Old 07-27-2010, 03:48 AM   #29
Matador
hashiryu
Drives: Mk4 Supra
All they need is a new head with some kind of dual VVTL-i or something and direct injection. EJ lives on for 5 more years...
Subaru has AVCS and AVLS, Doubt either will be present though. Toyota is working on the engine heads. They are implementing D4-S (direct injection).
Matador is offline   Reply With Quote
Old 07-27-2010, 03:53 AM   #30
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by [es vi: eks] View Post
The only thing the EZ30 and EG33 has incommon is they both flat 6s and used in Subarus.
The EZ30 was a complete new design at the time.
Sorry, I should of been more specific when I wrote that. Yes, EZ30 & EG33 are some what different. BUT if you look at all the tech they used on EZ30, which came from EJ. While EG33's tech was from... EJ engine.
EJ22 add 2 more cylinders -> EG33
EJ20 add 2 more cylinders -> EZ30
EJ22 improved w tech -> EJ20 & EJ25
...Do you see the Mary-go-around? Or it was bad metaphor?
Old 07-27-2010, 05:50 AM   #31
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
Mary-go-round works, at least it worked for me.
And in the scheme of things aren't all engines "archaic"? I'd say it really does come down to the technology advancements versus the engine designs. Engine design has been primarily unchanged for the last century with the significant changes being in materials and the afore-mentioned changes in tech (SOHC vs DOHC, timing chain > timing belt, push rods vs cam shafts etc. etc.).
I definitely don't know the full history of the changes, but the principle and primary design, as to say cylinder lay out and 4 stroke etc, has been standard for... I would have to guess a little over a century. Except for those guys at Mazda and their crazy Wankel.
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 07-27-2010, 06:44 PM   #32
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
Originally Posted by Conor View Post
I'm sorely disappointed that they're not using something like the IS350's 3.5L V6 in this car... never mind that they're (likely?) putting a boxer engine in it.
I like the concept of the car, but the powertrain is pushing me away.
If your in to hp out of the box this car is wrong for you, this car is mirrored over the old AE86 this car will be more on balance & cornering ability not 1/4 mile runs.
4agze is offline   Reply With Quote
Old 07-27-2010, 08:27 PM   #33
Dimman
Kuruma Otaku
Dimman's Avatar
Most of the major EJ changes are done to the head(s). Basically what seems to have stayed the same with the EJ will have been its bore spacing and mounting points for engine to chassis and for transmission to engine, and the fact that is some kind of OHC. It has come in displacements ranging from 1.8L (maybe less in Japan or Europe?) to 2.5L, so there is no need for major changes to the bottom end for displacement changes. Fundamentally its a very solid starting point for whatever they want to do to this motor.
AVCS is cam phasing (VVT-i)? And AVLS is profile changing (VTEC)? Which systems are on which current motors?
Either way if it's NA it will at least have AVCS/VVT-i. That is pretty much required for a combination of any form of performance with good emissions.
As for profile changing, Toyota seems to have moved away from VVTL-i, (the Lift part anyways). Why is that? Cost? Or just not having a performance platform to bother putting it in?
Old 07-27-2010, 09:33 PM   #34
ichitaka05
Site Moderator
ichitaka05's Avatar
iirc current ones are AVCS.
Old 07-28-2010, 03:33 PM   #35
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
V-6 in an supposed 86 successor?
Leave.
OldSkoolToys is offline   Reply With Quote
Old 07-28-2010, 04:45 PM   #36
4agze
4agze's Avatar
Leave.
lol thats what i was thinking, his in the wrong forum I'll direct him to the right one.
here
http://www.genesisowners.com/hyundai...esis-forum.php
http://www.the370z.com/
Old 07-28-2010, 05:05 PM   #37
Matador
hashiryu
Drives: Mk4 Supra
Retrds who don't know how and when to shift.
Leave.
Old 07-28-2010, 06:48 PM   #38
Abflug
Abflug's Avatar
Drives: MR2
how´s the boxer engine compared to the 3s-ge?
Abflug is offline   Reply With Quote
Old 07-28-2010, 08:07 PM   #39
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
if done right, a modern 2.0L will smoke a 3SGE, even the BEAMS. H4 or I4.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 07-28-2010, 08:07 PM   #40
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
Edit: damn it NESW20
Midship Runabout is offline   Reply With Quote
Old 07-28-2010, 08:09 PM   #41
NESW20
2.1L 3SGTE
me or tom? haha
2008 Civic Si Sedan
Old 07-28-2010, 08:11 PM   #42
Midship Runabout
Tom. Where did the 3s come from?
engine swap thread aspera Engine Swaps 231 03-15-2011 06:10 PM
Any issues with Subaru engine? CyberFormula Engine, Exhaust, Transmission 10 06-26-2010 06:02 PM
Subie rear-engine student-rendering Axel Other Vehicles & General Automotive Discussions 5 12-31-2009 10:12 AM
Accurate Engine Impressions S2KtoFT86 Other Vehicles & General Automotive Discussions 1 12-16-2009 01:05 PM
