#29 |
Drives: Scion FR-S
Gen, can you take pictures of the window switch panel and if there is an easy way to insulate around it? I believe that is where most of the rattles are coming from.
#30 | |
Drives: Scion FR-S
side: ![]() back ![]() It appears the plastic tabs keep it all held together. I haven't popped them off as I have a feeling I'd break them if I tried. The tabs are very rigid plastic. |
#31 |
Drives: 2013 Aquamarine Scion FR-S
Hey just wanted to post a solution I came to for the rattle. I went to the parts house and got a tube of RTV (pretty much gasket in a tube for those of you that don't know what it is). Then I took the door panels off and took out the switch housing. The rattle was coming from the seam of the two separate pieces. I took the RTV and made a line all the way around on both of them and then smoothed it out. Let it dry and re-install. 7 bucks and about 45 minutes (including drying time) and the rattle was gone!
#33 |
Drives: Whiteout FR-S
You can use Dynamat or a closed cell foam. Dynamat deadens metal or plastic but the foam is actually the best rattle killer for plastic in my opinion. Get a pack of this for the plastic...
http://www.raamaudio.com/products/En...and-Stick.html and this for the metal... http://www.raamaudio.com/products/RAAMmat-BXT-II.html |
#34 |
Drives: 2003.5 BMW m3
For the people who want to use Dynamat, I've heard to use eDead or FatMat for a cheaper alternative.
#35 |
Drives: Sexy Frs Firestorm M/T
O boy -_-
Not looking forward to something like this. *shrugs* taking apart the door and putting foam in should be easy... I mean it sounds easy. Right? Goodluck guys |
#36 |
Drives: Scion FR-S
Just took the door panel off to fix this. I used 3m tape and put it between all interfaces between the speaker-grill/window switches and the door. Also, the actual switches/box they sit in has some play, so put a little in there as well. Whole process took about 45 minutes. Hardest part for most will be removing door handle inserts, but mine where already off from previous project.
No more rattles, but waiting for a little cooler temps outside to be sure. |
#37 |
Project BRZ-Boosted Autos
Drives: MY14 BRZ
Dynamat seems like overkill for this kind of thing. Expensive and adds heaps of weight!
In my old WRX I pulled pretty much every panel off the interior and packed it full of packing foam and speaker box padding. It's cheap as chips, weighs next to nothing and does a great job! I'll be doing the same thing in my BRZ as soon as rattles start to arise outside of warranty. I already have a few in my drivers door that I'll be hopefully getting sorted by Subaru soon. |
#38 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
EASY FIX!
I literally took duct tape and rolled it a few times, it sandwiches in between the passenger button and the sidewall of its compartment. This got rid of EVERY RATTLE FROM THE DRIVER'S SIDE DOOR without taking anything apart, the button also loses no functionality, if you roll the duct tape the right thickness it won't pop out and will still allow the button full range of motion. A great basically not noticeable fix to an annoying problem without taking apart the door panels! |
#39 |
Drives: 2014 Subaru BRZ (Limited)
is anyone having ratting issues with their actuator in either door? i only have ratting on the passenger side but as soon as i lock the door from the inside, its gone...
#40 | |
Drives: 2013 BRZ(swp) Limited
I pulling the door cards off this weekend and installing both dynamat on the doors and some closed cell foam along the plastic parts that are rattling. I'll keep this thread updated with results! |
| The Following User Says Thank You to br_z1Lch For This Useful Post: | jbsali (05-22-2014) |
#41 |
Drives: 2013 FR-S White
well i just dropped it of at toyota for them to handle it and turns out that its the speakers and replacing them with better ones would "fix" the rattle.
#42 |
Wayward Member
Drives: Hot Lava 86
I had the dealership look at mine for the rattles and they said some stuff was loose so they tightened it all back up. On the drive home I was so excited to listen to music without a rattle I turned it way up. It was rattling again by the time I pulled in my driveway. Next time I went back I told them, but they said they looked at it and everything was fine, just don't turn the music up too loud. >_>
| Speaker Sizes | Thefuzz | Electronics | Audio | NAV | Infotainment | 68 | 05-28-2021 06:18 PM |
| Undercarriage aero panels: Not on US BRZ? | YankBoffin | BRZ First-Gen (2012+) — General Topics | 122 | 01-03-2015 10:56 PM |
| Rattle in door speaker panels | Lefty | Electronics | Audio | NAV | Infotainment | 2 | 06-18-2012 06:41 PM |
| A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 07:46 PM |
| Driver Side Speaker Housing Rattle | Lefty | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-12-2012 10:32 AM |
