#4579 |
Drives: DGM BRZ 6MT
What is super pursuit mode on?
#4580 |
Drives: Fiat Abarth
#4581 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
@fenton if you had the guess your peak psi what are you looking at?
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#4582 |
Drives: Firestorm FR-S AT
This just occured to me. For the 1.5 dump pack the "third" battery is two small batteries strapped together. So the final configuration is 1xstarter, 2xlarge dump, 2xsmall dump. Fenton said there was some technical reason why the two smaller ones is better than a third large one.
If thats the case, why not use the small ones for the entire dump pack? ie 1xstart and 6x small dump |
#4583 | |
Sent from my HTC One using Tapatalk |
#4584 | |
There isn't benefit to go to the smaller ones for all because they have to have the adapter and what not. Rob has tried much larger amp hour batteries and they take longer to heat up so they don't discharge as nice. Sent from my HTC One using Tapatalk |
#4585 |
Drives: WR Blue BRZ, 240Z
That's the beauty of this package, it doesn't require ANY engine modifications to the car. The modification is to the battery system and a flash to the ECU. Everything else is just a bolt on (or actually a bolt near).
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#4586 |
Drives: Your sister
I've been following this thread from beta stages, but I have question...this might already be covered, but to my understanding, the ESC activates when at 70% throttle load, correct?
Given the scenario, if I'm at mid-corner on a long sweeper @ 5000rpm and I'm slowly squeezing the throttle to WOT, does the ESC activate like a fully-on/off switch? Would it yield peaky, turbo-like (eg.single turbo supra power curve)?? I know ESC is designed primarily for street application, but I'm just concerned it might change the linear, predictable on-limit nature of the twins. I take my on-ramps full beast mode lol. |
#4587 | |
Drives: 2013 Scion FRS
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#4588 |
Yeah I am around 4.8 ish.
#4589 |
#4590 |
BTW- Im staying down here this weekend, but I figured it might be more useful to meet up and do the mods next week. Morning or afternoon better for the meet up?
#4591 | |
Worst case scenario you would go from 100 percent na power to like 130 percent power with boost depending on rpm. It has never been enough to upset the car in 3rd or higher gear. In first or 2nd you can get the back to step out mid corner if you time the boost right....its a lot of fun ![]() Supra would be like 100 percent power off boost and 250 percent on boost lol. Sent from my HTC One using Tapatalk |
#4592 | |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
