Old 05-09-2014, 02:02 PM   #15
wparsons
wparsons's Avatar
Apparently AD08R's are plenty happy with a 245 on a 7" wheel as well, and are probably a tire you should be considering for autoslalom.
flickr
Old 05-09-2014, 03:09 PM   #16
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Originally Posted by SeanRTR View Post
You sound like the robotic dude
I just shared the official information without expressing opinions. I'm sure you can do it your own way, maybe even fit BMX wheels to your car to prove you're not "robotic". Good luck.
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
The Following User Says Thank You to maxjedi For This Useful Post:
STV3 (05-09-2014)
Old 05-09-2014, 03:23 PM   #17
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
hardparkers gonna park
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
cactus (05-09-2014), itzmik3 (05-09-2014)
Old 05-09-2014, 04:29 PM   #18
TrqlessWonder
Drives: 2014 FR-S
Originally Posted by FRStock View Post
I know everyone runs RPF1s but what about Kosei K1 TS? The OZ wheels are just too expensive but the K1s are even cheaper and lighter than the RPF1s.
Forgot to add to the wheel lexicon. I'm on Motegi SP10. From the factory, they were +40, which were legal on the civic.
To use them on the FR-S, I had a machine shop change the offset to +42. The wheels are $125-135 each, and machining was $250 to do two sets of wheels. 17lbs each, you'd be hard-pressed to do better than that for less money. If I'm not mistaken, those wheels are also available as a +48, so then you're just into adding spacers, which I imagine is cheaper than machining.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 05-09-2014, 05:02 PM   #19
iaclimber4
iaclimber4's Avatar
Drives: 2013 Whiteout FR-S MT
Does anyone have pictures of the 245/40 on a 7" wheel? I saw something in CS discussion group however I did not see anything that was mounted on the car. The more the merrier, just trying to gauge things from different angles...Thanks
iaclimber4 is offline   Reply With Quote
Old 05-09-2014, 05:42 PM   #20
xwd
These Velox rims are cheap and light, not sure about their actual availability though.
http://www.phantasmusa.com/vevx17x704gu.html
Old 05-09-2014, 05:43 PM   #21
xwd
These Velox rims are cheap and light, not sure about their actual availability though. They are about 15.4lbs in 17x7.
Old 05-09-2014, 05:53 PM   #22
renfield90
The Stig's German cousin
http://www.ft86club.com/forums/showp...&postcount=976
Edit: not mounted on the car but it doesn't look wide enough to cause fitment issues.
Old 05-10-2014, 11:58 AM   #23
FRStock
Drives: 13 FRS
Now where to buy RPF1's. TireRack is out until July.
FRStock is offline   Reply With Quote
Old 05-10-2014, 12:37 PM   #24
rx3
I have 245/40 hoosiers on mine. My wheels are +42, and sitting in grid I can just squeeze a finger tip between the tire and the spring.
Just curious: Is this with or without crash bolts?
rx3 is offline   Reply With Quote
Old 05-10-2014, 01:20 PM   #25
TrqlessWonder
Drives: 2014 FR-S
That is with the factory crash bolts.
-Mike
#24 CS/CSR
The Following User Says Thank You to TrqlessWonder For This Useful Post:
rx3 (05-10-2014)
Widest tire to fit on an 18x9.5 Wheel?!!! ** ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 07-07-2014 04:08 PM
Whats the biggest/tallest/widest tire you have on 17/8 wheels? NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-14-2013 09:36 AM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
What is the widest tire for these wheels? ngabdala Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 09-12-2012 09:20 AM
Widest rear tire for a staggered setup? Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-22-2012 08:52 PM
