Old 04-01-2013, 07:00 PM   #1
THEmailman
Drives: Raven 6MT
Motive Power Bleeder
I am looking at getting one of these to make bleeding easier but have a question on fitment. Does anyone know the part number or what adapter is needed to allow use of this? Anyone have it that can point me where they bought it would be great too. Not sure if Subaru or Toyota designed the master cylinder or if it is unique for each car ( I have an FR-S).
Thanks!
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 04-01-2013, 08:37 PM   #2
OrbitalEllipses
Drives: Attitude
Subaru/Evo/Z fitment master cylinder adapter is the one you want.
Huehuecoyotl (04-01-2013)
Old 04-01-2013, 09:04 PM   #3
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
So glad I got myself one of these...
Huehuecoyotl is offline   Reply With Quote
Old 04-01-2013, 09:13 PM   #4
B L U E S L A T E
Drives: BMW E84
Been using this for years with my other cars... it makes life so much easier.
B L U E S L A T E is offline   Reply With Quote
Old 06-27-2013, 09:00 PM   #5
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Has anyone had problems getting their cap to seal properly on the brake fluid reservoir? I had the same 1107 adapter that I used for my old 350Z, but the cap isn't sealing correctly for the BRZ. I tried replacing the o-ring and that still didn't help. Any suggestions?
Thanks,
n8dog11914 is offline   Reply With Quote
Old 06-27-2013, 09:16 PM   #6
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Thanks,
I was having the same issue as well. When I was checking for leaks the PSI would always slowly go down to below 5PSI. The solution I used was to pump to 13PSI and then bleed a caliper and then check and pump back up if it goes down.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 06-27-2013, 09:41 PM   #7
n8dog11914
n8dog11914's Avatar
I am having trouble even getting it up to around 10 psi to start. I can't even walk away from it before it drops to 0. It had no leaks before and I'm fairly certain the cap is on their fully.
Old 06-27-2013, 09:44 PM   #8
OrbitalEllipses
Drives: Attitude
Mine works fine, getting the Motive cap on the MC has always been a bitch.
Old 06-28-2013, 01:25 AM   #9
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Maybe the threading on the cap is wrong or cross threaded? They are both plastic. Can you hear where the pressure is escaping?
Old 06-28-2013, 04:02 AM   #10
buckets
buckets's Avatar
Drives: infiniti g37x
i had the brass coupling crack on me not to long ago, might wanna check that.
buckets is offline   Reply With Quote
Old 07-02-2013, 06:28 PM   #11
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
i can verify ford master cylinder caps are the exact same as what is on our car
supramkivtt2jz is offline   Reply With Quote
Old 05-06-2014, 03:27 PM   #12
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Has anyone been able to find an adapter to fit on the clutch master cylinder reservoir cap?
JDKane527 is offline   Reply With Quote
Old 05-06-2014, 03:32 PM   #13
OrbitalEllipses
Drives: Attitude
As previously stated the 0107 model (350 Z, other Jap imports) works fine. I have used it several times, just like on my old Subaru, with NO issue.
If you already have a pump, but with a differet MC adapter then the Ford Racing adapter will work.
Old 05-06-2014, 03:34 PM   #14
JDKane527
JDKane527's Avatar
I realize the 0107 is for the BRAKE and I have already ordered one. My question is about the CLUTCH.
The Following 2 Users Say Thank You to JDKane527 For This Useful Post:
OrbitalEllipses (05-06-2014), RedReplicant (12-09-2022)
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-16-2022 12:38 AM
Motive Brake Bleeder Adapter xman11 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 02-23-2013 11:24 AM
Motive Autowerks Master Cylinder Group Buy as low as $40 Turn in Concepts Groupbuys 23 01-04-2013 07:03 PM
Motive Autowerks Master Cylinder Brace ONLY $60 Turn in Concepts Brakes, Suspension, Chassis 0 12-28-2012 10:15 AM
Motive Autowerks Master Cylinder Brace ONLY $60 Turn in Concepts Brakes, Suspension, Chassis 0 12-27-2012 05:00 PM
