Old 02-08-2014, 07:14 PM   #15
ikeryder13
Drives: 2013 GBS BRZ
Originally Posted by NYCsubaruBRZ View Post
heres some pics of my sub.
looks really nice with the interior IN the car but it is what it is. ill post pics when i get the interior back in the car.
sounds nice with the stock door speakers. plenty of bass imo.
no mounting hole(seat bolt) yet but thats easy. i need a little mesh grill for the sub port. have to decide on what color i want to do. prob wrb or black.
and i gotta switch the kicker out for a jl
How much would u charge for that?
ikeryder13 is offline   Reply With Quote
Old 02-09-2014, 12:08 PM   #16
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
250 for this one. i have a harness bar now and i cant use this box anymore. ill have to redesign a new one around the harness bar.
NYCsubaruBRZ is offline   Reply With Quote
Old 02-19-2014, 11:08 PM   #17
xcelir8brz
Drives: 2013 BRZ Limited
I may be interested in this box. Is it complete? Can you take a better picture of it inside and outside of the car (all around it)?
xcelir8brz is offline   Reply With Quote
Old 02-19-2014, 11:56 PM   #18
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
so i never got to make one but it looks like there's a lot of interest for something like this. someone with the tools should get this on the market I'd be down to pay for one
Sent from my SGH-I337M using Tapatalk
andrew5826 is offline   Reply With Quote
Old 02-28-2014, 09:35 PM   #19
butdamnbrian
Drives: 13 gbs brz
What's the volume of the box?
> CA crew. gbs brz ltd. 370z (sold). ap2 s2000 (sold). fg2 si (sold).
butdamnbrian is offline   Reply With Quote
Old 04-26-2014, 03:47 PM   #20
Scoobybrz
Scoobybrz's Avatar
Any updates on this project?
Scoobybrz is offline   Reply With Quote
Old 04-27-2014, 04:24 PM   #21
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Maybe it's a terrible idea... but has anyone tried something like this yet?
I can't be the first person to prioritize trunk space and rear-seat-fold-down-ability.
If you didn't want to do run the crazy mids and highs... you could invert the subs and the "rear seats" would fold flat.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 04-27-2014, 06:11 PM   #22
soundman98
ProCrastinationConsultant
soundman98's Avatar
a setup like that would work really well with a single IB 10. considering the airspace of the trunk, it wouldn't be worth porting.. and i don't understand the point of the dual 4ch amps..
Old 04-27-2014, 08:52 PM   #23
Shankenstein
Frosty Carrot
The plan is to split the stereo signal with MiniDSP out to 8 channels:
L & R - ring radiator tweeters in the A pillars
L & R - sealed midranges in the dash
L & R - woofers in the door
L & R - subs in the rear
I don't see much point in center-channel or rear fill with this car. Might test out a few configurations to see what works best.
According to this: LINK We have 6.9 cubic feet of trunk space with the seat up. The opening behind the seat is 13.25" x 40.5"
From my understanding, you want to make sure the trunk volume is atleast 10 x Vas. You also want to make sure to choose a woofer that has a Qts value between 0.6 - 0.8 (it damps itself well without support from a box).
The 10" subs I was planning to use have a Vas of 0.222 ft^3 and Qts of 0.721. That seems like a good fit for this application.
I've seen 3 main designs for IB in cars:
Old 04-28-2014, 01:26 PM   #24
mid_life_crisis
Drives: FR-S 10 #103 AT
Considering the size of the car, you might find this to be a better plan. More power to a single should give better control over the driver, which will be marginal with an infinite baffle setup. Of course you could argue that because it doesn't have the reinforcement of a proper box, you need all the driver surface area you can reasonably get, but I put accuracy at a premium, and accurate IB drivers tend to be power hungry due to very stiff suspensions, if I remember this stuff correctly.
Bridged - single 10" sub in the rear
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-28-2014, 04:40 PM   #25
Shankenstein
Frosty Carrot
Anything below 50 Hz won't or so won't give you a tangible benefit with regard to imaging. In a car with significant reflections, pockets, and generally bad acoustics... it does seem like a multi-sub setup gives you less cancellation/peaks throughout the car.
The following thread discusses multi-sub systems: LINK
The main reference from that discussion is a very technical paper, but it shows that more subs at a lower power yield a more even sound distribution. It also suggests that basic amounts of DSP can make tuning a multi-sub system quick and easy. LINK to PDF
Here's another reference that I found beneficial: LINK to PDF
TL;DR - The bottom octave of music (20-40 Hz) doesn't care if it's mono or stereo. Reflections and cancellation can get wonky. The top octave of sub-bass will have minor improvements with stereo bass (if it's processed properly).
10" Subwoofer Enclosure Driver Side Pre Order FRS / BRZ / GT 86 by Integrity Concepts Integrity Concepts Audio/Visual, Electronics, Infotainment, NAV 25 02-25-2014 10:29 PM
WTB driver seat cover, OEM/aftermarket. garudatwo Interior Parts (Incl. Lighting) 0 11-16-2013 10:45 AM
8" Subwoofer Enclosure Driver Side Pre Order FRS / BRZ / GT 86 by Integrity Concepts Integrity Concepts Audio/Visual, Electronics, Infotainment, NAV 5 11-06-2013 04:02 PM
Lowering/raising driver's seat? Dreamshot Scion FR-S / Toyota 86 GT86 General Forum 16 06-07-2013 04:59 AM
Driver Seat Article... Davyator Scion FR-S / Toyota 86 GT86 General Forum 8 06-15-2012 09:06 PM
