Old 03-01-2014, 01:01 AM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
Checking your Direct Injector numbers
Hey everyone! Here is a little trick to see the number of the direct injector seals you have on your car. This is useful if you are going to replace them and want to order them before taking everything apart.
Below is the general area you will be looking in. This is right behind the AC compressor and down below the manifold. notice where the white light from my stinger is shining on the head of the bolt below the manifold
Below is a closer look of where you are looking. Sorry for the crap and blurry pic but this is zoomed in some more. to the left under the manifold you will see the top of bolt there.directly behind that is the actual injector. which you will see in the next pic.
Below is the zoom of the straight shot down right behind the bolt i was talking about in the previous pic. you can see the number and you can see the connector going into it.
Hope this helps!
ft86me is offline   Reply With Quote
The Following 5 Users Say Thank You to ft86me For This Useful Post:
BatStig (03-01-2014), DAEMANO (03-01-2014), Laika (05-07-2014), OICU812 (03-04-2014), suaveflooder (03-01-2014)
Old 03-01-2014, 01:05 AM   #2
suaveflooder
Great trick! Used it a couple months ago. I'm a 2
suaveflooder is offline   Reply With Quote
The Following User Says Thank You to suaveflooder For This Useful Post:
ft86me (03-01-2014)
Old 03-01-2014, 01:08 AM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
thanks man! i was talking to @nelsmar on the phone while doing this and he was like whoa you should post this haha.
The Following User Says Thank You to ft86me For This Useful Post:
Old 03-01-2014, 01:09 AM   #4
suaveflooder
It's a good post. Most people don't know you can see it without removing a thing
ft86me (03-01-2014)
Old 03-01-2014, 01:10 AM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
thanks man! hope i'm not stepping on toes if people found this out before.
Old 03-01-2014, 06:17 AM   #6
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Brilliant, thanks!
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
ft86me (03-01-2014)
Old 05-03-2014, 10:47 PM   #7
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
just trying to educate myself. why would the numbers be different from one car to the next? isn't it 1 seal per injector? thx for the post.
Attachment 68818
Attachment 68819
Attachment 68820
Hope this helps!
garfull is offline   Reply With Quote
Old 05-04-2014, 03:52 AM   #8
ft86me
ft86me's Avatar
Drives: 2013 FRS
It has to do with the angles they spray into the cylinders. Each number that is labeled on it sprays differently so you need the same set that came w yours and all need to be the same. As for the fuel injectors, you don't need to worry about any of that. Hope this helps !
garfull (05-04-2014)
Old 05-13-2014, 10:10 AM   #9
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
someone show this to @Dezoris
marcoaferrer is offline   Reply With Quote
Old 05-13-2014, 11:28 AM   #10
Dezoris
Dezoris's Avatar
The direct injector thread had this updated. Its very good you can sneak a peak and see the numbers. I hope overtime as corrosion sets in and dirt builds up that these numbers don't disappear.
The Following User Says Thank You to Dezoris For This Useful Post:
ft86me (05-13-2014)
Old 05-13-2014, 11:53 AM   #11
ft86me
ft86me's Avatar
Drives: 2013 FRS
Thanks for helping me w the parts and info for getting my seals changed. Car is running great and now at 12psi!
Old 05-13-2014, 11:55 AM   #12
Dezoris
Dezoris's Avatar
Great, no problem. Hopefully they stay healthy with no knock and detonations should be fine.
ft86me (05-13-2014)
Direct Injector Seal Installation | Video and Issues Dezoris Engine, Exhaust, Transmission 234 03-07-2023 01:20 AM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Direct Injector Failure Poll track_warrior Issues | Warranty | Recalls / TSB 553 01-12-2017 06:12 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
Checking out your own car Bu-Tang Scion FR-S / Toyota 86 GT86 General Forum 18 06-11-2012 10:41 PM
