| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
| View Poll Results: I have used speed bleeders long term (2+ years) and had - | |||
| no issues with them, would recommend |
16 | 84.21% |
| minor issues with them, but still would recommend |
0 | 0% |
| minor issues with them, so would NOT recommend |
2 | 10.53% |
| major issues with them, so would NOT recommend |
1 | 5.26% |
| Voters: 19. You may not vote on this poll | |||
#15 |
Drives: Attitude
#16 |
Senior Addict
Drives: 86 GT
Is it the Ford compatible cap that we need to suit our MC?
#18 |
Drives: MDX, Camry
Could somebody give us a link for everything that we need to buy for a power bleeder? It is a little confusing now that so many adapters/caps are mentioned. Thanks.
#19 | |
Drives: Asphalt Scion FR-S
[ame="http://www.amazon.com/gp/product/B0002KM5ME/ref=oh_details_o01_s01_i03?ie=UTF8&psc=1"]Amazon.com: Motive Products Custom Ford Power Bleeder(0107) Ford 3 Tab: Automotive[/ame] Use this for the clutch reservoir: [ame="http://www.amazon.com/gp/product/B00A7UMW90/ref=oh_details_o01_s01_i01?ie=UTF8&psc=1"]Amazon.com: Power Bleeder Adapter - Universal Round Adapter mot1101: Automotive[/ame] If you want to get fancy with the connectors, use something like these: [ame="http://www.amazon.com/gp/product/B008V1XSPY/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1"]Amazon.com: Colder PLCD17005 Acetal Tube Fitting, Coupler, Shutoff, In-Line, 1/4" Flow Coupler x 5/16" Barb: Industrial & Scientific[/ame] [ame="http://www.amazon.com/gp/product/B008V1U0UU/ref=oh_details_o00_s01_i00?ie=UTF8&psc=1"]Colder PLCD22005 Acetal Tube Fitting, Insert, Shutoff, In-Line, 1/4" Insert x 5/16"Barb: Threaded Tube Fittings: Amazon.com: Industrial & Scientific[/ame] Below is a link to what the Porsche guys are doing to use this power bleeder as a dry pump: http://forums.rennlist.com/rennforum...ethod-use.html
| The Following User Says Thank You to JDKane527 For This Useful Post: | amram (05-13-2014) |
#20 |
Drives: 86
I have both the Motive PowerBleeder and Speed Bleeders. Hands down, I always prefer my Speed Bleeders. The PowerBleeder is a great tool, but hooking it up...filling the jug with brake fluid...pressurizing...removing the unused fluid...etc... is just a bigger pain than SpeedBleeders.
I use the Motive PowerBleeder on one of my cars still, but all my others have SpeedBleeders. I've had zero problems with them, even with my brakes being bled very frequently for track use. I've owned 8+ vehicles with SpeedBleeders installed, and never had an issue. Just be sure to buy the official SpeedBleeders, not the knock-offs. |
| The Following User Says Thank You to TemeCal For This Useful Post: | amram (05-13-2014) |
#21 |
Put them on all 4 calipers of my speed3, one leaked right away. Wouldnt do it again.
#22 |
Drives: Nevermorange FRS
Can't use motive bleeder for clutch, but you can use speed bleeders. makes clutch bleeding dandy.
PRO86 | WTCC | STL
#24 | ||
Lacking brains
Drives: frz
http://www.oakos.com/Merchant2/merch...Category_Code= I bought the Subaru one for my forester several years ago, works fine on this car Quote:
Top off reservoir, put on cap, pressurize (5-10psi), open bleeder, close bleeder. In cases where there's a lot of bleeding/flushing at a corner you may have to pump again. I really like how it allows me to stay the hell out of the interior of the car with dirty hands. |
#25 | |
Drives: 86
Never heard that before. Even their instructions say to add up to 2 quarts: http://www.motiveproducts.com/frame-instruct.htm That would be more of a pain doing a full flush/replacement, having to depressurize...top off...repressurize...bleed...depressurize...top off...repressurize...bleed....etc. You can not do a full flush with a few "top offs". |
#26 | |
Lacking brains
Drives: frz
#27 |
Drives: 86
I've done full flushes with both, and the speed bleeders are much easier and a LOT less messy. Not putting down the Motive, it's a great product. It's just not nearly as easy.
If you only topped off your reservoir once, I think YOU are doing it wrong. Your brake system takes a lot more than you're leading everyone to believe. |
#28 | |
Lacking brains
Drives: frz
There was no mess, at least not outside of your standard bleeding into a container through a hose. I'm not alone http://forums.corvetteforum.com/auto...r-bleeder.html http://forums.rennlist.com/rennforum...r-bleeder.html
| DIY - Stainless Steel Lines - Speed Bleeders - Fluid Bleed/Flush | F1point4 | DIY (Do-It-Yourself) Guides | 99 | 08-24-2017 06:05 PM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
| Forced Induction - is there a long term reliability problem for the 86/BRZ | Dazza | Forced Induction | 32 | 09-26-2012 12:39 AM |
