Old 02-14-2014, 10:35 PM   #57
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Thanks a lot for your research fstlane!
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 02-18-2014, 10:55 PM   #58
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Mikepage View Post
Eibach
Hollow
Front : 25mm
2 position
P1 = 88 N/mm (500 lbs/in) +255%
P2 = 103 N/mm (585 lbs/in) +314%
Rear : 19mm
2 position
P1 = 45 N/mm (255 lbs/in) +126%
P2 = 60 N/mm (338 lbs/in) +200%
http://performance-suspension.eibach...-roll-kit_2013
Hotchkis
Hollow
Front : 25.4mm
2 position
500 lbs/in 170%
630 lbs/in 245%
Rear : 19mm
4 position
320 lbs/in 200%
405 lbs/in 275%
520 lbs/in 385%
700 lbs/in 550%
http://www.hotchkis.net/scion-frs-sp...sway-bars.html
Uh.. so Is 500lb/in 255% stiffer than stock or 170% stiffer?
Old 02-18-2014, 11:42 PM   #59
solidONE
solidONE's Avatar
Cusco bar copy and pasted from the website
http://www.cuscousainc.com/vehicle-r...&modelname=475
Sway Bar
- 20mm 174% Solid - OE 18mm OD Solid
- w/Bushings
$294.00
Part Number
965 311 A20
Position: Front
Sway Bar
- 14mm 73% Hollow - OE 14mm Solid
- Use OE Bushings & Bracket
$267.00
Part Number
965 311 B14
Position: Rear
Sway Bar
- 16mm 168% Hollow - OE 14mm OD Solid
- w/Bushings
$267.00
Part Number
965 311 B16
Position: Rear
Sway Bar
- 16mm 79% Hollow - OE 18mm Solid
$294.00
Part Number
965 311 A16
Position: Front
The Following User Says Thank You to solidONE For This Useful Post:
Mikepage (02-19-2014)
Old 02-19-2014, 12:06 AM   #60
Mikepage
Mikepage's Avatar
I don't know I take the info from the web...
I know, it's a little bit weird.
o= FR-S =o
Old 04-23-2014, 11:39 PM   #61
Mikepage
Mikepage's Avatar
First Post updated with Cusco Spec!
ST added also.
o= FR-S =o
Old 04-24-2014, 11:21 AM   #62
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Don't be mad bro we are here to learn, I don't have any problems to say when am wrong.
Could you show to us? Then you will probably inform users correctly.
I want to understand what is the difference between an solid and an hollow bar.
I don't think it's enough big to really see the difference on the street and also maybe on a race track. I mean the difference between the 2 bar types.
I am pretty sure if you try both, hollow and rigid, you will probably not see any differences. It's only about how much the bar are more stiffness then the oem. Example, if you have the same % of stiffness between an hollow and an rigid bar then this is the same thing.
We say the same thing
I just want to say, look at the % of stiffness you want to add on your car and make your choice from this.
http://www.me.mtu.edu/~mavable/Book/Chap5.pdf
pdf warning
it has all the mechanics of materials and kinematic information you need to develop the proof yourself. FYI: your "engineering" friend is an absolute moron.
sincerely,
a mechanical engineer
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Mikepage (04-24-2014)
Old 04-24-2014, 11:30 AM   #63
Mikepage
Mikepage's Avatar
Sorry, my engineer friend? About which friend do you speaking about?
And I have also say :Originally Posted by Mikepage
Then what is the problem?
o= FR-S =o
Old 04-24-2014, 11:38 AM   #64
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
There is no problem on your side. You asked for an explaination and I provided.
Im making the statement your engineering friend is incredibly ignorant with mechanics and kinematics and should never be referenced for this topic again.
Probably all after market bar are hollow.
Anyway no difference between solid and hollow on the stiffness, I agave talked with my friend engineer.
Old 04-24-2014, 11:40 AM   #65
Mikepage
Mikepage's Avatar
But I never mentioned a friend engineer?
o= FR-S =o
Old 04-24-2014, 11:44 AM   #66
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
You edited this post: http://www.ft86club.com/forums/showp...5&postcount=26
to remove this quote:
Im assuming you edited it because you were lying about legitimately talking to anyone about it.
Old 04-24-2014, 11:52 AM   #67
Mikepage
Mikepage's Avatar
Sway bar option list
I don't lie, I just modified it because maybe we are wrong that's it!
Anyway, the goal of this discussion is to regroup all available sway bars.
o= FR-S =o
Old 05-12-2014, 08:02 PM   #68
barabia
barabia's Avatar
Can this thread get stickied? Ive found myself digging for it a lot over the past couple months lol
barabia is offline   Reply With Quote
The Following User Says Thank You to barabia For This Useful Post:
Mikepage (05-12-2014)
Old 05-12-2014, 08:18 PM   #69
Mikepage
Mikepage's Avatar
Good idea! But I can't do it unfortunately...
o= FR-S =o
Old 08-22-2014, 12:20 AM   #70
Mikepage
Mikepage's Avatar
Bump for members who search the right sway bars!
o= FR-S =o
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
Leather Option. l0aded Scion FR-S / Toyota 86 GT86 General Forum 20 03-02-2013 08:59 PM
Diffuser Option on the BRZ Markone AUSTRALIA 25 01-14-2013 03:21 AM
Scion FR-S Option list Crashoverride Scion FR-S / Toyota 86 GT86 General Forum 38 04-18-2012 03:37 PM
Considering this as another option 2011 WRX Draco233 Other Vehicles & General Automotive Discussions 5 04-01-2012 10:01 PM
