Old 05-02-2014, 04:14 PM   #2325
Suddenly...
Suddenly...'s Avatar
Drives: 2013 High AT
Have been looking into a set of Konig Oversteer. They are available in 18x8J and 18x9J. according to carid the 9J won't fit the twins as the tyre sizes available are only 255/35/18's. I'd just like to know anyone else's opinions on this? As far as a I can see they are a 42 offset. If I could get away with 255's I would as I assume the grip would be pretty good. Much better than the 225's available from carid for the 8J setup.
Suddenly... is offline   Reply With Quote
Old 05-03-2014, 04:11 AM   #2326
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
I ordered a set of 17x8 +32. I have stock suspension but plan on getting ST coilovers. I was thinking of going with 235/45 to keep my turn in response, but after reading through this I am thinking 245/40 will be better. Will I have any issues with 245? And is that too much tire if I stay NA for the time being?
Thunderleg is offline   Reply With Quote
Old 05-03-2014, 10:06 PM   #2327
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
245 work on 8" wheels and well look good. If you primarly want to drift then 245 are not ideal, but for grip or daily drive 245 are a good choice. you wont feel a big difference in acceleration if thats what you're concerned about
Killerbee is offline   Reply With Quote
Old 05-04-2014, 01:55 AM   #2328
jasonnly
Drives: Toyota 86 GT
Front: 225/40-18 wrapped on Works Kiwami 18x8.5 +38
Rear: 245/35-18 wrapped on Works Kiwami 18x9.5 +38
Will this fit at stock ride height? How do you guys think it will look? And also how it will perform.
jasonnly is offline   Reply With Quote
Old 05-04-2014, 02:39 AM   #2329
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
Thanks for the info Killerbee. Do you know if 245 with +32 will rub?
Old 05-04-2014, 04:33 AM   #2330
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Interested in some RPF1.
Front 18x8+45 235/35/18
Rear 18x8+45 245/35/18
Or simply a square 245/35/18 if recommended.
On a 0.6 drop. Any possible issues ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 05-04-2014, 08:46 AM   #2331
Killerbee
Killerbee's Avatar
that setup will fit good. it may poke 5-10mm in front depending on the tire brand, but it will not rub
Old 05-04-2014, 08:51 AM   #2332
Killerbee
Killerbee's Avatar
I'd recommend 245/35/18 square. you can rotate tires that way and also have the same diameter on both wheels front/rear.
setup itself is good and will fit and look good
Old 05-04-2014, 11:06 PM   #2333
connorlug
Drives: #1553 10 Series FRS
I'm sure this has been asked a million times, but I'm gonna ask anyway
Have 18x8.5 +38 ready to go on once tires get here, tires are federal rsr 245/35/18.. they run about 10mm wider so theyll end up being almost a 255. doing a square setup with ST coilovers.
will they fit? lmao
connorlug is offline   Reply With Quote
The Following User Says Thank You to connorlug For This Useful Post:
Kilos6 (05-10-2014)
Old 05-05-2014, 05:49 PM   #2334
Killerbee
Killerbee's Avatar
will they fit? lmao
Yes, but depending on your cambet settings they will poke a bit in the front
Old 05-05-2014, 09:06 PM   #2335
dabocx
dabocx's Avatar
Drives: Scion FRS
Thinking of getting Work meister S1r, was going to get 18X9.5 +37 in the front with the big brake face, however im a little lost on the rear. I could get the 18X9.5 +37 in the rear with the deep dish face but is there another option to get something with more lip that will still fit 265s/275s in the rear? Maybe 18X10?
dabocx is offline   Reply With Quote
Old 05-05-2014, 10:43 PM   #2336
connorlug
Thanks for the reply. going to start with some camber bolts and see where i'm at. thanks!
Old 05-06-2014, 12:47 AM   #2337
Simon99
Simon99's Avatar
Talking about camber bolts/rca.. are they needed for the STI pink drop (0.6'')
Sent from my SGH-I337M using Tapatalk
Old 05-06-2014, 02:00 AM   #2338
Knightmare
Oppa Gangnam Style!
Knightmare's Avatar
Drives: Limited BRZ
Hey guys, I'm wanting to know if I get 18x8.5 +38 w/245/35 tires square would that fit at stock ride height? I'm also looking at down the road a little bit more to drop 1 inch so would I still clear? I played with the tire calculator and it appears I should be good but i'm wanting to double check that I'm not looking at it wrong. I'm wanting to get kinda close to flush, a little off is ok, so any suggestions on moving my offset even after a 1 inch drop? Thanks in advance for your guys assistance
Time moves on but memories last forever...
'13 Limited Dark Grey Metallic BRZ, Manual Transmission
'07 STi, Cobb AP Stage 1, Invidia Cat back exhaust (Traded for the BRZ)
'06 Nissan Sentra SE-R Spec V, Numerous Mods, mostly Nismo
My Journal
Knightmare is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
