#29 | |
Drives: Toyota 86
#30 |
Drives: 1992 Nissan Skyline GTS-t Type-M
Thanks for the pic. Looks like I should be able to do the exact same thing but just stop at the second T since I only have the vacuum/boost gauge.
#31 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#32 |
NASA SpecE30 Racer
I would call that "before the check valve", but I guess that is semantics, haha. I envision the vacuum going from the intake manifold to the brake booster making the Tee before the check valve. You can Tee off anywhere that sees boost for your boost gauge. That can be the brake booster line or the line you already have Teed off the brake booster line. This is one of the reasons I prefer a vacuum manifold so you don't end up with tons of Tees and more failure points. I also prefer getting the vacuum from the PCV hose and leaving the brake booster hose alone, but I ran a vented catch can so I didn't need the PCV hose off the intake manifold any longer.
- King Tut
#33 |
Well I guess I'll have to check it again. I'm getting like -20 on idle and then it goes up to only like 1psi when I really get on it..
#34 |
Drives: 4Runner
I found the check valve. It's exactly where the above diagram shows. It's easily seen if you're looking for it. A slight swelling of the hose. So my T Fitting is between the engine and check valve.
diirk
waiting on a Neptune Premium MT |
#35 |
Drives: Toyota 86 TRD Version AT
Yes. That will work. I did mine exactly like @HRTROB.
You normally get 0 boost at 50% throttle and get full boost (9psi with stock pulley) at redline.
#36 | |
| The Following User Says Thank You to FyeaFRS For This Useful Post: | Tye300 (05-11-2014) |
#37 |
Drives: Scion FR-S
Don't mean to revive a dead thread but the information here is the best I could find regarding the boost gauge installs on the FRS and I'm having some issues with mine. I tapped into the brake boost line between the engine and the check valve for my Defi boost gauge. But when I'm driving I always see -30psi unless I press the brakes. If I press the brakes repeatedly the boost rises, then drops back down to -30psi. Could someone give me a pointer to what I did wrong?
I circled the check valve on the line for clarity.
#38 | |
#39 | |
Drives: Scion FR-S
That vac line only runs about 6 inches from the T to the sensor
#40 |
Drives: Scion FR-S
I posted a video to show what the gauge is doing:
#41 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Really hard to say because the install looks good.... maybe a bad gauge or sender unit?
#42 |
Drives: Scion FR-S
| Vortech Supercharging System Update - More boost, more POWER! | Brian@Vortech | Forced Induction | 337 | 03-12-2016 03:42 PM |
| DIY - Defi 60mm Boost Gauge Install in AC Vent | msile | DIY (Do-It-Yourself) Guides | 55 | 02-27-2016 01:10 PM |
| Which boost gauge? | Bigmaxy | Forced Induction | 3 | 07-07-2013 07:11 PM |
| Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge | Tubano-shop | Interior Parts (Incl. Lighting) | 0 | 05-27-2013 07:47 AM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 04:29 PM |
