#2927 | |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | SkAsphalt (04-28-2014) |
#2928 |
Ridge Racerrrrrrrrr
Most certainly will not - but that is how I would go about doing it correct?
#2929 |
Drives: Limited BRZ
Yes sir. Shorten it so that there is more preload, but don't over do it.
#2930 |
Given the amount of questions lately in regards to cooling at the track, I've got some photos of how we prepped the AVO Japan BRZ that has been tracked extensively. The key to cooling at the circuit is air flow through the radiator, and how to maintain that effectively as the speeds rise. Speed is a very important factor that is often overlooked. That's because air seeks the path of least resistance, and when you are going fast enough, that's not through the bumper/radiator, but around it. So you need to force it to go where you want.
We started by sealing off the edges around the radiator, important for making the air go through and not around. ![]() ![]() Mounted to the car. ![]() Next, and just as important, we made sure the air from the bumper opening is ducted properly through the intercooler and to the radiator ![]() ![]() Finally, we designed our own lip spoiler. From our experience tuning race brz's at 230km/h, we found that too much air was escaping under the bumper instead of going into the radiator. With the lip spoiler, we dramatically lowered temperatures and improved handling. The Oil cooler is also ducted and sealed up properly. ![]() ![]() An interesting fact here - our RA model BRZ only has one cooling fan, as it has no air conditioner fitted (from the factory). In the BRZ/FR-S, one cooling fan is for the radiator, and one is for the air conditioner.
| The Following 6 Users Say Thank You to AVOturboworld For This Useful Post: | DarkSunrise (07-09-2014), Kiske (01-31-2015), M1K3 (04-29-2014), Raven604 (05-02-2014), sw20kosh (05-21-2014), Xero-Limit (05-22-2014) |
#2931 |
Drives: White FR-S
So how many PSIs is/was everyone getting with the stock kit? I finally got my kit installed yesterday and my log tells me I'm hitting a very consistent 5psi with the actuator labelled 6psi.
I'm thinking of giving the rod a couple turns to at least get to the proper 6psi. Not trying to be greedy. Also, I don't know if it's impolite to discuss, but for those of you who don't have a great tuner nearby, who have you gone with or plan to go with for an e-tune? |
#2932 |
Drives: 4-Runner Sport - 13' BRZ SportTech
I'm getting 7psi on the stock actuator, however, I've had the actuator off and would have moved the actuator rod in the process. Just adjust the rod and you can bump it up to 6psi.
I went through Bill @ Delicious Tuning for my AVO base map and was very pleased. The everyday driveability was perfect with no surging, idle dips, etc. I just ordered their new Speed Density MAP tune with a boost controller so I'll post up impressions when I have it in next week. It was between Delicious and Drift Office for me.
Top Tier Imports - Check out my build journal HERE
#2933 | |
Drives: 2014 FRS
How much boost are planing for the multi-maps? The only other mods I have are exhaust so I went with 6psi and 11psi maps. |
| The Following User Says Thank You to onzippy For This Useful Post: | DesertFrs (05-04-2014) |
#2934 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | protpibe (05-02-2014) |
#2935 | |
#2936 | |
#2937 |
Drives: sti 2012 sedan
Can you sell your stage 1 without the turbo? Everything else that comes with stage 1 but without the turbo? If so, how much?
#2938 |
Drives: 2013 BRZ limited WRB
Does the base tune come with a built in failsafe for psi or AFR? I searched through the forum but couldn't get a definitive answer.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
#2939 | ||
Drives: Scion FRS 10 Series AVO Turbo
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
| The Following User Says Thank You to DesertFrs For This Useful Post: | SkAsphalt (05-05-2014) |
#2940 | |
Sent from my HTC One using Tapatalk
| The Following User Says Thank You to protpibe For This Useful Post: | kbogarto (05-04-2014) |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
