Old 05-06-2014, 12:39 PM   #673
loogs
Drives: on cruise control
Originally Posted by Amir Ghadiri View Post
Enkei RPF1 18x9.5 +38 Square
265/35-18 Falken RT615K
KW V3 Coilovers
Attachment 73554Attachment 73555Attachment 73556
Attachment 73561Attachment 73560
Attachment 73562
WOW! what wing is that?
loogs is offline   Reply With Quote
Old 05-06-2014, 01:38 PM   #674
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
Anomie is offline   Reply With Quote
The Following User Says Thank You to Anomie For This Useful Post:
Silver Ignition (05-06-2014)
Old 05-06-2014, 01:51 PM   #675
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
275 35 18s all around
JDLAutoDesign is offline   Reply With Quote
Old 05-06-2014, 01:55 PM   #676
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by kalamitykode View Post
I'd mainly do it for looks, but I don't want to sacrifice much performance. I'd do a 35mm offset, or near there. No fender modifications for now. I'm still learning about these things, so all I know about the suspension is that I'd like adjustable height coilovers, with about an inch or 1.5" drop.
there's WAY more to coilovers than height adjustment. start reading!
Originally Posted by Silver Ignition View Post
Thanks dude! I've been leaning towards the 17x9 but 18's look soooo good. It is a good +8-10lbs per wheel/tire assembly going 18's though and I can see that adding up. So should I run a 245 or 255 tire? Also should I be looking at +35 or +45 with 5mm spacers? I have SPC arms in the rear so I can camber them in a little bit but I don't want to wipe the tires out with -3*...I'd like to keep the camber under -2*
you won't need anywhere close to 3. especially if you're not slamming the thing.
the offset depends on what you want it to look like, iirc +45 isn't the concave face anymore so thats your call.
tire depends on brand, so one 245 will be skinny, while another brand will run fat and be as big as a 255...
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
kalamitykode (05-06-2014)
Old 05-06-2014, 02:07 PM   #677
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I want it to look like @Touge Factory 's black car
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following 2 Users Say Thank You to Silver Ignition For This Useful Post:
Hicklinc (02-09-2018), TouchMyHonda (05-07-2014)
Old 05-06-2014, 02:39 PM   #678
Pete156
I like to eat!
I don't think so. The 18x9.5 RPF1s you are considering are probably lighter than the 17" OEM wheels. The tires might be 2-3 lbs more.
Pete156 is offline   Reply With Quote
Old 05-06-2014, 03:15 PM   #679
Jive Turkey
the tuna, no crust.
yeah those are 17x9 +35, but they are on coilovers.
i was worn, +45 is still concave face, can be seen here with a 255 (he is on coils though)
http://www.ft86club.com/forums/showthread.php?t=26257
here is the clearance on the +35, i think you'll be just fine with a 245.
http://www.ft86club.com/forums/showp...3&postcount=26
Old 05-06-2014, 03:15 PM   #680
Jive Turkey
the tuna, no crust.
and here is the clearance issue with a +45 on stock struts, thats too close for comfort.
http://www.ft86club.com/forums/showp...5&postcount=17
Old 05-06-2014, 04:26 PM   #681
Silver Ignition
APEXHNTR
Yeahh I think it's gonna be a 17x9 +35 with 245/40 tires...10mm short of being "meaty"
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
MadFRS (05-11-2014)
Old 05-06-2014, 04:47 PM   #682
Jive Turkey
the tuna, no crust.
its meaty enough! just as long as its not stretched on the rim you're good to go
Old 05-06-2014, 04:57 PM   #683
Silver Ignition
APEXHNTR
245 on a 9" rim should have a nice looking bulge to it, not sure what tire I want to run...I'm a Michelin fan so PSS sounds good to me but I want a higher treadwear number becausedailydriver so I'm thinking Bridgestone S04 Pole Position
#1867 of 2500
Old 05-06-2014, 05:40 PM   #684
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
My 255 toyo r888s look pretty square...kinda lol
Sent from my IBrick
The Following 3 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
Hicklinc (02-09-2018), rookie (02-25-2016), Silver Ignition (05-06-2014)
Old 05-06-2014, 06:06 PM   #685
Jive Turkey
the tuna, no crust.
isn't a pss 300 tread wear?! thats really good for a summer performance tire, mine are 180 TW and have been pretty damn good so far
Old 05-06-2014, 10:07 PM   #686
Silver Ignition
APEXHNTR
isn't a pas 300 tread wear?! thats really good for a summer performance tire, mine are 180 TW and have been pretty damn good so far
Yeah I want something 240+ on treadwear
#1867 of 2500
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
