Old 09-19-2013, 05:53 PM   #57
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by markmatley View Post
Thanks for the helpful comment. Wish the op of that post would chime in.
i'm sorry that you have a difficult time visualizing the relative sizes of objects in a measurable unit
Old 09-19-2013, 06:12 PM   #58
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
My previous post meant no offense.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 09-19-2013, 09:27 PM   #59
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Originally Posted by Figo View Post
Sorry I just cant understand this thread. I thought the twins' OEM rims r ugly enough until I saw these. BTW those tires make it looks like a rally car.
There's a thing out there called weight.
Yeah, you might of heard of it.
Old 09-19-2013, 11:00 PM   #60
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Weight for wat? performance? or gas saver? I c neither here. And theres a thing called profile.
I mean, it make sense if those smaller rims will make the car looks better, like these in the pic。And again, I just dont like them personally. It doesnt mean nobody gonna like them.
btw, there r ton of rims+tries with low weight.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-19-2013, 11:05 PM   #61
dem00n
dem00n's Avatar
Drives: Scion FRS
Well, why do people go for the lightest 17 inch wheel on this forum and lightest "performance" tire? People could go for the lighest 15 inch wheel and tire, even more weight savings. Gas? Nah.
The TRD special you posted above (which i love) is mostly using that 15 inch wheel for the extra sidewall. Tons of oversteer fun if you have those 195/55r15. MMMM.
Old 05-16-2014, 10:12 PM   #62
TmP
TmP's Avatar
Drives: A bunch of 'em...
Wheels that don't fit: VW Jetta 15x6 ET38
Wanted to use these as slide around crap ties, but they touch the caliper
They are the stock steel rims with 195 65 15s on 'em.
Putting one on it looked like a perfect fit, but no dice.
TmP is offline   Reply With Quote
Old 05-17-2014, 08:17 AM   #63
dem00n
dem00n's Avatar
Drives: Scion FRS
Originally Posted by Mad1723 View Post
15s... Why?
Because racecar.
You need the right offset. Might as well stick with 16's.
Old 05-17-2014, 08:39 AM   #64
TmP
TmP's Avatar
I just figured I'd share this find so others don't go through the trial and error phase as well.
15x6s aren't listed in the wheel matrix anywhere
Old 05-18-2014, 10:41 PM   #65
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Thanks, I will link this in the offset chart.
Old 05-18-2014, 10:53 PM   #66
DarrenDriven
NW Region Moderator
Hmmm, actually have someone else with that spec that successfully installed them...
http://www.ft86club.com/forums/showthread.php?t=19403
I am going to merge threads and put your note in the first post so that others will be wary.
Old 05-19-2014, 06:36 AM   #67
TmP
TmP's Avatar
The size isn't the problem. It's the fact that I tried the stock STEEL wheels.
They rub on the caliper, trust me.
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
Got some new wheels for my DGM BRZ / "DATBRZ" DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-11-2012 12:06 PM
>>> MOTEGI WHEELS 17"/18" - INCLUDING MR121/MR125 ROTARY FORGED @ 17 LBS/19 LBS BestWheelDeals Wheels and Tires 2 09-07-2012 09:26 PM
"What kind of wheels are these?" MEGATHREAD switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-03-2012 11:03 PM
How harsh is the ride on 18" vs 17" wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-18-2012 03:08 PM
