| Software Tuning Discuss all software tuning topics. |
#43 |
Drives: 2015 WRX
What should it be reading shiv? I've got several occurances of it going from 0 to 100 on logs I've taken since the update. A01C calID here.
#44 |
Drives: WRB BRZ
#45 |
Troll Hunter
Drives: fr-s, tundra
Hey @shiv@vishnu I am considering permanently mounting my OFT so that I could easily log things, if needed.
I have an ultragauge that I use, so I'll be drawing a couple of comparisons to that. 1. The ultragauge, although is always drawing power, turns to "off mode" when the car is off. So there is no display lit up. Therefor, you'll have no need to unplug it whenever you get out of the car. Is there any feature on the OFT that I have overlooked that would let you do this? I was thinking it could work like, once the ignition is off, the OFT powers down.. but if you tap it, it wakes back up (lets say, if you were tuning, etc.) 2. The ultragauge also has a predetermined instrument panel set up, so every time it turns on, it just takes you to the gauges you'd like to look at. Any way we could see something like this for OFT? Like, it automatically takes you to AFR screen on start maybe? I love the idea of replacing gauges with the OFT, but if you really want to constantly monitor things as you could with a real gauge, I think these things would be limitations for me. Would love to hear back from you on what the current plans are, or if I'm missing anything thanks shiv, also hope you've had/about to have a great wedding
#46 | |
Drives: '13 BRZ
| The Following User Says Thank You to uRBAN_Metal For This Useful Post: | 86-tundra (05-07-2014) |
#47 | |
Drives: '13 Whiteout FR-S (M/T)
| The Following User Says Thank You to 1Cor10:23 For This Useful Post: | 86-tundra (05-07-2014) |
#48 | |
Drives: 2013 BRZ Premium 6MT
i still get either 0 or 100 on 700c rom. @shiv@vishnu any updates on this? also any news on getting the original rom file upgraded? all my attempts to get the dealer to update mine have failed.
2013 Subaru BRZ Premium 6MT -STOCK!
#49 | |
Drives: 2013 Scion FRS
I used some shaping foam and industrial Velcro to mount it in the left air vent but it's not the best solution. I do like the location though.
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#50 |
Check my build thread in signature, essentially 3M 'velcro' tabs to manage cables and iMagnet mount for OFT itself. If we get an on/off for OFT I'll be moving where I'm currently mounting the iMagnet so that it's not on the door - possibly the A Pillar or close by.
#51 |
Drives: 2013 FRS
I don't recommend opening the OFT case to install your own on/off switch. The enclosures don't open and close very easily at all. A better solution would be to implement a switch in the harness itself. At least this way you are only fiddling with a cheap cable and not the tablet itself. The risk with an on/off switch is accidentally killing power during a write process. So make sure the switch you make is solid. Another, possibly better option, would be to intercept the 12v power line just upstream of the OBD2 plug, extend it, and add a dash mounted switch there. I like that idea more myself as it would make it impossible for anyone (even the dealership) to flash your ECU with the OBD2 12v power killed
![]() Cheers, shiv |
#52 | |
Troll Hunter
so I then take it what was mentioned in my earlier post is not in the plans for current open flash development?
#53 |
Drives: 86 GT MT
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| Can you run ecutek data logging on a samsung windows tablet | Frs32907 | Software Tuning | 10 | 02-09-2016 11:30 PM |
| OpenFlash Tablet: Enhanced Data Logging (Sneak Peek) | Shiv@Openflash | Software Tuning | 51 | 06-03-2014 08:09 AM |
| FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 12:12 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 10:05 AM |
