Old 04-30-2014, 09:42 PM   #533
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Can someone please find IAM!?!? I would be soooo happy!!
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following User Says Thank You to calispec For This Useful Post:
ToyoburuBRZ (05-27-2014)
Old 04-30-2014, 10:33 PM   #534
ML
ML's Avatar
Drives: 13 White MT FR-S
I took these addresses from the taxtrix log config file. Idk if they will work the same but you can try it.
0xFFF816F0
0xFFF8B134
you might need to shorted it to after the F's or after the 8.
The Following User Says Thank You to ML For This Useful Post:
1Cor10:23 (04-30-2014)
Old 04-30-2014, 10:35 PM   #535
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
0xFFF816F0
0xFFF8B134
Can someone test these and confirm? Out of town
1Cor10:23 is offline   Reply With Quote
Old 04-30-2014, 11:40 PM   #536
calispec
calispec's Avatar
Ill try tomorrow.
www.GT86Mounts.com
Old 05-02-2014, 02:35 PM   #537
ML
ML's Avatar
Is there a way to log locally to the tablet instead of uploading it to their site? The upload web server for Torque is down apparently.
Old 05-02-2014, 02:57 PM   #538
stugray
Drives: 2013 GBS BRZ Limited
For all of those looking for the correct memory addresses for things like IAM or STFT:
Look up the log files for Tactrix (logcfg.txt) for your particular ROM ID.
The memory addresses in the logcfg.txt file would be the same ones you would use in torque for a custom PID.
As for:
Whenever I use torque for logging I find the local torque logfile (hidden in the filesystem) and email it to myself.
The auto-email log feature in torque never seems to work for me, I have to mail it manually.
The Following 2 Users Say Thank You to stugray For This Useful Post:
blackfireball5 (05-02-2014), ML (05-02-2014)
Old 05-02-2014, 03:01 PM   #539
ML
ML's Avatar
As for:
Thats the addresses I posted above, they are from the B01C log
Old 05-02-2014, 03:22 PM   #540
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Did anyone test this in torque?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 05-04-2014, 08:18 PM   #541
Dipstik-sportech
Dipstik-sportech's Avatar
Has anyone had an issue with connecting to the car when you have ecutek? The app recognises the dongle but won't connect to the car. A handheld scanner works fine
The Frozen North
Old 05-04-2014, 08:28 PM   #542
ML
ML's Avatar
The Frozen North
I have a oft tune and it does the same thing sometimes, but I just keep repluging it in and it eventually recognizes it
Old 05-04-2014, 10:52 PM   #543
calispec
calispec's Avatar
Just checked the PID's. They don't work. It says no data. I didn't know the equation but I just made one up because I wasn't concerned with the value. No luck.
www.GT86Mounts.com
The Following 3 Users Say Thank You to calispec For This Useful Post:
1Cor10:23 (05-05-2014), blackfireball5 (05-05-2014), ML (05-04-2014)
Old 05-05-2014, 10:44 PM   #544
Dipstik-sportech
So I tried plugging the adapter in at least a dozen times. Works fine in another vehicle though. Again cheap hand held scanner to the rescue
The Frozen North
Old 05-13-2014, 08:28 PM   #545
Lord Peth
Drives: 2014 BRZ
So my oil temp is working fine...but it displays in C and not F. All other gauges function in F...can seem to figure out the problem. I programmed the oil temp gauge before switching units in the settings, would this affect it?
Lord Peth is offline   Reply With Quote
Old 05-13-2014, 09:17 PM   #546
1Cor10:23
1Cor10:23's Avatar
You can adjust the output equation to convert to F I believe?
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
