Old 05-14-2014, 08:56 PM   #1023
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
FYI the belt is a Gates TP1200-8MGT-20 PowerGrip GT2 Twin Power V-Belt 92320041. You can pick them up online for about $65.
post_break is offline   Reply With Quote
The Following 2 Users Say Thank You to post_break For This Useful Post:
Model Citizen (05-15-2014), zoth (05-15-2014)
Old 05-14-2014, 09:21 PM   #1024
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Finally got to drive the car today. Holy crap this thing is fun! I can't wait until I can get over to the tuner and get a custom tune.
Anyone have any word on the availability of a smaller pulley for the blower?
Freeman is offline   Reply With Quote
Old 05-15-2014, 12:53 AM   #1025
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Dang thats a long name.
zoth is offline   Reply With Quote
Old 05-15-2014, 09:23 AM   #1026
post_break
post_break's Avatar
http://www.biedlers-belts.com/gates-...t-20-belt.html
@digital_assassin maybe put this URL in the first post?
The Following User Says Thank You to post_break For This Useful Post:
glamcem (05-15-2014)
Old 05-15-2014, 11:22 AM   #1027
zoth
zoth's Avatar
Thanks, that is a great price.
Anyone here using a Omi 3 bar on the kit? I would like to see how it's mounted. If you could please attached you pics. Thanks in advance.
Old 05-15-2014, 02:05 PM   #1028
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It mounts just the like the OEM sensor does on the driver side of the intake manifold with one bolt.
zoth (05-15-2014)
Old 05-17-2014, 09:59 PM   #1029
vgi
Drives: frs
quick update on C38 blower kit:
1. Kraftwerks does have a whole new molded pipe for C38 kit which they do provide, not some hacked-up couplers.
2. For those who have Circuit Werks lightweight pulleys, crank pulley seems to work just fine with the kit.
3. I was told the kit made 299whp on mustang dyno with stock header, overpipe back exhaust, fuel mods (pump and injectors) on 93 pump gas, and standard pulley. don't have the dyno sheet yet though.
vgi is offline   Reply With Quote
The Following 3 Users Say Thank You to vgi For This Useful Post:
Calum (05-17-2014), Freeman (05-17-2014), post_break (05-17-2014)
Old 05-17-2014, 10:07 PM   #1030
Freeman
Freeman's Avatar
Man, if I had a tuner close to me the C38 would have been the kit to buy.
Old 05-17-2014, 10:17 PM   #1031
vgi
Drives: frs
someone will offer e-tune sooner or later
Old 05-17-2014, 11:44 PM   #1032
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
yesterday, I did my first lapping event with Kraftwerks and all I can say is wow, I have to re-learn to drive this car again since the shifting points and gear selection for the certain turns are completely changed
I also took some logs and my oil temps were about the same (260-265 F) with last time but I have to add the ambient temps were higher yesterday (highest was around 220F) but I noticed it recovers a lot quicker ( both oil and coolant temps) maybe I should combine my oil to air with an air to air , coolant temps were a bit higher and I think I might have left some air in the system when changing the radiator I will make sure there is no air left..
[ame="http://youtu.be/Fa1UWvB-Lrg"]http://youtu.be/Fa1UWvB-Lrg[/ame]
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Superstar (05-19-2014)
Old 05-17-2014, 11:46 PM   #1033
CSG Mike
CSG Mike's Avatar
260 with an oil cooler is unacceptable... do you have air directed toward it?
Old 05-18-2014, 12:47 AM   #1034
glamcem
glamcem's Avatar
Mike a few things worth the mention since I have OEM oil cooler and it depends on the radiator, I should get better temps when I burp the coolant system.. and since I had the same oil temps when I was NA (completely stock power) with lower ambient temps I can only guess it will get better, if not maybe I can consider adding an air to oil cooler on top of my OEM cooling system ( if possible) so that I can keep my OEM cooler for warming purposes.. I will provide more data
Old 05-18-2014, 12:52 AM   #1035
CSG Mike
CSG Mike's Avatar
What were your coolant temps looking like? Was there a significant delta before/after the oil cooler? (we have existing data that shows that just adding a Rotrex supercharger doesn't significantly affect coolant temps on track).
*edit*
I just got around to watching your video. Do you normally shift early, even before the SC? Engine RPM has a direct correlation to oil temperature that is fairly independent of actual engine output.
Old 05-18-2014, 01:00 AM   #1036
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
So up at @Drift-Office today for tune refining after adding the 3" exhaust and came away with some really good results. Bob and Bill smoothed it out and it is not falling off at 6800rpm any more. I can't wait till tomorrow so I can drive it.
digital_assassin is offline   Reply With Quote
The Following 3 Users Say Thank You to digital_assassin For This Useful Post:
Freeman (05-18-2014), glamcem (05-18-2014), OICU812 (05-18-2014)
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
