Old 04-26-2014, 09:47 PM   #15
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Originally Posted by diss7 View Post
The avo kit is working too hard at 300whp. If you only want to get a figure and hardly use it, then go avo. But pushing avo north of 250whp is not going to be a realiable track/often-raped setup.
How I love internet experts!
Pitman is offline   Reply With Quote
The Following 4 Users Say Thank You to Pitman For This Useful Post:
AllDayJonRay (04-28-2014), cdrazic93 (04-27-2014), DesertFrs (04-27-2014), deucethemoose (04-26-2014)
Old 04-26-2014, 10:28 PM   #16
Dipstik-sportech
Dipstik-sportech's Avatar
I love fanboys
The Frozen North
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
diss7 (04-26-2014), SmsAlSuwaidi (04-26-2014)
Old 04-26-2014, 11:01 PM   #17
diss7
Drives: AE86, 2x GT86, TE27
I've seen two avo turbo kitted 86s overheating at the track. Both running 7psi. Both had oil coolers. One also had a thicker radiator.
Real life track usage experience. Not "look at my dyno, my car is realiable because it's been going for a few months as a light duty street car" experience.
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
SmsAlSuwaidi (04-26-2014), Sportsguy83 (04-28-2014)
Old 04-26-2014, 11:02 PM   #18
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Fbm or Avo
@diss7 is legit, he took off a sc for a turbo
Sent from my IBrick
The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
diss7 (04-26-2014), Sportsguy83 (04-28-2014)
Old 04-27-2014, 05:49 PM   #19
SilverTipp
SilverTipp's Avatar
Drives: Silver
I thought one of the advantages of the AVO and PTUNING kits were there placement for quick spooling and low heat? Now you say the opposite? Everyone's differences in opinions and experience in this forum constantly confuses the sh*t out of me ... I don't know if I will ever bite the bullet and get one.
Sent from my SCH-I545 using Tapatalk
SilverTipp is offline   Reply With Quote
Old 04-27-2014, 06:02 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The big thing here is they are at the track, AVO is perfect for DD. I would probably go with PTUNING or FBM for the track
Old 04-27-2014, 06:05 PM   #21
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Odd that AVO has no problem with heat when beating the piss out of their racecar at Tsukuba.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
Pitman (04-28-2014)
Old 04-27-2014, 06:06 PM   #22
SmsAlSuwaidi
Boosted
Ever heard of something called third party testing ?
I know an avo kit that heated up within a few laps
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 04-27-2014, 06:21 PM   #23
deucethemoose
Sent from my IBrick
I know of a lot of third parties who have tested. There are a ton of us with the AVO kit up here in the PNW. There was an AVO powered car at 86 Expo that was beat on in the 100+ degree heat all weekend long with AC going and no issues.
No need to act like a tool - if you know of one kit that overheated then super. Don't buy one.
The Following 2 Users Say Thank You to deucethemoose For This Useful Post:
Pete156 (04-28-2014), Pitman (04-28-2014)
Old 04-27-2014, 06:26 PM   #24
Dipstik-sportech
No need to act like a fanboy and snap at someone who points out they know someone with the same kit as you that has issues. Do we know what cooling upgrades the on that was beat on had done to it? I highly doubt it was on the stock radiator.
The Frozen North
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
SmsAlSuwaidi (04-27-2014)
Old 04-27-2014, 06:30 PM   #25
SmsAlSuwaidi
Boosted
Im the tool in here ? ..lol I've ridden in most fi kits for this car and know most of their cons/pros; hell i even own a turbo kit. This car needs cooling upgrades to be tracked even in stock form.
Sent from my IBrick
Dipstik-sportech (04-27-2014), Sportsguy83 (04-28-2014)
Old 04-27-2014, 08:26 PM   #26
Bigmaxy
Drives: Pegasus GTS86
I would think that any car that is going to see sustained track time will need cooling upgrades regardless of AVO or FBM.
As an aside I seem to recall an issue with the cooling fans on some of the FBM kits melting also.
Bigmaxy is offline   Reply With Quote
Old 04-27-2014, 08:36 PM   #27
diss7
The Ptuning kit is the best turbo kit as far as heat management, because of the turbo placement, and the option to keep the well insulated stock headers. It has a lot of IC piping though, which is the compromise with this kit.
AVO turbo location seems positive for heat management, but the turbo outlet pipe is far from ideal from a flow point of view, and this will raise EGT. IMO, this offsets the gains from having the turbo mounted where they have it.
The Following User Says Thank You to diss7 For This Useful Post:
Old 04-27-2014, 08:54 PM   #28
Dipstik-sportech
All kits have they're teething problems, hell the car itself has had its own issues. All kits have they're ups and downs, it's up to you to weigh your options.
The Frozen North
SmsAlSuwaidi (04-27-2014), Sportsguy83 (04-28-2014)
