Old 05-02-2014, 10:04 PM   #365
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by SHIFTER View Post
Why bother. It does everything you'd ever need in a car out of the box. All youd do is make it less stable, and that's a horrible thing to have when it's in the car
Like he said, reasons above. And it's a common misconception that rooting makes it less stable, it just gives you more access to do things that may or may not make it less stable, just rooting it changes nothing about the stability.
Deathalo is offline   Reply With Quote
Old 05-02-2014, 10:31 PM   #366
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
He's probably thinking about custom ROMs, which can be buggy and unstable.
B-R-Z is offline   Reply With Quote
Old 05-03-2014, 11:40 AM   #367
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Indeed - im assuming that is the end goal.
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 05-03-2014, 11:49 AM   #368
xjohnx
Grip>Slip
xjohnx's Avatar
yeah, no need for custom roms or anything. I mainly want the ability to choose my own launcher and addition of the full bluetooth stack. The full bluetooth stack would allow things like:
  • Bluetooth data tethering (as opposed to wifi)
  • High refresh rate (10hz) GPS sensors for datalogging
  • Pairing with my radar detector's smartcord so that i can use Escort Live (skip to 1:34 if the link doesn't take you there [ame="https://www.youtube.com/watch?v=A7PJPshCixU#t=94"]Escort Live Radar Detector Interface - YouTube[/ame] )
One other benefit would be the ability to reprogram the Radio and GPS buttons. If it works like i think it does, it should be pretty simple. From what I can tell, the GPS button launches the "carnavi" app which is just a symbolic link to your default GPS app. My assumption is that the radio button works the same way. In theory, you would be able to have the radio and GPS button launch whatever app you desire (poweramp, torque, tunein, etc).
Old 05-03-2014, 02:39 PM   #369
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Has anyone found a 30-pin dock connector to lightning adapter that does audio and isn't Apple's $30 one? I found one that claimed to do audio for $7 and I guess I should've known better, because it didn't.
Prog is offline   Reply With Quote
Old 05-03-2014, 03:26 PM   #370
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
OK, so I confess to being a moron. I have the Ca-Fi and am trying to install it, but I'm having a few issues. Can anyone provide any advice? @SHIFTER or @SVXdc maybe?
Here are the basics.
I have the BRZ OEM Audio + Reference 400 system with an OEM headunit (Fujitsu 10). I am not getting audio with the Ca-Fi, I think because its not getting power, but I'll let someone smarter than me take a guess.
I connected two connections from the BRZ to the umbilical that came with the Ca-Fi. (Technically, I connected the two connections from my OEM Audio Plus system). The ones in red below.
But after I do this, I still have connectors that aren't connected.
On the OEM unit, they'd connect here
It may not matter, but since I am not getting audio, I'm pretty sure it does. But its probably because I don't have the wire coming from the Ca-Fi labelled "Amp On" connected. Does anyone know where I should connect this? Using this link, I think it should connect to the pink wire in the OEM harness, but I'm not certain.
Finally, there is a blue wire coming off the power antennae adapter. Does anyone know where that goes?
Thanks in advance for any advice.
milhouse is offline   Reply With Quote
Old 05-03-2014, 03:50 PM   #371
xjohnx
Grip>Slip
xjohnx's Avatar
Bingo. I too have the OEM Audio+ unit.
Connect the "amp on" wire to any wire that gets power while the car is in accessory mode, (the blue antenna wire should actually work).
You'll also need to get an adapter to allow the ca-fi to connect to the factory antenna harness. That adapter will have a wire coming off of it, you'll want to wire that to the blue antenna wire as well.
Old 05-03-2014, 03:59 PM   #372
milhouse
Because Racecar
milhouse's Avatar
Thanks - I have that already and wasn't sure where to connect that either. I'll give it another shot.
Old 05-03-2014, 07:13 PM   #373
milhouse
Because Racecar
milhouse's Avatar
Thanks - this did it.
Any chance you have a rear camera? That's the only thing I don't have working.
Old 05-03-2014, 09:15 PM   #374
xjohnx
Grip>Slip
xjohnx's Avatar
i do, installed it over a year ago, never got around to wiring it up. maybe i'll do that tomorrow.
Old 05-03-2014, 10:38 PM   #375
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
post a how to if you're able to get any of those items to work
Andrew
Old 05-03-2014, 10:39 PM   #376
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
if you had a rear camera hooked up to the stock stereo you will need to unpin it and rewire it as a composite plug and plug it into the rca in the back of the unit.
see the previous pages for which rca input is for the camera.
Andrew
Old 05-03-2014, 10:40 PM   #377
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Any new comers PLEASE PLEASE PLEASE read the whole thread - every question asked in the last 5 pages has been answered atleast once. I'm willing to help, but please read the thread.
Andrew
The Following User Says Thank You to SHIFTER For This Useful Post:
DC2R (05-03-2014)
Old 05-03-2014, 10:55 PM   #378
jskurucz
Yep!
jskurucz's Avatar
Drives: 2015 WRX Sti
I wish they would have a Subaru version for WRX! The 2015 wrx uses the same headunit as the brz (with different wiring harness) so I guess the 7" universal would work, but I hate to go splicing into wires. Awesome write up!
jskurucz is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
