Old 11-27-2012, 03:07 PM   #1
xman11
Drives: Brz, R53
Motive Brake Bleeder Adapter
Has anyone used the Motive Brake Bleeder on their FRS/BRZ?
If so, do you know if adapter 1107 is the correct one?
I found this application guide online but it wasn't car model specific.
http://www.motiveproducts.com/files/...on%20Guide.pdf
xman11 is offline   Reply With Quote
Old 01-10-2013, 11:25 AM   #2
schtebie
Drives: CBS BRZ Limited
Bringing this back from the dead.
I'm curious to know as well.
schtebie is offline   Reply With Quote
Old 01-10-2013, 07:39 PM   #3
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
I believe it is. I have the bleeder and I'm pretty sure that 1107 adapter that worked on my Z will work on the twins. I'll check for you this weekend.
n8dog11914 is offline   Reply With Quote
Old 01-10-2013, 07:43 PM   #4
OrbitalEllipses
Drives: Attitude
1107 worked on my WRX; I can also check this weekend.
Old 01-15-2013, 07:52 PM   #5
schtebie
Were you able to check this weekend?
Old 01-15-2013, 10:01 PM   #6
Squishy
Drives: 2013 WRB BRZ
The Subaru three prong neck on our master cylinder is compatible with the ford adapter aka 1107 adapter / 0107 full kit (first number with 1 denoting only the adapter and 0 for the full kit).
This is what we need to use with the motive bleeder. Since I had one I used for my vette, I had to look this up as well to get the adapter for my BRZ.
So if you have the tank already then you only need the 1107 adapter.
Squishy is offline   Reply With Quote
Old 01-16-2013, 06:15 PM   #7
n8dog11914
n8dog11914's Avatar
Hey Schtebie,
I checked tonight and the 1107 definitely works. It is the three prong type and fits correctly.
Old 02-23-2013, 02:29 AM   #8
eckoflyte
Drives: Toyota 86 GTS
0107 kit, or 1107 adapter will work.
just used mine for the first time. will never use anything else ever again. i use the dry method flushed the complete system with 1L of fluid in 20 min. painless.
this absolutely kills the 2 person method, just makes it so much easier.
eckoflyte is offline   Reply With Quote
Old 02-23-2013, 10:24 AM   #9
xman11
Drives: Brz, R53
Thanks for confirming.
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-15-2022 11:38 PM
Antenna Adapter Alternatives solution Electronics | Audio | NAV | Infotainment 20 08-24-2020 10:52 AM
WhereToBuy: MAF Adapter empower-auto Engine, Exhaust, Transmission 5 06-08-2013 02:09 PM
Motive Autowerks Master Cylinder Group Buy as low as $40 Turn in Concepts Groupbuys 23 01-04-2013 06:03 PM
