CANADA Canada
Old 05-03-2014, 07:28 PM   #1
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Short shifter, bushings, springs etc. - Does anybody have these?
Hey guys and gals,
I'm thinking about getting a short shifter (likely the Kartboy), which comes with a rear shifter bushing.
The MTEC shift springs are also a possibility.
The reason is simply because I want to enjoy the shift feel as much as possible (the stock unit feels a bit odd after the winter - maybe because I drove on 16s and the gearing was shorter as a result).
However, I'd like to see what your thoughts are (particularly for those who have them installed).
Is this worth doing?
Thanks!
daiheadjai is offline   Reply With Quote
Old 05-05-2014, 01:19 PM   #2
daiheadjai
daiheadjai's Avatar
Nobody has these installed?
Old 05-05-2014, 02:00 PM   #3
wparsons
wparsons's Avatar
Wheel size should have zero effect on shifter feel, but more km's could have made the fluid degrade, or the warmer temps might be changing the feel due to a different fluid viscosity?
When you say you want to "enjoy the shift feel", what exactly do you mean? Do you want to remove any and all slop from the shift mechanism? I find the stock shifter is a tiny bit sloppy in sideways motion, but I'm at ~62k km's. It's WAY less sloppy than other cars I've owned, so I'm not too concerned yet.
I have the whiteline "positive shift kit", but it's still sitting on a shelf in my garage
flickr
Old 05-05-2014, 04:43 PM   #4
daiheadjai
daiheadjai's Avatar
That's a very good question.
As good as the stock shifter is, I find myself wanting to see how much more direct it could be with a short shifter or the springs (like MTEC).
The famous "rifle-bolt feel" so to speak.
It could just be the temps (that makes a lot of sense actually).
The other part of the equation could be my clutch release - I feel like there's more "lurching" or "sloppy" feel on my release than I used to have (maybe I'm the one getting sloppy on technique). Reading on the "rubbery" nature of the stock transmission mount, shift bushings, etc. made me wonder if that could be it (anything to avoid putting the blame on my own technique - for now, anyway).
Old 05-05-2014, 04:45 PM   #5
DAEMANO
Time Traveller
Just got MTEC springs, will post results after install. Maybe a week.
Old 05-05-2014, 04:55 PM   #6
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Get the TRD Quickshifter and call it a day. Gives shorter throws than any short shifter on the market and is $100 cheaper than a Kartboy (which is the only short shifter I'd recommend). Also doesn't have any rattling issues the others seem to have.
xxBrun0xx is offline   Reply With Quote
Old 05-05-2014, 05:07 PM   #7
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I have the Kartboy ss kit, lightweight delrin shift knob, Mtec spring, and all associated shift mechanism stiffening bushings. The transmission feels fantastic, similar to a gated shifter.
However, if you are someone who is overly bothered by NVH, some of the bushings do cause a bit of whine.
Decay107 is offline   Reply With Quote
Old 05-05-2014, 10:04 PM   #8
daiheadjai
daiheadjai's Avatar
I've got the Kartboy crank pulley whine already, so I guess it wouldn't be much difference NVH-wise.
Old 05-05-2014, 10:08 PM   #9
AlphaMotorsports.ca
Drives: Rocket Bunny BRZ, Track FRS
We have the MTEC shift springs in stock and could set you up with the Kartboy short shifter if you wish!
AlphaMotorsports.ca is offline   Reply With Quote
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 09:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
Short Shifter paulieblaze Engine, Exhaust, Transmission 33 01-20-2014 11:55 AM
Replace shifter bushings? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2013 10:49 AM
