Old 04-25-2014, 04:12 PM   #15
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by protpibe View Post
That depends on what caused the gasket leak.
I mean no disrespect at all, but did you forget to tighten down a header bolt initially? If so, then your header is probably fine and once everything is re-tightened down properly it should be okay until the new gaskets arrive.
If you did install it 100% correctly and it blew out a gasket that early while throwing codes, I would take a look at the header itself before anything else.
We tightened them like no other! Super Super tight
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-25-2014, 10:39 PM   #16
Astroboy
Astroboy's Avatar
Drives: None
No problem. Tighten up the nuts as best you can and run it. I don't remember if they are locking nuts or not, but perhaps you could add a lock washer.
You think those gaskets of a wrx sti will fit?
Old 04-26-2014, 01:08 AM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would check with AVO. They didn't like people using thicker gaskets last time I checked.
Old 04-26-2014, 08:05 AM   #18
onzippy
Drives: 2014 FRS
Anyways I just ordered some new gaskets from avo.
Hi Astroboy,
The kit ships with new gaskets.
If you didn't get them call AVO or message them. It's also been mentioned several places to check all the torques after a few heat-cycles of the turbo.
There is so much existing info in the AVO build threads to help new owners who are installing the kit themselves avoid problems.
onzippy is offline   Reply With Quote
Old 04-26-2014, 10:38 AM   #19
charged86
charged86's Avatar
i have sti gaskets on my car
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
Astroboy (04-26-2014)
Old 04-26-2014, 01:38 PM   #20
Astroboy
Astroboy's Avatar
Drives: None
Isn't the p171b a code for the direct injection failure?
Old 04-26-2014, 02:30 PM   #21
Astroboy
Astroboy's Avatar
Drives: None
Do you think it could be because I connected to my pcv line instead of the brake booster??? I think I fucked up
Old 04-26-2014, 02:33 PM   #22
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I guess that depends on what you connected to your PCV line by accident.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Old 04-26-2014, 02:35 PM   #23
Astroboy
Astroboy's Avatar
Drives: None
Error code P0171 P0170 and P171b came up
So shoul i just connect the T port that connects the the by pass valve back the the brake booster and reconnect the pcv valve back together to its original line?
Old 04-26-2014, 03:22 PM   #24
protpibe
protpibe's Avatar
The actual PCV line should be untouched (passenger side). The drivers side crank case breather (sometimes mistaken for a PCV) and AVO oil reservoir breather should tee together and go back into the pre-turbo intake tract port.
The BOV should tee into a vacuum source.
Aside from those, I don't think you should be splicing into anything else
Old 04-26-2014, 03:32 PM   #25
Astroboy
Astroboy's Avatar
Drives: None
I'll show you a pic if what I did in a couple minutes when I get home
Old 04-26-2014, 03:46 PM   #26
Astroboy
Astroboy's Avatar
Drives: None
Ok so I plugged in a t port to go torwards the bov.
Old 04-26-2014, 04:03 PM   #27
Astroboy
Astroboy's Avatar
Drives: None
I posted the pic, listen if I did something incredibly stupid just let me know please. You can laugh your ass off, I'd understand. just don't kill me over it..... this is my first time modding stuff like this
Old 04-26-2014, 04:29 PM   #28
protpibe
protpibe's Avatar
Yeah, that's the actual PCV line. I guess it is under vacuum so I don't think it's the end of the world. I'm not sure if this is good advice or not, but personally I would move it over to the brake booster just in case.
I'm re-doing my catch can setup and ordered a new PCV line myself, so if you do end up replacing it, they're only like $10 from a dealer.
TechStream Error Code B14A1 developer Issues | Warranty | Recalls / TSB 13 10-08-2018 07:22 AM
ECUtek error 37 NickFRS Software Tuning 5 06-29-2014 04:14 PM
Unichip Error Code Ingeberger Engine, Exhaust, Transmission 5 12-29-2013 01:09 PM
Paperwork error Rob_g Scion FR-S / Toyota 86 GT86 General Forum 4 05-24-2012 11:38 PM
Driver error Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 5 07-14-2010 07:25 PM
