Old 04-25-2014, 11:39 PM   #15
Vmax911
Drives: WRB BRZ
Originally Posted by shiv@vishnu View Post
You'll need to load an OTS map for it to work.
I'm running an OFT 1.56 map, do I need to run the 1.59 for it to work?
FYI, here's the log. There is some knock sprinkled around in there.
http://www.datazap.me/u/vmax911/comm...0&data=1-11-12
Vmax911 is offline   Reply With Quote
Old 04-26-2014, 12:13 AM   #16
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
V1.56 should work as well. Have you let your OFT update in the last 2 days (through OF Manager)? Have you uploaded the newest template since then too?
Shiv@Openflash is offline   Reply With Quote
Old 04-26-2014, 12:23 AM   #17
Vmax911
Drives: WRB BRZ
Yeah, I updated and installed the new template last night before logging this afternoon.
Old 04-26-2014, 12:43 AM   #18
Shiv@Openflash
Drives: 2013 FRS
I don't know then. I'll have to look into it on Monday. Thanks for bringing it to my attention.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Vmax911 (04-26-2014)
Old 04-26-2014, 06:02 AM   #19
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Grip Ronin View Post
so fine kcl should remain at 0 to show no signs of knock?
Any negative values indicate that it's pulling timing, positive values will indicate that it's adding timing if the IAM is less than 1. Like FBKC it will only show in areas where timing adjustment has been learnt and will not be constant.
.: Stealth 86 :.
Kodename 47 DJ:
Grip Ronin (04-26-2014)
Old 04-26-2014, 06:06 AM   #20
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@shiv@vishnu a couple of days ago I noticed my OFT display missing the names for channels in 'realtime' and 'configure'. Can anyone tell me how to fix this? Logging still works....just that I can't see what channels to select.
Fizz is offline   Reply With Quote
Old 04-26-2014, 06:19 AM   #21
steve99
Drives: FT86
Easy one mate, download new template file from openflash site follow instructions to update should be sorted
Old 04-26-2014, 06:44 AM   #22
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Just tried that....no difference. Still can't see the channel names
Old 04-26-2014, 07:01 AM   #23
steve99
Drives: FT86
Thats weird mine is ok
Tablet show ver 1.26
OFM version is 107.1
Template was "FRS Customised 3.slt"
Even fixed the commanded AFR name
Old 04-26-2014, 07:27 AM   #24
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yeah I uploaded the latest customised 3 template....
Old 04-26-2014, 10:36 AM   #25
makinen
makinen's Avatar
Drives: Toyota 86
I'm on the same boat after applying "FRS Customized 3.SLT".
I'm using A01E rom.
One thing that I suspect is my OFT was upgraded to 1.26 when I connected it to OFT Manager 1.07, not 1.07.1. The upgrade was done automatically before I've noticed there is 1.07.1. But anyway the channel names displayed with previous template file.
I'll try the previous template.
makinen is offline   Reply With Quote
Old 04-26-2014, 10:48 AM   #26
makinen
makinen's Avatar
Drives: Toyota 86
As you can see, version strings are not matched.
OFT shows 1.26.
Old 04-26-2014, 11:25 AM   #27
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
I used the gauges for the first time yesterday. Awesome! Now I just need to figure out how to mount it on the air vent to the left of the steering wheel! Anyone have any ideas?
nlowell is offline   Reply With Quote
Old 04-26-2014, 12:56 PM   #28
Shiv@Openflash
Drives: 2013 FRS
Attachment 76316
OFT shows 1.26.
Before you go to the realtime data screen, go to channel configuration screen. Press right arrow to save effects of new template. Then go to the realtime data screen.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Can you run ecutek data logging on a samsung windows tablet Frs32907 Software Tuning 10 02-09-2016 10:30 PM
OpenFlash Tablet: Enhanced Data Logging (Sneak Peek) Shiv@Openflash Software Tuning 51 06-03-2014 07:09 AM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
