Old 05-06-2014, 02:35 PM   #15
OrbitalEllipses
Drives: Attitude
My apologies! I clearly did not read.
1101 is a Universal Adapter Kit that you will have to tighten with wingnuts and such, but should work fine once you've done that. This is what Motive itself suggests.
Old 05-06-2014, 04:31 PM   #16
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
The universal adapters work fine, I use the round one on the master cylinder. Just make sure you test for a good seal by pressurizing the bleeder without fluid first.
Scenic Driver is offline   Reply With Quote
Old 05-06-2014, 05:07 PM   #17
celica73
Mine works fine, getting the Motive cap on the MC has always been a bitch.
that was my experience. It was tight as a... never mind.
Old 05-06-2014, 06:13 PM   #18
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
A little tip for anyone using one of these: You can do this without putting the brake fluid in the bleeder. Just use it to pressurize. You will need to refill the reservoir a few times to fully flush the calipers, but it is far less time consuming to do that compared to cleaning out the whole thing, or risk contamination if the last guy who used it didn't clean it properly.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
gdrider77 (06-27-2014)
Old 08-19-2014, 01:31 AM   #19
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Motive Power bleeder adapter part number?
@supramkivtt2jz @OrbitalEllipses @JDKane527 @moto-mike
I came across this thread and ordered the following bleeder from Amazon:
[ame="http://www.amazon.com/dp/B0002KM5ME/ref=pe_385040_30332190_TE_dp_2"]http://www.amazon.com/dp/B0002KM5ME/ref=pe_385040_30332190_TE_dp_2[/ame]
The Model number of the Bleeder is (0107) but on the adapter it says (1107),, It seems like adapter is not compatible and the cap won't stay on the reservoir..(Brakes fluid)
Has anyone else had the same issue?
glamcem is offline   Reply With Quote
Old 08-19-2014, 03:21 AM   #20
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Do you push down all the way before rotating to get it to seal? The pn sounds correct, check the adapter mounting tabs to make sure they are in good condition.
If you can post a picture of the adapter that may help.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
glamcem (08-20-2014)
Old 08-19-2014, 04:16 AM   #21
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
The part numbers are correct. It could be the o-ring being too thick. I think they also supply a thinner o-ring so that you can press the cap down far enough to twist and lock.
Fizz is offline   Reply With Quote
Old 08-20-2014, 04:18 AM   #22
glamcem
glamcem's Avatar
I will do that for sure
I am not sure I tried without the o-ring but still no luck..
Would you be able to take a picture of the adapter with and without o-ring?
Old 06-04-2015, 12:21 PM   #23
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
There is also a 0117 kit. It has a metal cap versus the plastic cap. I've emailed Motive regarding the differences and the metal cap unit is supposed to be better and if you plan to bleed more frequently then occasionally, it's the way to go.
Myself, we have a track car and hope to be adding a second to the stable soon. We try to bleed brakes after each track day and will do a full flush once a year (at least). I'm leaning towards the 0117.
G_Rossney is offline   Reply With Quote
Old 06-04-2015, 01:09 PM   #24
JDKane527
JDKane527's Avatar
Info on the dry method:
http://rennlist.com/forums/993-forum...ethod-use.html
I've been using the dry method for some time and find it way easier to do. The brass coupling was the source of leaks, so I cut it off and replaced it with a quick disconnect couplings.
Old 09-25-2017, 11:13 PM   #25
Quanye
just did a research,
adapter 1107 is the way to go
Amazon is selling it too
Quanye is offline   Reply With Quote
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-15-2022 11:38 PM
Motive Brake Bleeder Adapter xman11 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 02-23-2013 10:24 AM
Motive Autowerks Master Cylinder Group Buy as low as $40 Turn in Concepts Groupbuys 23 01-04-2013 06:03 PM
Motive Autowerks Master Cylinder Brace ONLY $60 Turn in Concepts Brakes, Suspension, Chassis 0 12-28-2012 09:15 AM
Motive Autowerks Master Cylinder Brace ONLY $60 Turn in Concepts Brakes, Suspension, Chassis 0 12-27-2012 04:00 PM
