#365 |
Drives: 2013 WR Blue Limited Manual BRZ
Like he said, reasons above. And it's a common misconception that rooting makes it less stable, it just gives you more access to do things that may or may not make it less stable, just rooting it changes nothing about the stability.
#366 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
He's probably thinking about custom ROMs, which can be buggy and unstable.
#367 |
Drives: Scion FR-S
Indeed - im assuming that is the end goal.
Andrew
2013 Scion FR-S MT (Silver) 2011 Toyota Rav4 Sport V6 4wd (Silver) |
#368 | |
Grip>Slip
One other benefit would be the ability to reprogram the Radio and GPS buttons. If it works like i think it does, it should be pretty simple. From what I can tell, the GPS button launches the "carnavi" app which is just a symbolic link to your default GPS app. My assumption is that the radio button works the same way. In theory, you would be able to have the radio and GPS button launch whatever app you desire (poweramp, torque, tunein, etc). Last edited by xjohnx; 05-03-2014 at 12:00 PM. |
#369 |
Drives: 2016 Cadillac CTS
Has anyone found a 30-pin dock connector to lightning adapter that does audio and isn't Apple's $30 one? I found one that claimed to do audio for $7 and I guess I should've known better, because it didn't.
#370 |
Because Racecar
Drives: 2013 Lightning Red Subaru BRZ
OK, so I confess to being a moron. I have the Ca-Fi and am trying to install it, but I'm having a few issues. Can anyone provide any advice? @SHIFTER or @SVXdc maybe?
Here are the basics. I have the BRZ OEM Audio + Reference 400 system with an OEM headunit (Fujitsu 10). I am not getting audio with the Ca-Fi, I think because its not getting power, but I'll let someone smarter than me take a guess. I connected two connections from the BRZ to the umbilical that came with the Ca-Fi. (Technically, I connected the two connections from my OEM Audio Plus system). The ones in red below. ![]() But after I do this, I still have connectors that aren't connected. ![]() On the OEM unit, they'd connect here ![]() It may not matter, but since I am not getting audio, I'm pretty sure it does. But its probably because I don't have the wire coming from the Ca-Fi labelled "Amp On" connected. Does anyone know where I should connect this? Using this link, I think it should connect to the pink wire in the OEM harness, but I'm not certain. Finally, there is a blue wire coming off the power antennae adapter. Does anyone know where that goes? Thanks in advance for any advice. |
#371 | |
Grip>Slip
Connect the "amp on" wire to any wire that gets power while the car is in accessory mode, (the blue antenna wire should actually work). You'll also need to get an adapter to allow the ca-fi to connect to the factory antenna harness. That adapter will have a wire coming off of it, you'll want to wire that to the blue antenna wire as well. |
#372 | |
Because Racecar
#373 | |
Because Racecar
Any chance you have a rear camera? That's the only thing I don't have working. |
#374 |
Grip>Slip
#375 | |
Drives: Scion FR-S
Andrew
#376 | |
Drives: Scion FR-S
see the previous pages for which rca input is for the camera.
Andrew
#377 |
Drives: Scion FR-S
Any new comers PLEASE PLEASE PLEASE read the whole thread - every question asked in the last 5 pages has been answered atleast once. I'm willing to help, but please read the thread.
Andrew
#378 |
Yep!
Drives: 2015 WRX Sti
I wish they would have a Subaru version for WRX! The 2015 wrx uses the same headunit as the brz (with different wiring harness) so I guess the 7" universal would work, but I hate to go splicing into wires. Awesome write up!
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
