Old 05-07-2014, 12:19 AM   #687
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
yeah an moss is 300...and it just happens to be one of, if not the best, combined for the street and track/auto-x tire.
and 255/40 is HUGE sidewall imo...that looks massive
Jive Turkey is offline   Reply With Quote
Old 05-07-2014, 11:40 AM   #688
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Silver Ignition View Post
Yeahh I think it's gonna be a 17x9 +35 with 245/40 tires...10mm short of being "meaty"
Originally Posted by Jive Turkey View Post
its meaty enough! just as long as its not stretched on the rim you're good to go
245 on a 9" rim should have a nice looking bulge to it, not sure what tire I want to run...I'm a Michelin fan so PSS sounds good to me but I want a higher treadwear number becausedailydriver so I'm thinking Bridgestone S04 Pole Position
Grand Meat Master Jive hath spoken and a new era of 245 tire acceptance for meaty consideration has begun!
Allow me to welcome myself into your midst of meat.
17x9 +42 Mach V Awesome's
245/40/17 Bridgestone RE-11A
Compared to stock: no stretch, no bulge, 100% lean meat.
Whiteline top mounts add enough negative camber for safe OEM lower spring perch clearance.
Lowered 22mm on RCE Yellows. No rub on and off track.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Ammonia (05-07-2014), Silver Ignition (05-07-2014)
Old 05-07-2014, 11:53 AM   #689
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Do these top hats have any adjustments, or are they just bolt-in negative camber? Looking at the pics of them, they look solid...weird...
Also, would I run into issues without them? Stock Struts and S-Techs.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 05-07-2014, 12:08 PM   #690
ATL BRZ
ATL BRZ's Avatar
The Whiteline Com-C top mounts aren't adjustable but they add negative camber and a bit of caster as well. They are high-durometer rubber and have bearings in the middle. I do not recommend them as they have caused issues for many people here including myself when running them with the OEM struts, which have a welded flat washer on top of the upper spring perch that doesn't play nice with the camber angles provided by the mounts. A conical washer is needed but Whiteline refused to admit that even after doing a bunch of warranty replacements with bearings destroyed by OEM upper spring perches and then shortly after all the Com-C's disappeared from the 86 market.
More on that here: http://www.ft86club.com/forums/showthread.php?t=26146
With 245's on a 17x9 +35 wheel you shouldn't have any clearance issues. You may be able to run OEM camber bolts with stock strut top mounts without rubbing but be sure to double check everything before assuming it's ok.
Hicklinc (02-09-2018), Silver Ignition (05-07-2014)
Old 05-07-2014, 01:05 PM   #691
loogs
Drives: on cruise control
i will be in here next week 265/35/18's going on
loogs is offline   Reply With Quote
Old 05-07-2014, 01:44 PM   #692
loogs
Originally Posted by mike the snake View Post
I'm running the same size and offset with 265 Michelin PSS tires (which I've read run a little big for their size) in the rear. They fit perfectly flush and no rub after grinding the little fender rivet tabs down, takes 30 seconds with a dremel.
can you point this out with a picture please?
Old 05-07-2014, 01:57 PM   #693
loogs
Originally Posted by zoth View Post
18x9 255/40r18 all around +38 offset.
woah! what wing is that?
Old 05-07-2014, 03:12 PM   #694
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
[Super Sexy Pics]
Wow, gorgeous car and set-up.
boooooooooooooooooost
Ammonia is offline   Reply With Quote
The Following User Says Thank You to Ammonia For This Useful Post:
ATL BRZ (05-07-2014)
Old 05-08-2014, 12:49 AM   #695
HI
HI's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by gramicci101 View Post
You might find more appreciation in the aggressive wheel thread.
shoot my bad bro. not trying to piss anyone off. I can take the pics down if you like.
HI is offline   Reply With Quote
Old 05-08-2014, 12:53 AM   #696
HI
HI's Avatar
Originally Posted by Ouhei View Post
Why on earth would you think that counts? Also, are there chunks missing on your wheels?
sorry didn't realize this was more of a full tire thread. Thought it was like the aggressive wheel thread.
The wheels are curbed and the paint is chipping, these have been my drift set for two years so they've seen better days.
Old 05-08-2014, 01:08 AM   #697
Amir Ghadiri
Amir Ghadiri's Avatar
Originally Posted by loogs View Post
WOW! what wing is that?
Seibon GD Style Carbon Fiber wing!
Amir Ghadiri is offline   Reply With Quote
Old 05-08-2014, 02:10 AM   #698
Kostamojen
Could you please? Thanks
Old 05-08-2014, 09:29 AM   #699
Silver Ignition
APEXHNTR
rough crowd...
#1867 of 2500
Old 05-08-2014, 12:53 PM   #700
p00mba
p00mba's Avatar
Drives: FR-S :)
rough crowd...
its scary to post in here... feelings get hurt...
p00mba is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
