Old 04-29-2014, 06:48 PM   #4845
Tenthousanddays
Drives: 2013 BRZ Limited
Originally Posted by jdv14476 View Post
There is an open source ESC thread in the forum somewhere. That might be the place for your questions.
"http://www.ft86club.com/forums/showthread.php?t=41148"
Thanks, I have posted there.
Unfortunately I was looking for some more technical details about the motor and blower used on the Phantom system. But I digress.
I'll kindly show myself out of this thread.
Tenthousanddays is offline   Reply With Quote
Old 04-29-2014, 06:58 PM   #4846
fenton
There is quite a bit of information on Robs website phantom supercharger. Com
Don't feel like you have to leave, it just seems that this thread derails really quickly from time to time lol.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 04-29-2014, 07:38 PM   #4847
DC2R
Drives: 2014 Scion FR-S
I have read through much of this thread but usually on phone which shows 162 pages. I think the faq idea will go a long way to keep conversation focused. That being said I have a question. It's anyone running this setup with a subwoofer? I'm concerned about the smaller battery not being able to handle non-stock power draws. Thanks
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 04-29-2014, 07:51 PM   #4848
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Bu tang is and so is nlowell
Installed Mods:
Old 04-29-2014, 08:14 PM   #4849
fenton
The system only consumes 25A so its basically like running a standard rear defrost in most cars.
Old 04-29-2014, 08:34 PM   #4850
shif7i7down
Erected Member
Drives: frs
@fenton is it possible or even safe to wire 4 dump pack in series and utilize a 48v to 24v step down regulator to distribute the necessary 24v to the esc? one would think that it would improve the duration of max rpm"boost" with the esc.
if it is safe to do that, i wouldn't mind an extra 40lbs in the trunk for (full power) output all throughout the power-band.
Last edited by shif7i7down; 04-29-2014 at 09:03 PM. Reason: added additional nonsense -_-
shif7i7down is offline   Reply With Quote
Old 04-29-2014, 08:40 PM   #4851
fenton
Originally Posted by shif7i7down View Post
@fenton is it possible or even safe to wire 4~5 dump pack and utilize a regulator to distribute the necessary 24v to the esc? one would think that it would improve the duration of max rpm"boost" with the esc.
if it is safe to do that, i wouldn't mind an extra 40lbs in the trunk for an 24v (full power) all throughout the power-band.
You still get power through the entire power band even with the standard and 1.5 dump pack options.
You get to a point of diminishing returns. The reason the boost does drop off is because the ESC spins at a fixed RPM which results in a fixed amount of airflow. When the engine isn't efficient that means the airflow turns into boost, as the engine becomes more efficient it requires more air and that means less boost.
The larger the battery the longer it takes to heat up and dump current more efficiently. The current size has a great price to performance to heating up ratio.
Old 04-29-2014, 09:09 PM   #4852
shif7i7down
Erected Member
Drives: frs
I was just wondering because when you go WOT the volt meter display goes from 28v down to around 19-20v right?, so i was assuming that with the decrease in voltage to the esc the turbine would be spinning slower at 19v when compared to the initial 28v when you go wot.
but if that's not the case then i guess my question is kinda stupid.. i was really hoping to wire it in series and just use a regulator to output a constant 24v at wot all the way to redline..
Old 04-29-2014, 10:09 PM   #4853
DC2R
I'm thinking my 300rms /600 peak amplifier should use between 25 and 50 amps depending on conditions. Seems like a lot to run on small battery among with radio and all other equipment, no?
Sent from my GT-N5110 using Tapatalk
Old 04-29-2014, 10:50 PM   #4854
TM
TM's Avatar
Drives: DGM BRZ 6MT
It hasn't exactly been a week yet, but...
WHOAAAAAA. DAT TORQUE.
Love the acceleration with the ESC activated. Accelerates even though the 3-4k rpm range. Between the 18-mile drive on the highway to work, 20-mile drive on the back roads back home, and 5-mile drive to the gym, this thing makes me smile every step of the way!
TM is offline   Reply With Quote
Old 04-29-2014, 10:50 PM   #4855
Sojhinn
Sojhinn's Avatar
Love the acceleration with the ESC activated. Accelerates even though the 3-4k rpm range. Between the 18-mile drive on the highway to work, 20-mile drive on the back roads back home, and 5-mile drive to the gym, this thing makes me smile the whole way!
Wait until it really breaks in.
Installed Mods:
Old 04-29-2014, 10:59 PM   #4856
shif7i7down
Erected Member
Drives: frs
so I'm guessing you aren't underwhelm about the powwa of the ESC anymore?
how would you rate the ESC on a scale from 1 to 10, now vs when you initially installed it?
Old 04-30-2014, 12:32 AM   #4857
fenton
Awesome glad to hear you are loving it. To be honest i take the long way to work every day i drive the car just to keep boosting more
Old 04-30-2014, 12:34 AM   #4858
fenton
It really depends on what state the batteries were in when you get them. For me, Rob has always used the batteries first in his car so they were ready to go and got full boost right away.
The batteries really do take time to condition especially if they have been the factor or a warehouse for a while.
The best thing to clear this ailment is a heavy right foot
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
