Old 03-31-2012, 08:32 PM   #57
Ikaros
Solar wind surfer
Ikaros's Avatar
Drives: 2013 FRS
Lol, this kinda makes you wonder how much money they actually saved by removing the push button from the FR-S. Well to be honest it was probably coupled with other stuff like automatic AC.
Ikaros is offline   Reply With Quote
Old 03-31-2012, 10:44 PM   #58
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
it's only standard on the us-spec brz/ltd... i don't know about other countries, but it's an option for all models/trims in japan...
zAnSh1n is offline   Reply With Quote
Old 04-01-2012, 04:40 AM   #59
Kunzite
Drives: Toyota Auris
Originally Posted by LTunedX View Post
The 2 main antennas have a maximum detection range of roughly 5-6 ft. which really is not a lot...I have to stand pretty much right next to my driver's side door for the key to be detected...if you are even a couple inches outside of the antenna's detection range, then you wouldn't be able to start the car
Also, this is also assuming that someone is already in the driver's seat and you're standing literally right next to them....then yes, they could start the car
So, if you're standing next to your car and see someone sneaking inside - run away!
Ikaros: well, for less than 1000 euro I got (IIRC):
- Smart Entry&Start
- auto lights
- auto (rain-sensing) windshield wipers
- auto dimming rear mirror
- Cruise control
- VSC (ESP)
I only wanted the VSC, though... but I found all the others more or less useful.
Kunzite is offline   Reply With Quote
Old 04-02-2012, 03:57 AM   #60
LTunedX
Lexus Enthusiast
LTunedX's Avatar
Drives: L-Tuned IS300
^ to lock your doors while your smart key is in detection range, you can press and hold the LOCK button for 3 seconds to override the smart key function and lock your doors =]
LTunedX is offline   Reply With Quote
Old 04-02-2012, 02:04 PM   #61
Crashoverride
here, there, any where
Drives: FR-S SOON!!!
Well I will buy a subaru try with the button hole and by an aftermarket for my FR-S....walla push button start... now to figure out the HVAC swap...
Crashoverride is offline   Reply With Quote
Old 04-21-2012, 12:23 PM   #62
Ikaros
Solar wind surfer
Ikaros's Avatar
Drives: 2013 FRS
For those of you who are worrying about the possibility of someone hoping in your car and driving away, just get the smart keyless entry by itself. It's only $190 and you get all the convinience, without having to worry about someone else starting your engine.
I'm probably going to get the keyless entry with the auto window closer, cause I love the physical feed back you get when you turn the key when starting your car. Pushing a button to start the car kinda desensitize it for me.
Old 05-04-2012, 08:58 AM   #63
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
I was looking around youtube and I found this, it kinda does the same thing as this alarm but it has more features for around the same price.
http://my350z.com/forum/exterior-and...ty-system.html
[ame="http://www.youtube.com/watch?v=V73QqmkIivk&feature=youtube_gdata_player"]Infiniti G35 alarm ST-800 - YouTube[/ame]
Juanito08 is offline   Reply With Quote
Old 05-10-2012, 03:10 AM   #64
LTunedX
Lexus Enthusiast
LTunedX's Avatar
the ST-800 is made in Korea...and the parts are not of high quality
customer service is pretty much non-existent...and I hear the 2-way remote has a poor battery life....it lasts about 2 days before you have to recharge
Old 05-17-2012, 06:59 PM   #65
Carson Toyota
Carson Toyota's Avatar
Drives: Scion/Toyota
Originally Posted by zAnSh1n View Post
i thought of this as well, but i am not sure if that portion [yellow] of the bezel is a separate piece, or if it's all connected with the hvac section... either way, i don't think i like that placement very much anyways, so i will most likely mount the button where the seat heater toggles go in the brz [green], since i'm getting an fr-s and there is just a blank panel there...
This part is avaialable seperately from the entire HVAC panel, so the only thing im not sure of is if its the same part# as the Subaru one. If it is then you can just order from any US subaru dealer since that option is available. If not then we can order these from Japan.
you can see the part here in this pic, its highlighted in blue. you can see that it is seperate from the hvac controls
Carson Toyota is offline   Reply With Quote
Old 05-19-2012, 01:37 PM   #66
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
what? i don't see any pic...
Old 05-19-2012, 02:37 PM   #67
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
My wife's Prius has the OEM proximity/push button and I'm still not used to it yet. I always want to turn a key when I turn off the car. The system is pretty awesome, and it makes you want everything else to be keyless; like your house and work.
It might have been said already but I think an OEM proximity entry and push button start will be WAY too expensive on it's own.
Just the key is between $200-300.
Figure the cost of dealer parts and labor (even by a stereo shop) and I'd assume you'd be looking at at least $1000-$2000.
It makes the Advanced Keys system look like a steal.
If the OEM one could be done for under $1000 (like if I do the work myself) I'd strongly consider it...
86'd is offline   Reply With Quote
Old 05-19-2012, 02:44 PM   #68
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Me either. I see a piece highlighted in red, but not blue.
kmbkk is offline   Reply With Quote
Old 05-19-2012, 02:46 PM   #69
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
those pix are quoted... he forgot to link to the pic he is referring to...
Old 05-20-2012, 06:20 PM   #70
mr2lor
Drives: 2013 Scion FR-S Asphalt MT
Anyone use this before?
http://www.digitalguarddawg.com/KEYL...-FEATURES.html
mr2lor is offline   Reply With Quote
FRS Ignition Key ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 120 07-22-2014 09:23 PM
push button start standard? sparrowhawk BRZ First-Gen (2012+) — General Topics 2 03-04-2012 03:52 PM
Push button start general question maxeveland Other Vehicles & General Automotive Discussions 9 02-14-2012 10:13 AM
No push button start a good thing? Syldrin Scion FR-S / Toyota 86 GT86 General Forum 130 12-13-2011 07:06 PM
