Old 04-25-2014, 12:17 PM   #281
xjohnx
Grip>Slip
xjohnx's Avatar
Power amp works. I just side loaded it without issue.
The Following 4 Users Say Thank You to xjohnx For This Useful Post:
Andrew025 (04-25-2014), milhouse (04-25-2014), Prog (04-25-2014), Stormalong (04-25-2014)
Old 04-25-2014, 12:28 PM   #282
xjohnx
Grip>Slip
xjohnx's Avatar
A couple shots of poweramp running:
Old 04-25-2014, 02:13 PM   #283
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Stormalong View Post
I got Sygic installed, I had to side load it since it killed the Play store app when I tried to install it.
You can use http://apps.evozi.com/apk-downloader/?id=com.sygic.aura to download the apk. I wasn't able to use this URL on the unit itself for some reason (it wouldn't download), so I did it on my computer and uploaded the apk to my Google Drive. Then I used Drive on the unit to download and install the apk. Then the app will download some data plus whatever maps you select (500MB Canada for me) and you are off and running.
Is Sygic the best offline navigation app?
Prog is offline   Reply With Quote
Old 04-25-2014, 02:21 PM   #284
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Idk about best, but it's probably the best/well known free offline nav app.
Deathalo is offline   Reply With Quote
The Following User Says Thank You to Deathalo For This Useful Post:
Prog (04-25-2014)
Old 04-25-2014, 03:06 PM   #285
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
So, day 2 mini review:
I was able to mess with the unit a lot more yesterday evening. I previously had a Nexus 7 install, so I basically already knew the sort of things I wanted - Podcast Addict, PowerAmp, MapFactor navigation, etc. I need to get my microSD card in before I can really do anything with offline navigation apps, so I can't comment too much on that.
It turns out, PowerAmp is not compatible with the Ca-Fi. Not a huge deal, I just downloaded Google Play Music, which does work (and there's a host of other apps that'll probably work). Like I said, the stock music app is pretty awful, so unless you're all about keeping this thing stock for some reason, you'll probably wanna get a different player. The good news is that so far, the physical buttons (next/previous) seem to work in Google Play Music.
Before I got a chance to install another different music player or Torque, I ran out of space on the head unit (I downloaded some podcasts in Podcast Addict also), so I have to wait until tomorrow to get my Micro SD card.
I haven't messed with Tasker at all yet, but I did install it, so I know it's compatible with the device.
Right now, my main concerns with the Ca-Fi are the random unmounting of the USB drive and the absurd, 2 year old 30 pin dock connector for iPhone. If the unit won't randomly unmount microSD cards, I'll be happy, as I don't really plan on using thumb drives. I think Apple's official 30-pin to lightning connector does audio, but all of the knock off ones do not, and I really cannot justify spending $30 on Apple's. If anyone finds an adapter for this that works, it would benefit myself (and probably others here) if you could send us a link for it.
TL;DR - my opinion of the unit has gone up since yesterday.
BTW just found I ran out of space too... Reason being is ky seems when u install an app from the play store it retains the APK install file on the c: drive. If you use the file manager to go in and delete them you will have plenty of space. Weird but not the worst thing.
Sorry been busy ... I'll comb this thread later and answer other questions.
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
The Following User Says Thank You to SHIFTER For This Useful Post:
Prog (04-25-2014)
Old 04-25-2014, 03:11 PM   #286
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Oh and no issues here with the SD card or USB unmounting randomly. Could be your drive or something.
Also make sure you take the plastic off the screen. Lol. I noticed the other day it was still on. Woops. Much more responsive and less glare.
Andrew
Old 04-25-2014, 05:52 PM   #287
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Nope,
@SHIFTER hasn't responded yet.
Whats up with your aux jack?
Andrew
Old 04-25-2014, 05:54 PM   #288
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by xjohnx View Post
anyone know the procedure for resetting the unit back to the factory ROM? I'm tempted to try that "root my an-21 u" app, but don't want to try without being able to restore if things get borked up
I accidentally did - I believe I held down the power/volume button for 20 seconds.
Be careful - mine defaulted to russian language when I did that on accident Easy fix though - just go into the language settings and change it.
Andrew
Old 04-25-2014, 05:58 PM   #289
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
How did you get the SWC pin out? I tried Shifter's recommendation of pushing the pin down with needlenose pliers, I tried pulling the wire from the bottom...nothing. Am I missing something?
edit: Nevermind, figured it out. I used a spare harness from my old head unit, pushed down on the little clip inside with an ice pick, and pulled the wire down from the bottom.
So I'm kinda confused on what to do with this aux adapter to make aux in work. Do you have any advice?
you only need the three pins for the two RCAs on the harness that you purhcased. Either clip the other wires or pull them out of the plug.
Once you've done that plug the harness in, you will see that the wires don't match 100% to the FR-S harness. Red is right, White is Left, Black is ground on the FR-S harness. You'll need to swap one or two of the pins around to match the FR-S harness - but im not 100% sure which off the top of my head (i did this over a year go). Should be pretty obvious.
Once done - plug the RCA plugs from that harness into the back of the stereo where the AUX input is (middle plugs, bottom and half way up)
Andrew
Old 04-25-2014, 06:24 PM   #290
Deathalo
I believe he bought the AUX adapter you linked to, and doesn't know what to do with it... which is helpful because I won't know either when mine comes
Old 04-25-2014, 06:29 PM   #291
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
See my last post
Andrew
Old 04-25-2014, 11:43 PM   #292
Prog
Prog's Avatar
I think I understand what you mean, but its been a while since I pulled the USB/aux port thing out of the dash. I will try to do it this weekend and see what happens.
Old 04-26-2014, 03:35 AM   #293
BennyBRZ
Drives: 14 BRZ Limited - DGM
Well I went ahead and pulled the trigger on the ca-fi. I don't have much experience with HU installs but hopefully with the aux, usb, antenna adapters linked in this thread the install should go fairly smooth when I get it.
BennyBRZ is offline   Reply With Quote
Old 04-26-2014, 11:00 AM   #294
Prog
Prog's Avatar
Just let us know if you need help.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
