Old 08-14-2012, 04:22 PM   #1
Light flashing under trail braking.
The light next to the shift light in the upper right of the tach flashes whenever I try to trail brake. The same light stayed on solid when our BRZ was on the dyno, and went off as soon as we started driving normal after the dyno session, so the light is definitely directly related to wheel speeds/wheel speed sensors.
I have both traction and stability control fully off. Does anyone know how to eliminate this? It's interfering with trail braking, and forces the car to understeer instead of rotating the car how I want it to.
*disclaimer* this is for track use.
Old 08-14-2012, 05:32 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
Did you hold the TC button down for 5 seconds? When I did that I was free to do as I please
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-14-2012, 08:17 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
This.
When all the nannies are shut off you should see TRAC OFF lit, the slipping icon lit, and VSC SPORT should not be lit.
Old 08-14-2012, 09:16 PM   #4
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
If it's turned fully off you can do as you wish. It will still light up but won't interfere.
ill86 is offline   Reply With Quote
Old 08-14-2012, 10:38 PM   #5
Originally Posted by Draco-REX View Post
This.
All nannies are off. The "slip" light is still coming on under threshold trail braking, and the car just plows.
Old 08-15-2012, 12:17 AM   #6
ill86
ill86's Avatar
Drives: iG FR-S
Will it lift-throttle oversteer?
I'm not being a ****.. But you aren't asking for too much steering input are you?
Ie, are you causing understeer?
Old 08-15-2012, 12:21 AM   #7
ill86
ill86's Avatar
Drives: iG FR-S
Maybe it's just the elec. brake controller?
Old 08-15-2012, 08:44 AM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
I haven't tested it yet, but it might flash when the ABS is engaged also..
The only other thing I can think of might be the SSmart Stop or whatever it's called. Are you deep into both the gas and brake at these points on the track?
Old 08-15-2012, 01:26 PM   #9
This was speculated yesterday, and I confirmed that no, it doesn't come on when ABS is engaged. I purposely did a lot of "panic stops" to double check.
No, the car understeers under static load, but this is under trail braking into a corner, not mid-turn.
Yes, I'm "causing" the understeer, but the car is understeering in a scenario where it should be rotating. The understeer is a symptom of the braking system not allowing me to do what I want. If I brake at 90% of the limit of the tires, then I can get more simultaneous rotation and braking out of the car than if I try to brake at 100%.
Old 08-15-2012, 02:28 PM   #10
Draco-REX
Corner Junkie
Draco-REX's Avatar
I'm not sure about the light, that will take some playing around. I'll have to try to remember to see if I can get the light flashing at the next AutoX. It still might be the Smart Stop or whatever. Though trail braking isn't really the place where you'd be hard on both pedals.
As for the car's behavior, perhaps it has a lot more front bias than you are used to? You might be asking too much of the front tires without realizing it. Dunno.
Old 08-16-2012, 10:20 AM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Well, seems like it's the EBD, I'm really surprised and I wonder what it's trying to do.
Old 08-16-2012, 12:44 PM   #12
Mitch
form follows function
Drives: RIP '13 BRZ
One wheel is losing traction and inducing ABS before the others. EBD is trying to bias towards the wheels that are not losing traction to minimize braking distance.
Mitch is offline   Reply With Quote
Old 08-16-2012, 02:39 PM   #13
But the end result is that braking distance is actually increased... we're talking like 30% increased...
Old 08-16-2012, 04:03 PM   #14
03Z33
drift
03Z33's Avatar
I felt this several times yesterday on a bumpy canyon road, I would jab the brake on entry or mid-turn to make a correction and the car would "release" the brakes and point the car straight. Not a good feeling! will have to try pulling the ABS fuse next time to see if that helps.
03Z33 is offline   Reply With Quote
Toxic Detail and Performance, Indian Trail NC Toxic Announcements, Contests, Giveaways 4 07-24-2012 05:13 PM
Turn signal amber LED's flashing quickly michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 11 07-13-2012 10:55 PM
anybody else see the flashing carrot??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 46 01-18-2012 09:25 AM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 12:49 PM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 04:20 PM
