16" spring clamps
for removing stock box and/or accessory belt you may refer the post by @ecko04 on the same thread
http://www.ft86club.com/forums/showp...2&postcount=60
, some people say that they can reach those hoses by only removing the throttle body but there's no way I can reach them and put clamps on them.. maybe if I had skinnier hands
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Calum (05-20-2014)
Old 05-20-2014, 10:16 AM   #1081
jflogerzi
jflogerzi's Avatar
What supporting mods? Also are you using the standard blower or upgraded one?
Old 05-20-2014, 10:29 AM   #1082
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Removing that bolt on the AC unit located on the drivers side will be a super PITA thanks to the location of the supercharger. Ugh!
post_break is offline   Reply With Quote
Old 05-20-2014, 02:36 PM   #1083
glamcem
glamcem's Avatar
yes it is hard but doable, worth to mention I have big hands so it took me a bit more than I expected, I also spent some time removing the throttle body and intake manifold, without them it would be a lot faster..
I would suggest you to release the accessory bolt as you did with KW kit installation then put a zip tie or cable and hold it so it won't push the AC compressor towards to passenger side and you will be able to remove the bracket and bolts easily..
so since you have the KW kit I would do this in the following order:
  1. remove intercooler pipe with the maf sensor
  2. release accessory belt by pushing tensioner pulley and have someone hold it or wrap a cable around it so it keeps holding it for you
  3. remove the first bolt from behind the AC comp
  4. release the belt from the AC compressor
  5. remove upper bracket part (see picture)
  6. remove bolts in the pictures
  7. clamp the hoses
  8. put everything in reverse order.
sorry for the typo in the pics
Old 05-20-2014, 02:37 PM   #1084
glamcem
glamcem's Avatar
looking good mayne
Old 05-20-2014, 02:40 PM   #1085
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
I'm ordering my kit today, add me to the cool KW club. anyone running e85 or Flex with stock injectors? the 91 octane here sucks, I tried e85 NA and now am addicted to it. Just want to make sure I can run this kit on stock injectors and e85.
Taino-BRZ is offline   Reply With Quote
Old 05-20-2014, 02:46 PM   #1086
TmP
TmP's Avatar
Drives: A bunch of 'em...
I guess I'm gonna take my sweet time with my install and do it over a whole weekend.
Savor it if you will and clamp down anything I can find that could lead to a boost leak. LOL
Anyone running a cam plate with the KW kit? Is it truly a must?
TmP is offline   Reply With Quote
Old 05-20-2014, 04:18 PM   #1087
gmsii
gmsii's Avatar
If you are gonna run on e85, get bigger injectors and pump...KW or one of its dealers can give you a good deal Grams Injectors and Pump upgrade
the KW highboost pulley on E85 should make 340-350 on your local dyno
gmsii is offline   Reply With Quote
Old 05-20-2014, 04:20 PM   #1088
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
My apologies if this has been answered already, but does the kit come with a basemap if I already have a license and cable?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 05-20-2014, 04:29 PM   #1089
post_break
post_break's Avatar
I think it should be known that you need a checkvalve for the crank case. Since the kit did not include one. Otherwise you're boosting it.
The Following User Says Thank You to post_break For This Useful Post:
Calum (05-20-2014)
Old 05-20-2014, 04:33 PM   #1090
TmP
TmP's Avatar
Link to a recommended check valve would be dope.
Also, suggestion on Catch can setups are something I'm very interested in
Old 05-20-2014, 04:57 PM   #1091
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It has been answered. They offer a "tuner kit" that doesn't come with a tune and they offer a more expensive kit with a tune.
Old 05-20-2014, 05:00 PM   #1092
Taino-BRZ
Taino-BRZ's Avatar
Order placed, looking to get it before the weekend. Thanks to @fteightysix for the awesome deal. Got me a c30 black edition with tune.
Sent from my SGH-M919 using Tapatalk
The Following 2 Users Say Thank You to Taino-BRZ For This Useful Post:
86SPEED (05-20-2014), Freeman (05-20-2014)
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
