Old 05-03-2014, 01:56 PM   #1
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
lean at idle only
Hey guys,
I am having an issue that I can't figure out:
The car is running lean at idle (16-19 AFR). As soon as I give it a little gas or drive, it reads normal. On cold start it also reads normal.
There are no vacuum leaks. I can't hear any and I went thru and checked all the vacuum lines.
There are no popping or crackling (I thought DI seal failure at first)
Logs
http://datazap.me/u/woode87/lean-idle?log=0&data=
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 05-03-2014, 02:07 PM   #2
nelsmar
Need logs for sure. Get these at a minimal:
direct injection time, port time, short term trims, long term trims, rpm, manifold pressure, maf v, mass air flow (g/s), intake temp, coolant temp, oil temp, engine load, atmospheric pressure
My flickr - Canibeat
Local magazine scout
Old 05-03-2014, 03:24 PM   #3
woode
Boosted Member
woode's Avatar
@nelsmar, I uploaded a log, I had to change it to .doc to upload. You can change it back to .csv after downloading.
Log 2
Trying to figure out why they aren't displaying full resolution.. these should work if you click them and click zoom
Old 05-03-2014, 03:53 PM   #4
woode
Boosted Member
woode's Avatar
Staring at the log, the only thing I see that correlates with the AFR is my DI time sort of
The car makes pops very occasionally at idle... I always thought DI seal failure was more often and didn't cause lean conditions though.. so I am assuming this isn't the problem?
This is turning out to be a pain in the ass. I need to drive my car back to NJ from Texas in 2 weeks and this happens..
Old 05-03-2014, 05:13 PM   #5
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Log 2
Might be easier to upload to datazap.me
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
woode (05-03-2014)
Old 05-03-2014, 05:48 PM   #6
woode
Boosted Member
woode's Avatar
Logs
The Following User Says Thank You to woode For This Useful Post:
86-tundra (05-03-2014)
Why do people lean on their cars when posing with their cars? tzhu07 Other Vehicles & General Automotive Discussions 26 03-15-2014 09:51 AM
PO171 SYSTEM TOO LEAN BANK 1 rmdrag0n Engine, Exhaust, Transmission 23 03-02-2014 01:50 AM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 01:53 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 04:33 PM
Slip+CEL = Bank1 running lean? Trashed675 Issues | Warranty | Recalls / TSB 11 03-28-2013 11:53 PM
