Old 05-14-2014, 07:29 PM   #29
illicitstylz
Drives: 2014 FRS - Whiteout - 6spd MT
Originally Posted by swpbrz View Post
The auto one is for transmission the vsc one both have is for when and where to brake as you loose grip.
this english makes my head hurt.
illicitstylz is offline   Reply With Quote
The Following 2 Users Say Thank You to illicitstylz For This Useful Post:
FRSupra (05-16-2014), NWFRS (05-15-2014)
Old 05-14-2014, 07:47 PM   #30
theom
Drives: FR-S 2013
6 speed
I drive my 6 speed manual with the sport button on all the time.
Without it, I find the traction control too interfering.
I wish there was a setting to allow even more slip before the traction control braking kicks in.
If it's raining hard I might leave the sport button off. (full traction control).
So for me, Not useless.
theom is offline   Reply With Quote
Old 05-14-2014, 08:01 PM   #31
J_kennington
Drives: 2013 asphalt scion FRS
Originally Posted by djmm View Post
Does the sports mode in auto make the car slide sideways easier?
what that other guy TRIED to say is.
no on an auto the "sport" button does not do anything with the tc. the vsc sport button does.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-14-2014, 09:58 PM   #32
Trifid
Human
Trifid's Avatar
Drives: 2013 FR-S 6MT 10 Series #704
"Control characteristics such as the Vehicle stability control (VSC) and TRAC are adjusted to afford maneuverability closer to what a driver may have imagined"
Yes. By far, the dumbest thing I have ever read. I "imagined" the car would take off and fly, but it didn't. I want my money back!
Trifid is offline   Reply With Quote
Old 05-14-2014, 09:59 PM   #33
theom
Drives: FR-S 2013
How does one activate inspection mode on the manual trans FRS?
Is this the "Pedal Dance" I've heard of?
thanks
Originally Posted by stevesnj View Post
Inspection Mode disables the aids as well as the auto LSD which is always on with VSC and TRAC off. ABS for pedal braking is still on in Inspection Mode but ABS to control LSD loading (off brake pedal) during cornering. Enjoy! This is also how the service manual states to do Dyno runs to get the true HP and other readings.
Old 05-14-2014, 10:15 PM   #34
Trifid
Human
Trifid's Avatar
Yep, that's the pedal dance.
Here's an interesting tidbit: The pedal dance (diagnostic mode) isn't limited to the FRS/BRZ, it also works on (of all things) a Yaris. So I'm guessing all Toyotas can be "pedal danced." It's amusing to see a Yaris go balls-to-the-wall with the two yellow lights on the dash. LOL
Old 05-14-2014, 10:48 PM   #35
Mcpot132
Drives: Hopefully a BRZ!
Originally Posted by fang_gt86 View Post
If you can't tell the difference, you're not driving it hard enough..
Mcpot132 is offline   Reply With Quote
Old 05-14-2014, 10:58 PM   #36
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
I imagine Do-Rifto!!!!
Jond63 is offline   Reply With Quote
Old 05-15-2014, 08:01 AM   #37
djmm
djmm's Avatar
Drives: toyota
So really sports mode in auto is just higher rpm gear change ?
What is a pedal dance
djmm is offline   Reply With Quote
Old 05-15-2014, 08:04 AM   #38
stevesnj
stevesnj's Avatar
thanks
Video
[ame="https://www.youtube.com/watch?v=CWXv7UNA7hg"]FRS Pedal dance - YouTube[/ame]
The Following User Says Thank You to stevesnj For This Useful Post:
illicitstylz (05-15-2014)
Old 05-15-2014, 08:04 AM   #39
J_kennington
On my at, it seems like higher auto rpm range, better throttle input, and a slightly different exhaust note. Us in the auto have BOTH a sport and a vsc sport button. Both can be used at the same time.
2005 Yamaha yz250f
Old 05-15-2014, 09:40 AM   #40
djmm
djmm's Avatar
Drives: toyota
Good to know. I have A/T too but still breaking in, that's why I never touched any settings yet.
Old 05-15-2014, 10:14 AM   #41
J_kennington
If you are say, traveling 70mph in 6th(manual mode on at). Say you want to downshift to the lowest gear possible(from my own experience at 70 it's about 4th gear). So you start flapping the paddles and then OH NO I hit it 3 times instead of 2". The car will audibly beep at you and stay in 4th. To say "hey bozo, if I go to 3rd your gonna blow me up so I'm staying in 4th whether you like it or not".
Another thing, if your coming to a stop the car will automatically downshift for you at minimum rpms to keep from stalling(in either mode).
2005 Yamaha yz250f
The Following User Says Thank You to J_kennington For This Useful Post:
MoebiusStrip (05-17-2014)
Old 05-15-2014, 11:35 AM   #42
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
From what I've seen driving mine in sport mode, the car doesn't like to shift before 3k rpm at any point, and will hold a gear much longer with even a little more throttle. I like the sport mode, although I will say it's pretty useless on roads with speed limits of 35 or less. No matter how slow you drive it refuses to shift up until you hit 3k rpm, so if you can't get above 37 (where it hits 3k in third I believe) because of traffic it won't shift and you'll be wasting gas until you manage to go over 37, or hit the paddle shifter.
Anywhere else though it's a pretty nice little feature. As far as the VSC sport versus sport mode, the article seems to be just talking about sport mode. But some cars combine traction control differences with transmission differences so it's hard to know exactly which one to talk about here.
Nevermore is offline   Reply With Quote
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 02:40 AM
DIY Auto VSC Sport and AT Sport Mode Seattle944t DIY (Do-It-Yourself) Guides 0 09-08-2013 05:02 PM
Cruise control with Sport or VSC Sport mode notout86 Scion FR-S / Toyota 86 GT86 General Forum 12 08-29-2013 06:50 PM
normal mode/vsc sport/trc off Toyota GT 86 Scion FR-S / Toyota 86 GT86 General Forum 48 04-09-2013 01:47 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
