Old 05-05-2014, 03:02 PM   #15
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You're better off going with a catback rather than just an overpipe change. I reccomend ARK -GRiP or Corsa Performance
Old 05-05-2014, 03:18 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Freeman View Post
It does.
To clarify, my Nameless 3inch op/dp combo bolted up to the stock header without issue.
Nameless created the OP/DP combo to be able to change the bend of the OP and not force it to connect to the OEM location because the OEM connection between OP and DP is really hard to work around and fit a bigger pipe. Fitting a 3 in OP retaining stock header and FP is going to be really difficult/impossible.
Old 05-05-2014, 03:25 PM   #17
wparsons
wparsons's Avatar
There's some dynos that have shown 5-8 whp. It has been debated to death if those are actual gains, changes because of resetting the ECU or what.
Still the matter of the fact is, ou increase the volume of a very small pipe, but keep all the restrictions in place. Doesn't seem like it is worth it still... Not trying to be negative, but real.
Those dynos are done with the OP being the last restriction in the exhaust though. I would bet that if you did a dyno comparison between fully stock and fully stock with a 3" over pipe only it wouldn't be a significant difference at all.
flickr
Old 05-05-2014, 03:27 PM   #18
jm1681
Drives: MKVI VW GTI
While I AM all about getting any bit of power I can, where I can, I have no interest in spending over a grand, or even over $500 on a full exhaust. The most I'd ever do at this point is the Flowmaster, strictly to get the 2.5" mid-section for as little as possible.
jm1681 is offline   Reply With Quote
Old 05-05-2014, 03:33 PM   #19
Sportsguy83
Drives: Limited BRZ
I agree.
Old 05-05-2014, 03:37 PM   #20
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Nameless created the PO/DP combo to be able to change the bend of the OP and not force it to connect to the OEM location because the OEM connection between OP and DP is really hard to work around and fit a bigger pipe. Fitting a 3 in OP retaining stock header and FP is going to be really difficult/impossible.
Agreed.
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
Sportsguy83 (05-05-2014)
Old 05-05-2014, 05:53 PM   #21
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
It's the cats in the system that is the restriction. No way around it even with a 3" OP. If you put in the OP, and install your trackpipe as you said, you lose the second cat and might gain a bit. Maybe 3whp?
Tye300 is offline   Reply With Quote
3" Overpipe protpibe Engine, Exhaust, Transmission 6 04-21-2014 12:05 PM
WTB: 2.5" Overpipe + Hardware leicaboss Want-To-Buy Requests 1 02-10-2014 01:44 AM
Overpipe > 2.5" ?? Deep Six Engine, Exhaust, Transmission 2 10-21-2013 06:40 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
