Old 05-05-2014, 04:03 PM   #1
Dezoris
Dezoris's Avatar
Trail Braking and Rotation Questions
So just finished first two autox.
First weekend in FRS (RS3) and second in S2000. (RS3v2)
Totally different cars but one thing that bothers me is while the FRS is far more stable in the rear and putting power down is rarely an issue, I cannot get the car to trail brake with or without pedal dance
In terms of autox I'd say it critical.
So without changing much what are my options?
  • Firm up rear rebound of shocks?
  • Less rear toe?
  • Rear sway bar?
  • Brake Pad choices?
(If you had any questions about switching to the Sony Action Cam the S2000 video should convince you.)
S2000 Run:
[ame="https://www.youtube.com/watch?v=mnhplGM2F38"]S2000 Autox Test Hankook RS3 v2 | In Car Only - YouTube[/ame]
FRS Run:
[ame="https://www.youtube.com/watch?v=aDWA8YeknWY"]Supercharged FRS BRZ Autox Test | In Car Only - YouTube[/ame]
The Following User Says Thank You to Dezoris For This Useful Post:
Anthonytpt (05-06-2014)
Old 05-05-2014, 04:11 PM   #2
juliog
juliog's Avatar
Drives: 86
Do you mean the car is still actively messing with your braking or?
Also I see you are running RS v2, noticed any difference relative to v1 so far?
juliog is offline   Reply With Quote
Old 05-05-2014, 04:17 PM   #3
Dezoris
Dezoris's Avatar
I don't feel the car interfering, it just feels like there is no rear brake bias or the rear won't unload enough to trail the ass around. Should I soften the rear?
The v2s got up to temp fast and did not have that rubbery feel to them like the old tires did when cold. But once the temps rose the tire pressures jumped almost 8PSI. (50F to 65F Outside) I had to keep the pressures low to keep them from feeling slippery.
Since I am still near full tread depth and its only my first autox on them, it's hard to make any conclusions. They are still a fast tire but for me they felt more slippery in the heat. Thats not scientific and I dont have track time on them yet.
Old 05-05-2014, 06:59 PM   #4
juliog
juliog's Avatar
Drives: 86
Running same pads F/R?
Old 05-05-2014, 10:25 PM   #5
CSG Mike
CSG Mike's Avatar
What year AP2? Stock suspension?
S2k's have a slight rear bias
Old 05-05-2014, 10:30 PM   #6
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Sure does look good. That image stabilization is remarkable.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Old 05-05-2014, 10:46 PM   #7
Dezoris
Dezoris's Avatar
Actually no and thats one thing I am going to change before this weekend to test. Currently it runs HawkHP Front (supposedly worse than stock) and OEM rear.
For this weekend going to 1521 squared.
Completely stock car, aside from modified alignment, RS3 tires 225/255s. Carbo1521s Squared from you and old Centric Cyro Blanks Front.
2005 MY. (Pre DBW and TCS non-sense.)
If you saw how much the camera was vibrating on the mount its crazy how well it works. It does cut into the sharpness of the image but for car videos I will take loss of that over having stable footage.
Old 05-05-2014, 11:08 PM   #8
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Let's see you have wider tires in the rear than the front and you have more brake pad up front but oem in the rear. I have no idea why it won't rotate.
You should have stuffed the 255s up front
Element Tuning is offline   Reply With Quote
Old 05-05-2014, 11:25 PM   #9
Dezoris
Dezoris's Avatar
That was the S2000 tire specs.
FRS has 235 squared.
Old 05-05-2014, 11:45 PM   #10
icemang17
Drives: Scion FR-S/ Subaru BRZ
interesting....I find my FRS quite loose.....almost too much really....but the stock tires don't help either.... If you need more rotation you can adjust tire pressures by increasing the end you want less traction, but that could hurt putting power down too
You could try aligment....a touch more toe out up front should help rotate the car...or less toe in out back
icemang17 is offline   Reply With Quote
Old 05-06-2014, 12:37 AM   #11
rice_classic
Take off the front sway bar. If you're trying to induce rotation with trail braking and it's not happening then you can make the front work better or the rear work worse. It's RWD so don't make the rear work worse. Take off front sway which should allow the front to work its contact patch better. Also make sure you have enough camber to maximize front contact patch. The S2k has a pretty aggressive dynamic camber gain up front, the FRS has almost none so it will probably need more static camber to do the same thing.
Without going into a technical dissertation on shocks and springs I will just say, set your shock valving to accommodate spring rate, after that leave them alone. Do your setup aydjustments with ride height, spring rate, sways and alignment.
PRO86 | WTCC | STL
Old 05-06-2014, 09:40 AM   #12
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
What swaybars are on the car now? What are the spring rates on the Ohlins? Defiantly use same pads front and back.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 05-06-2014, 11:59 AM   #13
CSG Mike
CSG Mike's Avatar
Is your FRS loose, your steering input too rough, or are you just too aggressive with the gas?
The FRS understeers at terminal cornering speeds, regardless of tires. If *just* a tire change magically eliminates your oversteering, then the oversteer was driver induced; you don't change the balance or dynamics of the car with just a tire change.
WillRacer1jz (06-18-2014), wparsons (05-06-2014)
Old 05-06-2014, 02:12 PM   #14
Dezoris
Dezoris's Avatar
I will attempt to disconnect it, if going with square pads don't do anything.
I feel like the damper settings are very good. I have a tone of grip and stability. I attached my alignment, with my driver weight and gear on.
I went back to stock sway bars because Ohlins did all their design with that in mind.
Spring rates are 343lbs all corners.
Tire Rotation Interval Questions HunterGreene Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-03-2016 09:40 PM
Traction light flashing under trail braking; TC and VSC are both off... CSG Mike Tracking / Autocross / HPDE / Drifting 72 06-12-2016 08:18 AM
Tire rotation scionfrs2014 DIY (Do-It-Yourself) Guides 3 04-30-2014 05:12 PM
Trail of the Dragon L3P47 Mid-Atlantic 12 02-08-2013 01:47 PM
Light flashing under trail braking. CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-16-2012 04:10 PM
