Old 05-14-2014, 02:36 PM   #71
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by dwx View Post
This pan doesn't have fins, I believe the FBM cast pan does. I also don't think it would make a ton of difference on this car, there isn't really good airflow in that area anyways.
I plan on applying gold reflective tape to the pan. People are having issues with melting motor mounts with FI... Going to try to do all I can to protect the components around the header and down pipe.
Has more than one person really had issues melting motor mounts? Got any links? I was under the impression that it was a one time problem for someone using known poor fitment turbo kit.
Decay107 is offline   Reply With Quote
Old 05-15-2014, 06:06 AM   #72
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Originally Posted by Pitman View Post
@racerx1715 @DesertFrs
Has a fitment been confirmed yet with the AVO turbo kit?
Yes, fitment was a little tight to the headers but did clear. We have since updated the pan to provide clearance in those areas.
Just a question, what's the size of the oil return plug? My JDL turbo kit came with a weld-in return with a push-on fitting which I think is -8AN, so I need to buy a male to barbed fitting to put in the oil pan.
Thread size on the pan is: 1/2" NPT.
Jeff@Racer X Fab is offline   Reply With Quote
The Following 2 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
Pitman (05-15-2014), xwd (05-15-2014)
Old 05-18-2014, 12:34 AM   #73
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Pitman,
I received the Oil Pan a few weeks ago and installed it on the FRS. Their was one spot on the Pan where I had to contact @racerx1715 as it touched with the AVO Header. I still have the Oil Pan on the car and still driving it at this point. Jeff stated he was going to look into that.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following 2 Users Say Thank You to DesertFrs For This Useful Post:
Jeff@Racer X Fab (05-20-2014), Pitman (05-18-2014)
Old 06-15-2014, 08:45 PM   #74
xwd
Edit: I learned if you raise the motor it will tilt the engine forward enough to where there is room between the front crossmember and the pan to get a socket on the back three bolts. So you don't have to take out any motor mounts, just take off the nuts holding them to the crossmember.
Also don't take the drain plug out after you put the pan on the car, because by the time you do oil will have collected there and drip on you...
The Following User Says Thank You to xwd For This Useful Post:
Jeff@Racer X Fab (06-17-2014)
Old 10-21-2014, 04:41 PM   #75
blown
Drives: ft86
does it fit on nameless header?
blown is offline   Reply With Quote
Old 10-22-2014, 09:42 AM   #76
Jeff@Racer X Fab
We have confirmed fitment on the following headers/turbo kits:
OEM header no heat shield
P&L header
JDL header
JDL turbo kit
AVO turbo kit (Rev 2 oil pan)
We have had 2 customers that used the Nameless header but have not had confirmation on fitment.
Old 02-02-2015, 10:58 PM   #77
normancw
normancw's Avatar
Drives: 128i
Question OpenFlash Header
P&L header
JDL header
JDL turbo kit
Do you have any customers that have confirmed fitment with the OpenFlash Header?
normancw is offline   Reply With Quote
The Following User Says Thank You to normancw For This Useful Post:
DAEMANO (02-03-2015)
Old 02-03-2015, 09:47 PM   #78
Jeff@Racer X Fab
No I don't think we do. If you would be interested in checking the fitment, shoot me a PM.
Old 04-15-2015, 12:54 PM   #79
1BadFA20
Drives: '92 GS-R, '02 RSX-S, '14 BRZ
Racer X Pan does not fit with FA20 club turbo manifold. It hits on the right side. If you smash in the tube it works though lol.
JDL clears like a champ.
PTE 5758, Turbosmart, JDL, Perrin, Tein, Rays Gramlights, Sumitomo, Raceseng, Beatrush, Buddy Club, Valenti, DSS, Act, Cartboy, Mtec, APR, Beatsonic, FA20CLUB, Radium, JPM Coachworks, VIS, Recaro, IAG, Cleib, Nameless, Zele
Coming soon: Garage Vary, Cleib, Cravenspeed, VEI
1BadFA20 is offline   Reply With Quote
The Following User Says Thank You to 1BadFA20 For This Useful Post:
Jeff@Racer X Fab (04-17-2015)
Old 04-15-2015, 01:13 PM   #80
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Any confirmation that this clears a Openflash Header?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 04-15-2015, 09:25 PM   #81
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
Came from the MR2 community where we all loved your products. I have PTuning headers and would like to be a part of testing the clearance.
Trefoil is offline   Reply With Quote
The Following User Says Thank You to Trefoil For This Useful Post:
RJasonKlein (04-16-2015)
Old 04-16-2015, 12:05 AM   #82
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Yes, please report back your results - I have the PTUNING header and would like to know if the Racer X Fabrication oil pan clears our header.
RJasonKlein is offline   Reply With Quote
Old 04-17-2015, 10:33 AM   #83
Jeff@Racer X Fab
No, we have not had any customers use the oil pan with the Openflash header. If you would like to try test fitting the pan send a PM or email to info@racerxfabrication.com
Thanks!! Same, we have not had a test fit with the PTuning header feel free to PM or email if interested.
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
Trefoil (04-19-2015)
Old 04-19-2015, 06:51 PM   #84
Trefoil
Trefoil's Avatar
PM'd. Looking forward to your additional products for this platform as well!
Racer X Fabrication air intake design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 45 08-01-2019 12:29 PM
Racer X Fabrication suspension parts, and development Jeff@Racer X Fab Suspension | Chassis | Brakes -- Sponsored by 949 Racing 134 09-01-2016 05:02 AM
Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! Jeff@Racer X Fab Groupbuys 74 06-23-2014 09:08 AM
Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! Jeff@Racer X Fab Brakes, Suspension, Chassis 25 01-24-2014 11:42 AM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
