#813 |
Professional Smartass
Drives: White Out FRS
| The Following User Says Thank You to post_break For This Useful Post: | captain_jack (04-29-2014) |
#814 |
Ok so I mounted the pulleys. Here's the deal with the forester oil cooler. It fits. Now it's very tight. We're talking 3-4mm tight, but it fits. The nice thing is that the part that is too close for comfort can be ground off with a dremel. The pictures don't do it justice.
The pictures make the bolt look closer than it appears in person. I will run this setup and have no fear of that nut ever contacting that part of the cooler. If it does I have bigger problems. So there you go. The forester oil cool will "fit" depending on how you view this gap. Please note you CANNOT run the hardline from the forester oil cooler. I have standard coolant hoses running down to a T. The hard line goes in the same place as the drivers side mounting bracket. That's what uses those two holes that the bracket utilizes that are magically unused. This oil cooler setup is about $250 from subaru and paired with an upgraded radiator should perform just fine on the track. |
#815 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Cool I'll probably put in my order soon for the OEM Forester oil cooler. I'm not looking forward to the install though since I'm going to have to remove the Kraftwerks S/C plate to make it fit I believe. I'm not 100% sold on whether or not an upgraded radiator would have that big of an effect on the overall cooling though. Seems like there just isn't enough surface area between the coolant and oil to be as effective as all those traditional oil coolers - even with a bigger radiator. My simple minded thought process goes... if it is good enough for a ~300 hp WRX/STI/ForesterXT, this should be good enough for my ~300hp FA20. (Hopefully with the smaller pulley going in at the same time it'd be 300++hp). (I don't track it much - more of a fun DD)
#816 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Sportsguy83 (04-30-2014) |
#817 |
Boosted Noob
I guess I'm saying I don't really drive it all that hard. The other option (which is honestly quite likely) is to see if time will bring a thermostatic solution that will be compatible with the KW kit. If I don't drive it all that hard, not even sure if the OEM solution is all that necessary.
#818 | |
Drives: 2022 BRZ Limited
good to know it's working with no problem
#820 |
I will also install koyo radiator so hopefully I don't run into any fitment issues
#821 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
#822 |
#823 |
Drives: 2013 Ultramarine FR-S
You can add me to the list. Paid for it yesterday.
| The Following 2 Users Say Thank You to Freeman For This Useful Post: | digital_assassin (05-01-2014), glamcem (04-30-2014) |
#824 | |
Drives: 13 CSB BRZ Ltd
So essentially, the system was designed in anticipation of failure?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
#825 | |
may the schwartz be with you.... |
#826 |
Drives: Nissan Versa
No system is 100% reliable. User error, installation error, manufacturing faults etc... will happen. Engineering some contingency into the system seems... prudent, no? I mean, Titanic and all...
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
