Old 04-06-2014, 11:40 AM   #85
xjohnx
Grip>Slip
xjohnx's Avatar
It's a long shot, but Visconti and Moto Mike get them so they now where from... Now getting that info from them.....
just shot @moto-mike an email to see if he could sell me one or two. thanks!
Old 04-06-2014, 11:57 AM   #86
Ryan P
If you get some useful info on this let me know I too would like to know where to find stock connectors
Sent from my SPH-L710 using Tapatalk
Ryan P is offline   Reply With Quote
Old 04-14-2014, 05:11 AM   #87
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Just wanted to point out a really stupid error I made in hopes it saves someone else during the install. It didn't make any sense when I was doing it, and this caused me to double check the wiring diagrams, and low and behold, my haste led to an error. In regards to connecting the AEM Failsafe wideband, the white wire that you tap into for the analog AFR data is not the white wire coming off of the Uego wideband, but the whitewire that comes out of the AEM gauge cluster. This is logically obvious, and obvious if one spends 5 seconds to look at the AEM instruction manual. You will find this wire, along with the brown wire that needs to connected to ground for the analog output. Simple mistake, but no point in two people making it.
OjiGeorge is offline   Reply With Quote
Old 05-10-2014, 12:37 PM   #88
xjohnx
Grip>Slip
xjohnx's Avatar
I ended up finding one, but i'm not sure which part # i ordered. It was either the subaru or toyota one. I wish I could tell you which one worked because I ordered them both and had them separated so i could keep track of which was which, but my girlfriend managed to do some spring cleaning.
I'm almost certain the Toyota one was the one that fit: http://www.casperselectronics.com/st...oducts_id=1306
but here's the subaru one just in case: http://www.casperselectronics.com/st...oducts_id=1395
Old 05-14-2014, 12:30 PM   #89
welllam
Drives: STi
Hey @sportguy83
Do you use the whole length of the signal wire of the AEM gauge or you connect a new wire from o2 into the cabin and then fuse to the gauge output wire, meaning the AEM output wire is as short as possible? I'm thinking might be some resistance Issue because the AEM wire looks very thin!
Took log tonight. Mine was at 4.49 V, so really on point.
我從使用 Tapatalk 的 SM-N9005 發送
welllam is offline   Reply With Quote
Old 05-14-2014, 12:48 PM   #90
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by welllam View Post
Hey @sportguy83
I used the full length of the AEM wire and it made it exactly to the place I wanted cutting the Rear O2 cable fairly close to the sensor.
Old 06-01-2014, 11:25 PM   #91
wowy
wowy's Avatar
Drives: 1990 Mazda Miata, ISO 2022+ BRZ...
Thanks! I ordered the Toyota one and it fit just fine. Very clean install.
wowy is offline   Reply With Quote
Old 06-03-2014, 10:12 AM   #92
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Sorry to revive this thread. I have my AEM wideband connected to evap. I can see the data in ecutek. I'm using a power ground which makes my AFR off by a factor of 1. Meaning in ecutek it shows 15.5 but the gauge would be 14.5.
What are you guys using for analog ground? Can someone please provide a pin and connector I can look up in the wiring diagram?
post_break is offline   Reply With Quote
Old 06-07-2014, 08:00 PM   #93
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Installed my LC-2 on the rear O2 port today.
At first I tried using the power and ground ports on the plug to power the whole thing. However, it seems it shares a ground with the throttle body. When I powered it up, as soon as the O2 heater turned on, the throttle body freaked out.
The LC-2 must be pumping a ton of noise across it's ground. I ended up running dedicated power and ground for it, and it seems fine now.
Just something to be aware of. Other wideband setups may be fine, I dunno.
FrX is offline   Reply With Quote
Old 06-08-2014, 04:23 PM   #94
xjohnx
Grip>Slip
xjohnx's Avatar
would love to see some pics.
Old 06-09-2014, 02:54 AM   #95
D K
Stig's dark passenger
Question to the gurus out there @Sportsguy83 and @jamesm
If you use the cpc for flex fuel, can you still use it for the failsafe?
Are there any conflict issues?
D
D K is offline   Reply With Quote
Old 06-09-2014, 05:16 AM   #96
s2d4
s2d4's Avatar
D
Why not use the rear o2 sensor for WB?
Old 06-09-2014, 08:53 AM   #97
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
FML lol Do i really want to do my first turbo install on my own!
Its seems simple but then at times just doesnt! your first post was like a 2nd language for me! lol
I get frustrasted with stuff quick so i can see me punching my frs during this process! lmao
EDIT: MECHANICAL STUFF exhaust manifold DOWNPIPE turbo oil lines fuel pumps piping intercooler drilling oil cooler etc. CAKE!! "I got this"
ELECTRICAL STUFF: "FML I suck"
FRS_FIEND is offline   Reply With Quote
Old 06-09-2014, 09:55 AM   #98
nelsmar
D
There are two Ecu inputs that ecutek can utilize. The cpc and the rear o2. You cannot wire two devices to the same input.
My flickr - Canibeat
Local magazine scout
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-08-2013 11:23 PM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 10:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
